RB
Vista - USB CoreMicro Flash drive hangs system
05-07-2009   #1 (permalink)
Vista Home Premium 64bit
When I plug a 2.0 GB flash drive in my USB port it virtually hangs my machine.
Eventually it will respond, maybe 5 - 10 min later, but ever command takes that long.
It works on XP and Vista 32 bit. Any suggetions?
Thanks
05-08-2009   #2 (permalink)
Gene E. Bloch
Re: USB CoreMicro Flash drive hangs system
On Thu, 7 May 2009 23:37:34 -0500, nuttuphacker wrote:
> machine.
> takes that long.
> Thanks
If that is the only drive that does that, it's time to buy a new drive.
Of course, you'd have to transfer the contents from the old flash drive
using one of the other computers :-)
Gene E. Bloch letters0x40blochg0x2Ecom
05-10-2009   #3 (permalink)
mazorj
"nuttuphacker" <guest@xxxxxx-email.com> wrote in message
news:969f7869aae0c0618f8a3fc4a92d086b@xxxxxx-gateway.com...
> my
> machine.
> takes that long.
> Thanks
> nuttuphacker
Does it hang on both systems or just one OS? I've had problems with
old flash drives plugged into Vista, and new ones (with bundled
features and programs) on my XP machine. It's probably rooted in the
old 1.1 and new 2.0 USB standards, but at today's prices it's not
worth trying to correct. I bought some new ones, use the old drives
for short-term back-ups on my XP machine and the new ones on Vista.
The ones that work on both machines are used to do file transfers.
RB
Similar Threads for: USB CoreMicro Flash drive hangs system
Flash Drive has no drive letter... Not in Disk Management Vista hardware & devices
Pen drive/USB flash drive showing as floppy disk Vista General
LastWriteTime and Locating the drive letter of a flash drive. PowerShell
Zip file on flash drive slows system; 100% CPU Vista General
Question Regarding Flash-Drive Usage for System Memory Vista performance & maintenance
