"L. Brásio" <LBrsio@xxxxxx> wrote in message
news:896C5B18-BAC9-4D1A-8ED6-F9807F0D86EB@xxxxxx
> Hi everyone!
> I've been having a problem since I installed Vista on my laptop... I had
> to
> manually install some drivers and I don't know if I installed them all
> correctly... Anyway, I've been having this error/bluescreen:
> Produto
> Windows
> Problema
> Encerrar inesperadamente
> Data
> 06-05-2009 12:45
> Estado
> Relatório Enviado
> Assinatura do problema
> Nome do Evento do Problema: BlueScreen
> Versão do SO: 6.0.6001.2.1.0.256.1
> ID de Região: 2070
> Ficheiros que ajudam a descrever o problema (alguns ficheiros poderão
> deixar
> de estar disponÃ*veis)
> Mini050609-01.dmp
> sysdata.xml
> Version.txt
> Informações adicionais sobre o problema
> BCCode: d1
> BCP1: FFFFFFDC
> BCP2: 00000002
> BCP3: 00000001
> BCP4: 9A79E305
> OS Version: 6_0_6001
> Service Pack: 1_0
> Product: 256_1
> Informações do servidor: c355e80c-f320-402a-ac88-2806bc2817bb
> Can anyone help me please???
> Thank you!
> Regards Hi--
If you don't have the Vista DVD with Startup Repair Features to boot from
then
Download Vista Repair Disk
http://neosmart.net/blog/2008/window...disc-download/
1) First try 3 options from Startup Repair. If you have a Vista DVD then
restart with it in the drive>press any key to boot from it and run Startup
Repair. From Startup Repair you have 3 good tools with an excellent chance
of fixing your system. If you don't have a Vista DVD from which to boot to
Startup Repair, no problem, Download the .iso from the link below and
burn it, and you'll have the Microsoft Vista Repair Disk with Startup
Repair.
How to Use Startup Repair from the Vista DVD or the Repair Disk you make:
http://www.bleepingcomputer.com/tuto...torial142.html http://windowshelp.microsoft.com/Win...f3f351033.mspx
2) If Startup Repair does not get your Vista back, then use the 3 bootrec
commands from the command prompt available on the Statup Repair Menu:
The menu I refer to is in this set of directions with a grey background.
http://vistahomepremium.windowsreins...airstartup.htm
Those are:
bootrec /fixmbr
bootrec /fixboot
bootrec /rebuildbcd
3) If my second option doesn't work, then try System restore from the
Startup Repair list.
4) If by rare chance you have an actual Vista DVD, you can put it in, boot
from it>choose the Upgrade Option>choose your current broken Vista Drive and
try to do a repair install with the Vista DVD.
How To Perform a Repair Installation For Vista
Repair Install For Vista
5) If the above 3 tools don't work, then use the 4 tools available by
restarting your pc and tapping F8 once per second to get to the Windows
Advanced Options Menu.
From this menu click on 3 Safe Mode links to use System Restore. Make sure
you try all 3 if one doesn't work, because just one of them may work.
Tap F8 to Reach Windows Advanced Options Menu Pictured Below:
http://media.photobucket.com/image/v...ot-Options.jpg
Safe Mode
Safe Mode with Networking
Safe Mode with Command: At the prompt you would type the command to use
for system restore at the safe mode cmd prompt is:
%systemroot%\system32\restore\rstrui.exe
If these 3 tools don't work, you have one more you can try which is Last
Known Good Configuration.
Good luck,
CH
