Vista - Printers not showing in Control Panel
Old 05-15-2009   #1 (permalink)
Doug
I want to change the properties of a printer attached my computer but when I
click on Control Panel>Printers, Explorer opens with Printers highlighted in
the left pane but nothing appears in the right pane. There are 4 printers
on this machine and I can print to all of them but can't see them in Control
Panel!
Any idea what's causing this and how to correct it?
Doug
Solved Icon Labels Not Showing In Control Panel... General Discussion
Control Panel is EMPTY, Lost all printers Windows Updates
Control Panel showing wrong information. General Discussion
Unable to Remove Printers in Control Panel Vista print fax & scan
Control Panel not showing Vista General
