Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Web Banking problem
Update your Vista Drivers
Thread Tools Display Modes
Old 10-11-2006   #1 (permalink)
Martin Racette
Guest
Web Banking problem
I'm running Vista 64bit, and so far everything is just working as advertise,
except for one thing (an important one though)
When I try to login to my bank (TD Canada Trust), I get to the login just right,
but when I click the login (after I entered ID, and password), all I get is an
error page that tells me to make sure that the SSl and TLS is enable (they are
all enable)
How could I fix this
BTW. I tried with both version of IE7 (64 and standard), and the same place do
work with IE7 under XP
Thank you in Advance
Merci a l'Avance
Martin
Old 10-11-2006   #2 (permalink)
JerzyMarian
Guest
RE: Web Banking problem
Is it "404 error" ? If yes try unchek "TSL 1.0". My VISTA RC2 5744.
JerzyMarian
"Martin Racette" wrote:
> Hi,
> all enable)
> Merci a l'Avance
> Martin
Old 10-11-2006   #3 (permalink)
Gary G. Little
Guest
Re: Web Banking problem
Some banking systems are slow to accept changes in an OS. this may not be
the problem, but if it is, you mosy likely will not be able to use thier
home banking until some time after Vista is released. I encountered that
with B of A and going from NT4 to 2000.
Gary G. Little
"Martin Racette" <rat7_2001@hotmail.com> wrote in message
news:u9KtVqU7GHA.3960@TK2MSFTNGP05.phx.gbl...
> Hi,
> advertise, except for one thing (an important one though)
> right, but when I click the login (after I entered ID, and password), all
> I get is an error page that tells me to make sure that the SSl and TLS is
> enable (they are all enable)
> place do work with IE7 under XP
> Merci a l'Avance
> Martin
Old 10-13-2006   #4 (permalink)
Spirefm
Guest
Make sure that 'SSL2' is checked in Internet Explorer/Options/Advanced/Security
Colin
> Gary G. Little
> > Hi,
> > Merci a l'Avance
> > Martin
Old 10-15-2006   #5 (permalink)
Martin Racette
Guest
When I'm using IE7 in XP SSL2 is not enable and everything works fine, but in
Vista just to get the login page I need SSL2 enable.
BTW with Beta2 I was able to perform all I needed to do on that same website,
but with RC1....
Merci a l'Avance
Martin
"Spirefm" <Spirefm@discussions.microsoft.com> wrote in message
news:F038F0FB-8570-408A-A477-DE76E48F63CA@microsoft.com...
> Colin
>> Gary G. Little
>> > Hi,
>> > Merci a l'Avance
>> > Martin
Old 10-15-2006   #6 (permalink)
robw
Guest
No, putting the "Secure Sockets Layer" setting under "Security" would make
too much sense for M$.
They put it under "Advanced". Look for SSL 2.0
-Rob
"Hong" <aasdfasd@rogers.com> wrote in message
news:OfKWZDH8GHA.1252@TK2MSFTNGP04.phx.gbl...
> May I ask stupid questions? Where is this option SSL2? I checked Security
> and could not find it.
> Nadya
>> Colin
>>> be
>>> Gary G. Little
>>> > Hi,
>>> > just
>>> > all
>>> > is
>>> > Merci a l'Avance
>>> > Martin
Old 10-15-2006   #7 (permalink)
Barry Watzman
Guest
The issues here are not Vista, they are IE7 (which vista comes with, but
which will also be available for XP).
> Nadya
>> Colin
>>> not be
>>> Gary G. Little
>>> > Hi,
>>> login > just
>>> password), > all
>>> TLS > is
>>> > -- > Thank you in Advance
>>> > Merci a l'Avance
>>> > Martin
Old 10-15-2006   #8 (permalink)
Hong
Guest
Nadya
> Colin
>> Gary G. Little
>> > Hi,
>> > just
>> > all
>> > is
>> > Merci a l'Avance
>> > Martin
Old 10-22-2006   #9 (permalink)
Dreamweaver
Guest
I had the same problem and I had to 'check' Use SSL 2.0 and 'uncheck' Use TLS
1.0 and then everything was fine. IE7 Vista RC1
> but with RC1....
> Merci a l'Avance
> Martin
> > Colin
> >> Gary G. Little
> >> > Hi,
> >> > Merci a l'Avance
> >> > Martin
Old 10-23-2006   #10 (permalink)
grec
Guest
Use firefox
> > but with RC1....
> > Merci a l'Avance
> > Martin
> > > Colin
> > >> Gary G. Little
> > >> > Hi,
> > >> > Merci a l'Avance
> > >> > Martin
Display Modes
Banking in 08 ms accounting RickRSBAEnterprise .NET General 1 03-22-2008 02:36 PM
online banking Powerranger Vista General 1 02-17-2008 03:50 PM
Internet banking problem CaroleD Vista security 11 02-13-2007 02:39 PM
Web Banking problem Martin Racette Vista account administration 12 11-23-2006 02:58 PM
Web Banking problem Martin Racette Vista security 12 11-23-2006 02:58 PM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
