| | CD/DVD drive shows wrong icon when I place a disc in the drive I have a problem with the way my CD/DVD drive icons are showing up in the storage devices window. It seems that my machine is displaying the same icon regardless of the CD or DVD I put into my DVD drive. At one time, I put a Windows XP installation CD in my DVD drive, and the CD/DVD drive icon was replaced by the HP logo. I put another software or game into my DVD drive and I still got the HP logo as the CD/DVD drive icon. So I tried emptying all of my Prefetch files from my Prefetch folder, and I thought I solved the problem when I put the Windows XP CD into the drive and got the regular Setup icon. But when I put a different CD into the drive, the same Windows XP Setup icon showed up. And when I right-clicked 'Properties' on the CD/DVD drive Icon, in some cases there is no icon in the upper-left-hand corner next to the name of the CD. Is there something I need to fix in my registry, to keep the machine from displaying the wrong icon (or a stuck icon) whenever I put different CDs or DVDs into my DVD drive? Or is there a simpler solution? -- Message posted via WindowsKB.com http://www.windowskb.com/Uwe/Forums....vista/200904/1 |
| | Re: CD/DVD drive shows wrong icon when I place a disc in the drive I should add this example to clarify my explanation: I booted into Windows XP, and placed my Windows Vista and Windows XP installation discs into my DVD drive, knowing that they both have different SETUP icons. When I had the WinXP CD in the drive, the DVD icon was replaced by the XP SETUP icon; and when I put the Vista DVD in the drive, the DVD icon was replaced by the Vista SETUP icon. In Vista, when I put either disc in the DVD drive, I get the XP SETUP icon, even if I have the Vista DVD inside. For lack of a better way to explain this, it seems that the program that displays the appropriate icon (in place of the CD/DVD drive icon), for whatever program I have in the DVD drive, is stuck on whatever icon is in its cache. As I look at the COMPUTER window in Vista, I see the Vista Setup icon in the lower left-hand corner, but the CD/DVD drive icon has the XP Setup icon displayed, and I have a Vista setup disc inside. The wrong icon is being displayed for the disc that's in the drive. The icon being displayed, and the setup icon on the disc, are different. Is there any way to fix this? -- Message posted via WindowsKB.com http://www.windowskb.com/Uwe/Forums....vista/200904/1 |
| | Re: CD/DVD drive shows wrong icon when I place a disc in the drive In article <94ec8d2f28616@xxxxxx>, CookyMonzta via WindowsKB.com <u50174@xxxxxx> wrote: Quote: > >The wrong icon is being displayed for the disc that's in the drive. The icon >being displayed, and the setup icon on the disc, are different. Is there any >way to fix this? > What happens if you click refresh? |
| | Re: CD/DVD drive shows wrong icon when I place a disc in the drive On Tue, 21 Apr 2009 07:22:25 +0000 (UTC), the wharf rat wrote: Quote: > In article <94ec8d2f28616@xxxxxx>, > CookyMonzta via WindowsKB.com <u50174@xxxxxx> wrote: Quote: >> >>The wrong icon is being displayed for the disc that's in the drive. The icon >>being displayed, and the setup icon on the disc, are different. Is there any >>way to fix this? >> > What I have in mind is...white out and a box of Crayolas... > > What happens if you click refresh? It's not really a different thought, though. -- Gene E. Bloch letters0x40blochg0x2Ecom |
| | Re: CD/DVD drive shows wrong icon when I place a disc in the drive the wharf rat wrote: Quote: Quote: >>The wrong icon is being displayed for the disc that's in the drive. The icon >>being displayed, and the setup icon on the disc, are different. Is there any >>way to fix this? > What I have in mind is...white out and a box of Crayolas... > > What happens if you click refresh? -- Message posted via WindowsKB.com http://www.windowskb.com/Uwe/Forums....vista/200904/1 |
| Mapped Music Drive == "WRONG ICON!" | General Discussion | |||
| Wrong Drive Icon | Drivers | |||
| Putting a certificate in the proper place after accidentally puttingit in the wrong place | Vista security | |||
| Rename Drive Label/Change Drive Icon | Vista General | |||
| hard drive shows up as CD-ROM drive | Vista General | |||
