| | Scheduled task when switching to battery mode Hi, I’m trying to create a scheduled task that will run when I unplug my laptop, ie. when it switches to battery mode. I can’t seem to find anything in the event logs that indicates that the laptop has switched to battery mode, so I’m a little stuck. Likewise, I’d like to run another scheduled task when I reconnect the laptop to the power and it stops running on battery mode. Does anyone know of a way that I can create such scheduled tasks? Thanks, -- Dylan Parry http://electricfreedom.org | http://webpageworkshop.co.uk “If I had my life to live over again, I'd be a plumber” – Einstein |
| | Re: Scheduled task when switching to battery mode On Fri, 15 May 2009 10:24:09 +0100, Dylan Parry wrote: Quote: > Hi, > > Im trying to create a scheduled task that will run when I unplug my > laptop, ie. when it switches to battery mode. I cant seem to find > anything in the event logs that indicates that the laptop has switched > to battery mode, so Im a little stuck. > > Likewise, Id like to run another scheduled task when I reconnect the > laptop to the power and it stops running on battery mode. > > Does anyone know of a way that I can create such scheduled tasks? > > Thanks, usually made to run in the Notification Area, that change the icon from a lightning bolt to a battery icon when you unplug the power supply. So it is obviously possible. -- Gene E. Bloch letters0x40blochg0x2Ecom |
| How to end a Scheduled Task | Vista General | |||
| Scheduled Task Challenge | Vista General | |||
| exe for scheduled task | .NET General | |||
| Scheduled Task - States Task Ran - No Results | Software | |||
| How do you rename a scheduled task | Vista account administration | |||
