| | Control Panel -> Keyboard ->Key Settings - Hardware or Software Specific? Is the Control Panel -> Keyboard ->Key Settings tab made (not) available based on Hardware? Or is there a software module/driver required to be loaded to access this feature? Thanks, |
| | control panel hardware I needing the best seting vista +Bob+ wrote: Control Panel -> Keyboard ->Key Settings - Hardware or Software Specific? 23-abr-09 Is the Control Panel -> Keyboard ->Key Settings tab made (not) available based on Hardware? Or is there a software module/driver required to be loaded to access this feature? Thanks, Previous Posts In This Thread: On jueves, 23 de abril de 2009 03:21 p.m. +Bob+ wrote: Control Panel -> Keyboard ->Key Settings - Hardware or Software Specific? Is the Control Panel -> Keyboard ->Key Settings tab made (not) available based on Hardware? Or is there a software module/driver required to be loaded to access this feature? Thanks, EggHeadCafe - Software Developer Portal of Choice ASP.NET Atom-to-RSS Feed Converter http://www.eggheadcafe.com/tutorials...orss-feed.aspx |
| internet settings/control panel | Graphic cards | |||
| How do you save control panel settings? | Vista General | |||
| Control Panel - Show Specific Icons Only | Tutorials | |||
| Keyboard Icon Missing from Control Panel | Vista installation & setup | |||
| keyboard peoperties inside control panel is gone | Vista General | |||
