| | Wireless connection works, cable connection does not! I am having the worst problems connecting using a cable connection, which I need because as I am in Europe at the moment, many sites or private homes are not equipped with wireless. Now, when I connect with cable, everything seems to be working fine, the Toshiba connectivity doctor tells me I am connected, the diagnose program assures me that the problem has been resolved etc. etc. and yet whenever I try to connect (IE, Mozilla, Google, I have tried them all), I get an error screen. I have tried everything I could think of, checking my settings etc. Nothing works. Let me emphasize that: 1) wireless connection works fine 2) it is a problem with my computer, not the host, since I have encountered the same problem everywhere (libraries with password protected access, private homes without password protected access etc.). Can anyone help? |
| | Re: Wireless connection works, cable connection does not! Lyautey wrote: Quote: > I am having the worst problems connecting using a cable connection, which > I need because as I am in Europe at the moment, many sites or private > homes are not equipped with wireless. Now, when I connect with cable, > everything seems to be working fine, the Toshiba connectivity doctor tells > me I am connected, > the diagnose program assures me that the problem has been resolved etc. > etc. and yet whenever I try to connect (IE, Mozilla, Google, I have tried > them all), I get an error screen. I have tried everything I could think > of, checking my settings etc. Nothing works. > Let me emphasize that: > 1) wireless connection works fine > 2) it is a problem with my computer, not the host, since I have > encountered the same problem everywhere (libraries with password protected > access, private homes without password protected access etc.). > Can anyone help? paraphrasing. 2. Is the wired network adapter enabled? Look in Device Manager. 3. What antivirus/security program(s) do you have installed? I've seen cases where McAfee (for instance) firewalls the wired and wireless connections separately and you need to configure them accordingly. 4. The First Question Of Troubleshooting: If the problem is new, what changed between the time things worked and the time they didn't? Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ |
| | Re: Wireless connection works, cable connection does not! Thanks for your response. 1. What does the error screen say? Please quote exactly without paraphrasing. I have been getting several, like "This computer has limited or no connectivity. Cannot communicate with primary DNS server (134.157.0.129)" or "Windows failed to find the well-known host "www.microsoft.com" using DNS. The server may be down." 2. Is the wired network adapter enabled? Look in Device Manager. I did, thank you for the suggestion. Both the Atheros wireless adapter and the Realtek RTL8101 are working properly. I noticed yellow exclamation marks next to Microsoft 6to4 adapter and ISATAP adater no. 3. When I clicked on the link I found a message indicating "This device is not working properly because Windows cannot load the drivers required for this device. (Code 31) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available." I did in both cases. 3. What antivirus/security program(s) do you have installed? I've seen cases where McAfee (for instance) firewalls the wired and wireless connections separately and you need to configure them accordingly. I got rid of McAfee, which came with my Toshiba, about a year ago, having noticed hat it kept causing freezes and other problems. Now I have Symantec, to which I can connect (when I can connect) as a member of the Vassar College community. I haven't noticed any particular problems. 4. The First Question Of Troubleshooting: If the problem is new, what changed between the time things worked and the time they didn't? This I can't answer because I cannot remember when or how the problem started. As I said, generally I do not need a wired connection because in the US most places are wireless now, but Europe is way behind and a wired connection is needed in most places. Thanks for continuing to advise if you can. Quote: > Malke Quote: > Lyautey wrote: > Quote: > > I am having the worst problems connecting using a cable connection, which > > I need because as I am in Europe at the moment, many sites or private > > homes are not equipped with wireless. Now, when I connect with cable, > > everything seems to be working fine, the Toshiba connectivity doctor tells > > me I am connected, > > the diagnose program assures me that the problem has been resolved etc. > > etc. and yet whenever I try to connect (IE, Mozilla, Google, I have tried > > them all), I get an error screen. I have tried everything I could think > > of, checking my settings etc. Nothing works. > > Let me emphasize that: > > 1) wireless connection works fine > > 2) it is a problem with my computer, not the host, since I have > > encountered the same problem everywhere (libraries with password protected > > access, private homes without password protected access etc.). > > Can anyone help? > 1. What does the error screen say? Please quote exactly without > paraphrasing. > > 2. Is the wired network adapter enabled? Look in Device Manager. > > 3. What antivirus/security program(s) do you have installed? I've seen cases > where McAfee (for instance) firewalls the wired and wireless connections > separately and you need to configure them accordingly. > > 4. The First Question Of Troubleshooting: If the problem is new, what > changed between the time things worked and the time they didn't? > > Malke > -- > MS-MVP > Elephant Boy Computers - Don't Panic! > http://www.elephantboycomputers.com/#FAQ > > |
| | Re: Wireless connection works, cable connection does not! Hi Lyautey, Open cmd prompt and type: ipconfig /all If everything is OK, you should get a valid IP address for your wired network connection from a local DHCP service. If DHCP service is not available, your IP address will look like: 169.254.y.z (where y and z = 1 - 254) This range of addresses is known as APIPA and allows you to communicate only on the local network, but not on the Internet. If you get that address, you should ask the person who is in charge of that wired network for help . Another thing. When you use wired connection, make sure that wireless connection is turned off. "Lyautey" <Lyautey@xxxxxx> wrote in message news:90D41FF2-F5C8-4F31-BDD7-DB99F9741998@xxxxxx Quote: > Thanks for your response. > > 1. What does the error screen say? Please quote exactly without > paraphrasing. > > I have been getting several, like "This computer has limited or no > connectivity. > Cannot communicate with primary DNS server (134.157.0.129)" or "Windows > failed to find the well-known host "www.microsoft.com" using DNS. The > server > may be down." > > > 2. Is the wired network adapter enabled? Look in Device Manager. > > I did, thank you for the suggestion. Both the Atheros wireless adapter and > the Realtek RTL8101 are working properly. I noticed yellow exclamation > marks > next to Microsoft 6to4 adapter and ISATAP adater no. 3. When I clicked on > the > link I found a message indicating "This device is not working properly > because Windows cannot load the drivers required for this device. (Code > 31) > Click 'Check for solutions' to send data about this device to Microsoft > and > to see if there is a solution available." I did in both cases. > > 3. What antivirus/security program(s) do you have installed? I've seen > cases > where McAfee (for instance) firewalls the wired and wireless connections > separately and you need to configure them accordingly. > > I got rid of McAfee, which came with my Toshiba, about a year ago, having > noticed hat it kept causing freezes and other problems. Now I have > Symantec, > to which I can connect (when I can connect) as a member of the Vassar > College > community. I haven't noticed any particular problems. > > 4. The First Question Of Troubleshooting: If the problem is new, what > changed between the time things worked and the time they didn't? > > This I can't answer because I cannot remember when or how the problem > started. As I said, generally I do not need a wired connection because in > the > US most places are wireless now, but Europe is way behind and a wired > connection is needed in most places. > > Thanks for continuing to advise if you can. Quote: >> Malke > "Malke" wrote: > Quote: >> Lyautey wrote: >> Quote: >> > I am having the worst problems connecting using a cable connection, >> > which >> > I need because as I am in Europe at the moment, many sites or private >> > homes are not equipped with wireless. Now, when I connect with cable, >> > everything seems to be working fine, the Toshiba connectivity doctor >> > tells >> > me I am connected, >> > the diagnose program assures me that the problem has been resolved >> > etc. >> > etc. and yet whenever I try to connect (IE, Mozilla, Google, I have >> > tried >> > them all), I get an error screen. I have tried everything I could think >> > of, checking my settings etc. Nothing works. >> > Let me emphasize that: >> > 1) wireless connection works fine >> > 2) it is a problem with my computer, not the host, since I have >> > encountered the same problem everywhere (libraries with password >> > protected >> > access, private homes without password protected access etc.). >> > Can anyone help? >> 1. What does the error screen say? Please quote exactly without >> paraphrasing. >> >> 2. Is the wired network adapter enabled? Look in Device Manager. >> >> 3. What antivirus/security program(s) do you have installed? I've seen >> cases >> where McAfee (for instance) firewalls the wired and wireless connections >> separately and you need to configure them accordingly. >> >> 4. The First Question Of Troubleshooting: If the problem is new, what >> changed between the time things worked and the time they didn't? >> >> Malke >> -- >> MS-MVP >> Elephant Boy Computers - Don't Panic! >> http://www.elephantboycomputers.com/#FAQ >> >> |
| Windows 7 | Re: Wireless connection works, cable connection does not! Thanks for your response. 1. What does the error screen say? Please quote exactly without paraphrasing. I have been getting several, like "This computer has limited or no connectivity. Cannot communicate with primary DNS server (134.157.0.129)" or "Windows failed to find the well-known host "www.microsoft.com" using DNS. The server may be down." 2. Is the wired network adapter enabled? Look in Device Manager. I did, thank you for the suggestion. Both the Atheros wireless adapter and the Realtek RTL8101 are working properly. I noticed yellow exclamation marks next to Microsoft 6to4 adapter and ISATAP adater no. 3. When I clicked on the link I found a message indicating "This device is not working properly because Windows cannot load the drivers required for this device. (Code 31) Click 'Check for solutions' to send data about this device to Microsoft and to see if there is a solution available." I did in both cases. 3. What antivirus/security program(s) do you have installed? I've seen cases where McAfee (for instance) firewalls the wired and wireless connections separately and you need to configure them accordingly. I got rid of McAfee, which came with my Toshiba, about a year ago, having noticed hat it kept causing freezes and other problems. Now I have Symantec, to which I can connect (when I can connect) as a member of the Vassar College community. I haven't noticed any particular problems. 4. The First Question Of Troubleshooting: If the problem is new, what changed between the time things worked and the time they didn't? This I can't answer because I cannot remember when or how the problem started. As I said, generally I do not need a wired connection because in the US most places are wireless now, but Europe is way behind and a wired connection is needed in most places. Thanks for continuing to advise if you can. Quote: > Malke Quote: > Lyautey wrote: > Quote: > > I am having the worst problems connecting using a cable connection, which > > I need because as I am in Europe at the moment, many sites or private > > homes are not equipped with wireless. Now, when I connect with cable, > > everything seems to be working fine, the Toshiba connectivity doctor tells > > me I am connected, > > the diagnose program assures me that the problem has been resolved etc. > > etc. and yet whenever I try to connect (IE, Mozilla, Google, I have tried > > them all), I get an error screen. I have tried everything I could think > > of, checking my settings etc. Nothing works. > > Let me emphasize that: > > 1) wireless connection works fine > > 2) it is a problem with my computer, not the host, since I have > > encountered the same problem everywhere (libraries with password protected > > access, private homes without password protected access etc.). > > Can anyone help? > 1. What does the error screen say? Please quote exactly without > paraphrasing. > > 2. Is the wired network adapter enabled? Look in Device Manager. > > 3. What antivirus/security program(s) do you have installed? I've seen cases > where McAfee (for instance) firewalls the wired and wireless connections > separately and you need to configure them accordingly. > > 4. The First Question Of Troubleshooting: If the problem is new, what > changed between the time things worked and the time they didn't? > > Malke > -- > MS-MVP > Elephant Boy Computers - Don't Panic! > index > > disable the wireless adapter while connecting through wired. The gateway of your wireless adapter may interrupt your wired connection. keep us informed |
| | #6 (permalink) |
| | Re: Wireless connection works, cable connection does not! Lyautey wrote: Quote: > Thanks for your response. > > 1. What does the error screen say? Please quote exactly without > paraphrasing. > > I have been getting several, like "This computer has limited or no > connectivity. > Cannot communicate with primary DNS server (134.157.0.129)" or "Windows > failed to find the well-known host "www.microsoft.com" using DNS. The > server may be down." tell unless you run ipconfig - see below) but you definitely have a problem with DNS. First do this: Start Orb>Search box>type: cmd When cmd appears in Results above, right-click and choose "run as administrator". This will get you an elevated command prompt. At the command prompt type: ipconfig /all [enter] See what IP address is assigned to the ethernet (wired) adapter. See what DNS servers are listed. Post back with that information. In the meantime: Is this computer a member of a domain? It sounds like you have the wired adapter set to get DNS from 134.157.0.129. This was possibly set up because of the college network. You need to set the wired adapter to get its IP and DNS automatically. While you're at it, disable IPv6 too. This Microsoft Knowledge Base article tells you how to do these things: http://windowshelp.microsoft.com/Win...b11e21033.mspx Quote: > I noticed yellow exclamation > marks next to Microsoft 6to4 adapter and ISATAP adater no. 3. address the IP/DNS issues. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ |
| | #7 (permalink) |
| | Re: Wireless connection works, cable connection does not! Hi there, thanks for the suggestions, I will try what you suggest. In the meantime, here is the information I get after typing ipconfig /all (I am skipping what obviously has to do only with wireless): Ethernet adapter Local Area Connection : Connection-specific DNS Suffix : Description: Realtek RTL8101 Family PC1-E Fast Ethernet NIC (NDIS 6.0) Physical Address: 00-1B-38-3D-F9-86 DHCP Enabled: Yes Autoconfiguration Enabled: Yes Link-local IPv6 Address: fe80::ecc3:a195:8d25:53b3%8(Preferred) IPv4 Address: 82.224.27.22 (Preferred) Subnet Mask: 255.255.255.0 Lease Obtained: Friday, May 15, 2009 4:18:42 PM [EST] Lease Expired: Friday, May 22, 2009 4:18:42 PM Default Gateway: 82.224.27.254 DHCP Server: 82.224.26.254 DNS Servers: 134.157.0.129 134.157.29.13 NetBIOS over Tcpip: Enabled Tunnel adapter Local Area Connection* 9: Media State: Media disconnected Connection-specific DNS Suffix: Description: 00-00-54-4E-01 DHCP Enabled: No Autoconfiguration Enabled: Yes Tunnel adapter Local Area Connection* 10: Media State: Media disconnected Connection-specific DNS Suffix: Description: Teredo Tunneling Pseudo-Interface Physical Address: 02-00-54-55-$E-01 DHCP Enabled: No Autoconfiguration Enabled: Yes Tunnel adapter Local Area Connection* 11: Media State: Media disconnected Connection-specific DNS Suffix: Description: isatap.(AE9D600A-786D-4646-93E3-DCBC340c9835) Physical Address: 00-00-00-00-00-00-00-E0 DHCP Enabled: No Autoconfiguration Enabled: Yes Tunnel adapter Local Area Connection* 15: Media State: Media disconnected Connection-specific DNS Suffix: Description: isatap.(75E43715-D7C1-4D0B-9238-71CEA9C99C8) Physical Address: 02-00-54-55-$E-01 DHCP Enabled: No Autoconfiguration Enabled: Yes Tunnel adapter Local Area Connection* 16: Connection-specific DNS Suffix: Description: 6TO Adapter Physical Address: 00-00-00-00-00-00-00-E0 DHCP Enabled: No Autoconfiguration Enabled: Yes IPv6 Address: 2002:52e0:1b16::52e0:1b16 (Preferred) Default Gateway: DNS Servers: 134.157.0.129 134.157.29.13 NetBIOS over Tcip: Disabled Tunnel adapter Local Area Connection* 17: Media State: Media disconnected Connection-specific DNS Suffix: Description: isatap.ens.fr Physical Address: 00-00-00-00-00-00-00-E0 DHCP Enabled: No Autoconfiguration Enabled: Yes (And of course I did turn off the wireless connection as you advised but it made absolutely no difference). "Malke" wrote: Quote: > Lyautey wrote: > Quote: > > Thanks for your response. > > > > 1. What does the error screen say? Please quote exactly without > > paraphrasing. > > > > I have been getting several, like "This computer has limited or no > > connectivity. > > Cannot communicate with primary DNS server (134.157.0.129)" or "Windows > > failed to find the well-known host "www.microsoft.com" using DNS. The > > server may be down." > OK, it sounds like you are getting an IP address (or possibly not, I can't > tell unless you run ipconfig - see below) but you definitely have a problem > with DNS. > > First do this: > > Start Orb>Search box>type: cmd > When cmd appears in Results above, right-click and choose "run as > administrator". This will get you an elevated command prompt. At the > command prompt type: > > ipconfig /all [enter] > > See what IP address is assigned to the ethernet (wired) adapter. See what > DNS servers are listed. Post back with that information. > > In the meantime: Is this computer a member of a domain? It sounds like you > have the wired adapter set to get DNS from 134.157.0.129. This was possibly > set up because of the college network. You need to set the wired adapter to > get its IP and DNS automatically. While you're at it, disable IPv6 too. > This Microsoft Knowledge Base article tells you how to do these things: > > http://windowshelp.microsoft.com/Win...b11e21033.mspx > Quote: > > I noticed yellow exclamation > > marks next to Microsoft 6to4 adapter and ISATAP adater no. 3. > This is nothing to worry about and unconnected to your problem. Let's > address the IP/DNS issues. > > Malke > -- > MS-MVP > Elephant Boy Computers - Don't Panic! > http://www.elephantboycomputers.com/#FAQ > > |
| | #8 (permalink) |
| | Re: Wireless connection works, cable connection does not! Lyautey wrote: Quote: > Hi there, thanks for the suggestions, I will try what you suggest. In the > meantime, here is the information I get after typing ipconfig /all (I am > skipping what obviously has to do only with wireless): > > Ethernet adapter Local Area Connection : > > Connection-specific DNS Suffix : > Description: Realtek RTL8101 Family PC1-E Fast Ethernet NIC (NDIS 6.0) > Physical Address: 00-1B-38-3D-F9-86 > DHCP Enabled: Yes > Autoconfiguration Enabled: Yes > Link-local IPv6 Address: fe80::ecc3:a195:8d25:53b3%8(Preferred) > IPv4 Address: 82.224.27.22 (Preferred) > Subnet Mask: 255.255.255.0 > Lease Obtained: Friday, May 15, 2009 4:18:42 PM [EST] > Lease Expired: Friday, May 22, 2009 4:18:42 PM > Default Gateway: 82.224.27.254 > DHCP Server: 82.224.26.254 > DNS Servers: 134.157.0.129 > 134.157.29.13 > NetBIOS over Tcpip: Enabled A Whois lookup for that IP address produces this: netnum: 82.224.26.0 - 82.224.27.255 netname: FR-PROXAD-ADSL descr: Proxad / Free SAS descr: Static pool (Freebox) descr: menilmontant-5 (th2) descr: NCC#2003105812 country: FR (For more see: http://whois.domaintools.com/82.224.27.254) So I assume since you said that you are in Europe that you are in France and this is the ISP you're using. However, the DNS server is located at the Universite Pierre et Marie Curie: inetnum: 134.157.0.0 - 134.157.255.255 netname: FR-UPMC-NET descr: Universite Pierre et Marie Curie descr: Centre de Calcul Recherche descr: 4 Place Jussieu, 75252 Paris CEDEX 05, France country: FR (For more see: http://whois.domaintools.com/134.157.0.129) You are properly getting a public IP address from the ISP but failing on DNS. Make sure your computer is set to get DNS automatically as described in my last post to you (and disable IPv6 while you're there). Then flush your DNS cache by: Start Orb>Search box>type: cmd When cmd appears in Results above, right-click it and choose "Run as administrator". This will give you an elevated command prompt. At the command prompt type: ipconfig /flushdns [enter] Exit the command prompt and try to connect to the Internet. Report back. Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ |
| | #9 (permalink) |
| | Re: Wireless connection works, cable connection does not! I think you solved it! I have been able to connect at the BnF (I am indeed in Paris since I have been teaching in France this past year). Many thanks! Lyautey "Malke" wrote: Quote: > Lyautey wrote: > Quote: > > Hi there, thanks for the suggestions, I will try what you suggest. In the > > meantime, here is the information I get after typing ipconfig /all (I am > > skipping what obviously has to do only with wireless): > > > > Ethernet adapter Local Area Connection : > > > > Connection-specific DNS Suffix : > > Description: Realtek RTL8101 Family PC1-E Fast Ethernet NIC (NDIS 6.0) > > Physical Address: 00-1B-38-3D-F9-86 > > DHCP Enabled: Yes > > Autoconfiguration Enabled: Yes > > Link-local IPv6 Address: fe80::ecc3:a195:8d25:53b3%8(Preferred) > > IPv4 Address: 82.224.27.22 (Preferred) > > Subnet Mask: 255.255.255.0 > > Lease Obtained: Friday, May 15, 2009 4:18:42 PM [EST] > > Lease Expired: Friday, May 22, 2009 4:18:42 PM > > Default Gateway: 82.224.27.254 > > DHCP Server: 82.224.26.254 > > DNS Servers: 134.157.0.129 > > 134.157.29.13 > > NetBIOS over Tcpip: Enabled > Your computer is set to get an address from a DCHP server at 82.224.27.254. > A Whois lookup for that IP address produces this: > > netnum: 82.224.26.0 - 82.224.27.255 > netname: FR-PROXAD-ADSL > descr: Proxad / Free SAS > descr: Static pool (Freebox) > descr: menilmontant-5 (th2) > descr: NCC#2003105812 > country: FR > > (For more see: http://whois.domaintools.com/82.224.27.254) > > So I assume since you said that you are in Europe that you are in France and > this is the ISP you're using. However, the DNS server is located at the > Universite Pierre et Marie Curie: > > inetnum: 134.157.0.0 - 134.157.255.255 > netname: FR-UPMC-NET > descr: Universite Pierre et Marie Curie > descr: Centre de Calcul Recherche > descr: 4 Place Jussieu, 75252 Paris CEDEX 05, France > country: FR > > (For more see: http://whois.domaintools.com/134.157.0.129) > > You are properly getting a public IP address from the ISP but failing on > DNS. Make sure your computer is set to get DNS automatically as described > in my last post to you (and disable IPv6 while you're there). Then flush > your DNS cache by: > > Start Orb>Search box>type: cmd > When cmd appears in Results above, right-click it and choose "Run as > administrator". This will give you an elevated command prompt. At the > command prompt type: > > ipconfig /flushdns [enter] > > Exit the command prompt and try to connect to the Internet. Report back. > > Malke > -- > MS-MVP > Elephant Boy Computers - Don't Panic! > http://www.elephantboycomputers.com/#FAQ > > |
| | #10 (permalink) |
| | Re: Wireless connection works, cable connection does not! Lyautey wrote: Quote: > I think you solved it! I have been able to connect at the BnF (I am indeed > in Paris since I have been teaching in France this past year). Many > thanks! Lyautey Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ |
| Cable connection | Vista General | |||
| Connection problem with cable modem | Network & Sharing | |||
| Using WMC with an antenna and cable connection | Vista General | |||
| Vista Wireless internet connection works sometimes | Vista networking & sharing | |||
| Blackberry Dialup connection interupts wireless connection | Vista networking & sharing | |||
