| | Spooler will not start! I've looked on loads of threads and cannot find a solution to start the print spooler and add my printer. Happened since I upgraded to vista ultimate. When I go cmd>net start spooler I get: The service is not responding to the control function. Then if I go services and click the spooler in the side bar it says: <failed to read description. Error code 1813> If I then go to click 'Start spooler' I get the message: 'Error 1053: The service did not respond to the start or control request in a timely fashion' I'd be very greatful for any advice. Thank you in advance. -- Nick Strouther ------------------------------------------------------------------------ Nick Strouther's Profile: http://forums.techarena.in/members/98930.htm View this thread: http://forums.techarena.in/vista-help/1181284.htm http://forums.techarena.in |
| SPOOLER - | Vista print fax & scan | |||
| Printer Spooler, and sub spooler | Vista print fax & scan | |||
| HOw do I start the print spooler so I can install my print drivers? | Vista installation & setup | |||
| Print Spooler will not start | Vista print fax & scan | |||
