| | Portable hard drive for 64-bit vista I am trying to find, with out much luck, a good portable hard drive for my laptop. There are a lot of choices, but 99% of them have a disclaimer that they won't work with Vista 64 bit. I'm looking for something in the 320 to 500 GB range that I don't need a loan for! I bought a Seagate FreeAgent and the package said "works with Vista". I went to their website for install instructions and found, in micro print, "no support for Vista 64, only Vista 32 bit". The statement on their packaging pretty much took care of their credibility and truthfulness! Any ideas would be appreciated. Dave |
| | Re: Portable hard drive for 64-bit vista In article <#BuWHM7vJHA.924@xxxxxx>, Dave <jde2003@xxxxxx> wrote: Quote: > I am trying to find, with out much luck, a good portable hard drive for my >laptop. There are a lot of choices, but 99% of them have a disclaimer that >they won't work with Vista 64 bit. I'm looking for something in the 320 to >500 GB range that I don't need a loan for! will work with any Vista. Period the end. The ones that won't are the ones that try to be clever and use encrypted file systems that require software to access. Here's what you do: Buy a nice big sata drive of your choice. Buy a nice aluminum USB sata drive enclosure. Lots of colors and styles, with and without fans. Whatever. INstall drive, plug in, use drive management to format. |
| Vista Ultimate 64bit | Re: Portable hard drive for 64-bit vista I'm using a 1.5TB freeagent on my vista ultimate 64. It said it wouldn't work but does. The software for backups etc doesn't work. |
| | Re: Portable hard drive for 64-bit vista It may just be Seagate's drive management and back-up software that is not compatible with Vista 64. Plug it in and check to see if the OS recognizes and will read/write to it. If so, it ought to come up in Windows Explorer and as a Save As choice in applications. I had similar problems with a WD external drive. Once I stopped using and/or uninstalled all the WD software and went to conventional use of the drive, it works fine even though it's formatted in FAT32. I use Norton's back-up program but any standard OEM or third-party Windows back-up routines ought to work as well once you let Vista treat it like any other USB drive. BTW, many early Vista 64 owners found out the hard way that early adaptations of h/w and s/w to make them "Vista compatible" only included 32-bit platforms. I made several wasted purchases before I caught on to the fact that up until recently, developers considered the 64-bit Vista market to be too small of a user base to bother with. I guess that in their view at that time, if 95% of their potential buyers using Vista had Vista 32, that was good enough to justify claiming that their product would work on Vista systems - and too bad for the other 5%. It wasn't until computer manufacturers started selling Vista 64 PCs in quantity that the third-party s/w and peripheral vendors started explicitly noting on the package whether their product would work (or would not work) under Vista 64. Grrr... "Dave" <jde2003@xxxxxx> wrote in message news:%23BuWHM7vJHA.924@xxxxxx Quote: > I am trying to find, with out much luck, a good portable hard drive > for my laptop. There are a lot of choices, but 99% of them have a > disclaimer that they won't work with Vista 64 bit. I'm looking for > something in the 320 to 500 GB range that I don't need a loan for! > I bought a Seagate FreeAgent and the package said "works with > Vista". I went to their website for install instructions and found, > in micro print, "no support for Vista 64, only Vista 32 bit". The > statement on their packaging pretty much took care of their > credibility and truthfulness! > Any ideas would be appreciated. > > Dave > |
| | Re: Portable hard drive for 64-bit vista Any drive that works in Vista 32-bit should work in Vista 64-bit. I haven't found one yet that won't work for me. I would suspect that the disclaimer on the package refers to any bundled or utility software that comes with or on the drive. The drive itself should work fine. "Dave" <jde2003@xxxxxx> wrote in message news:#BuWHM7vJHA.924@xxxxxx Quote: > I am trying to find, with out much luck, a good portable hard drive for > my laptop. There are a lot of choices, but 99% of them have a disclaimer > that they won't work with Vista 64 bit. I'm looking for something in the > 320 to 500 GB range that I don't need a loan for! > I bought a Seagate FreeAgent and the package said "works with Vista". I > went to their website for install instructions and found, in micro print, > "no support for Vista 64, only Vista 32 bit". The statement on their > packaging pretty much took care of their credibility and truthfulness! > Any ideas would be appreciated. > > Dave > |
| | #6 (permalink) |
| | Re: Portable hard drive for 64-bit vista Thanks to all for the advice! I really get bummed at the developers for ignoring Vista 64. I'm going to ponder the suggestions and give it a shot. All I wanted to do was have the portable to save music and photos on so I would not clutter my main drive. I get real anal about having unused or seldom used stuff on the hard drive. Thanks again for the prompt and informative replies! Dave "mazorj" <mazorj@xxxxxx> wrote in message news:%23b56fI%23vJHA.6040@xxxxxx Quote: > It may just be Seagate's drive management and back-up software that is > not compatible with Vista 64. Plug it in and check to see if the OS > recognizes and will read/write to it. If so, it ought to come up in > Windows Explorer and as a Save As choice in applications. > > I had similar problems with a WD external drive. Once I stopped using > and/or uninstalled all the WD software and went to conventional use of > the drive, it works fine even though it's formatted in FAT32. I use > Norton's back-up program but any standard OEM or third-party Windows > back-up routines ought to work as well once you let Vista treat it > like any other USB drive. > > BTW, many early Vista 64 owners found out the hard way that early > adaptations of h/w and s/w to make them "Vista compatible" only > included 32-bit platforms. I made several wasted purchases before I > caught on to the fact that up until recently, developers considered > the 64-bit Vista market to be too small of a user base to bother with. > I guess that in their view at that time, if 95% of their potential > buyers using Vista had Vista 32, that was good enough to justify > claiming that their product would work on Vista systems - and too bad > for the other 5%. It wasn't until computer manufacturers started > selling Vista 64 PCs in quantity that the third-party s/w and > peripheral vendors started explicitly noting on the package whether > their product would work (or would not work) under Vista 64. Grrr... > > > "Dave" <jde2003@xxxxxx> wrote in message > news:%23BuWHM7vJHA.924@xxxxxx Quote: >> I am trying to find, with out much luck, a good portable hard drive >> for my laptop. There are a lot of choices, but 99% of them have a >> disclaimer that they won't work with Vista 64 bit. I'm looking for >> something in the 320 to 500 GB range that I don't need a loan for! >> I bought a Seagate FreeAgent and the package said "works with >> Vista". I went to their website for install instructions and found, >> in micro print, "no support for Vista 64, only Vista 32 bit". The >> statement on their packaging pretty much took care of their >> credibility and truthfulness! >> Any ideas would be appreciated. >> >> Dave >> > |
| Password protecting my portable hard drive | Software | |||
| How do I save my Exported Vista Mail Messages to a Portable Hard Drive | Vista mail | |||
| Portable Hard Drive Problems | Vista hardware & devices | |||
| Need Driver to install portable hard drive | Vista hardware & devices | |||
| portable hard drives not showing up at all | Vista hardware & devices | |||
