Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Problems with connection
Update your Vista Drivers
Thread Tools Display Modes
Old 10-15-2006   #1 (permalink)
Matt
Guest
I just got Vista RC1 and nothing related to connection the internet seems to
be working including IE, Windows Update, Gagets dealing with the web, and AIM.
Whenver I diagnos the problem I get the error
"www.XXXXX.com is not set up to establish a connection on port "World Wide
Web service (HTTP) with this computer"
Obviously I've checked to see if i have a good connection and I do.
I don't know what else to do.
Old 10-15-2006   #2 (permalink)
Rick Rogers
Guest
Re: Problems with connection
Hi Matt,
You have a Marvell Yukon network adapter? There is a known bug with this nic
and RC1. I found the easiest solution to be to just install XP drivers for
it over the Vista ones. It has been fixed in later builds.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Matt" <Matt@discussions.microsoft.com> wrote in message
news:0FE9423F-BAB8-46EC-A816-DD9CCE7E005E@microsoft.com...
>to
> AIM.
Old 10-15-2006   #3 (permalink)
Jane C
Guest
I keep reading about the problems with the Marvell Yukon, which is the nic I
have. Haven't had any problems at all in any build with it!! x86 and x64.
Vista must like me ;-)
Jane, not plain 64 bit enabled
Batteries not included. Braincell on vacation :-)
"Rick Rogers" <rick@mvps.org> wrote in message
news:uzymy4J8GHA.4408@TK2MSFTNGP02.phx.gbl...
> Hi Matt,
> nic and RC1. I found the easiest solution to be to just install XP drivers
> for it over the Vista ones. It has been fixed in later builds.
> Best of Luck,
>>to
>> AIM.
>> Wide
Old 10-15-2006   #4 (permalink)
Rick Rogers
Guest
It's probably just certain chipsets. It won't matter anyways as it's been
addressed.
Best of Luck,
"Jane C" <jellybean@nospam.xjgarage.org> wrote in message
news:8C97D47B-4D9B-41CD-A575-741CBA4F4684@microsoft.com...
>I have. Haven't had any problems at all in any build with it!! x86 and
>x64. Vista must like me ;-)
>> Hi Matt,
>> drivers for it over the Vista ones. It has been fixed in later builds.
>> Best of Luck,
>>>to
>>> and AIM.
>>> Wide
Old 10-16-2006   #5 (permalink)
John Barnes
Guest
No problem here either but doubt the nic likes me. Good thing too, since my
nVidia nic has the firewall problem and I can't find a way to install it so
I can uninstall it, so Marvell or nothing for me so far. Have you seen any
solution for RC1?
>> Hi Matt,
>> Best of Luck,
>>>to
>>> and AIM.
>>> Wide
Old 10-16-2006   #6 (permalink)
Dennis Pack
Guest
John:
I have the A8N-E NF4 motherboard with only Nvidia NIC and I haven't
had any problems with the Vista installed drivers though build 5744 with x64
or x86. I haven't installed any Nvidia drivers other than the ones on the
Vista disk.
"John Barnes" <jbarnes@email.net> wrote in message
news:u1C5y3W8GHA.4708@TK2MSFTNGP05.phx.gbl...
> my nVidia nic has the firewall problem and I can't find a way to install
> it so I can uninstall it, so Marvell or nothing for me so far. Have you
> seen any solution for RC1?
>>> Hi Matt,
>>> Best of Luck,
>>>>seems to
>>>> and AIM.
>>>> Wide
Old 10-16-2006   #7 (permalink)
John Barnes
Guest
I didn't have problems on x64 or x86, but many did. Not sure why it
randomly happens, but it does. You have certainly seen the postings on the
X64 site.
"Dennis Pack" <dennispack at hotmail dot com> wrote in message
news:9EAA005D-4405-434E-8A89-49F96791942F@microsoft.com...
> John:
> x64 or x86. I haven't installed any Nvidia drivers other than the ones on
> the Vista disk.
>>>nic I have. Haven't had any problems at all in any build with it!! x86
>>>and x64. Vista must like me ;-)
>>>> Hi Matt,
>>>> this nic and RC1. I found the easiest solution to be to just install XP
>>>> Best of Luck,
>>>>>seems to
>>>>> and AIM.
>>>>> Wide
Old 10-16-2006   #8 (permalink)
John Barnes
Guest
Doing a find on the nVidia firewall on x64 I see you even posted 1 of them
news:OBt2EQX8GHA.4620@TK2MSFTNGP02.phx.gbl...
>X64 site.
>> John:
>> haven't had any problems with the Vista installed drivers though build
>> 5744 with x64 or x86. I haven't installed any Nvidia drivers other than
>> the ones on the Vista disk.
>>> since my nVidia nic has the firewall problem and I can't find a way to
>>> install it so I can uninstall it, so Marvell or nothing for me so far.
>>> Have you seen any solution for RC1?
>>>>> Hi Matt,
>>>>> XP drivers for it over the Vista ones. It has been fixed in later
>>>>> builds.
>>>>> Best of Luck,
>>>>>>seems to
>>>>>> and AIM.
>>>>>> Wide
Old 10-16-2006   #9 (permalink)
Dennis Pack
Guest
John:
I agree fully about the Nvidia firewall causing problems with x64.
I'm running Vista RC2 (5744) x64, (NF4 chipset) in device manager it shows
the Nvidia networking controller but the driver is from Microsoft
(6.2.0.116) not Nvidia. On my NF3 tower with Vista RC1 (5600) it also shows
the Nvidia networking controller with Microsoft drivers (6.2.0.121) not
Nvidia. Maybe I haven't had a problem since I didn't install the Nvidia
drivers.
news:OmpE$TX8GHA.3916@TK2MSFTNGP04.phx.gbl...
>>the X64 site.
>>> John:
>>>>>x86 and x64. Vista must like me ;-)
>>>>>> Hi Matt,
>>>>>> builds.
>>>>>> Best of Luck,
>>>>>>>seems to
>>>>>>> web, and AIM.
>>>>>>> "World Wide
Old 10-16-2006   #10 (permalink)
John Barnes
Guest
I haven't seen a Vista driver package from nVidia for the chipset (only the
videocard) and the driver package has the install for the firewall so I can
remove the piece that is blocking my IE32. At least for now I can use the
Marvell
news:548DA555-6256-4413-A30D-F8EF704A7071@microsoft.com...
> John:
> shows the Nvidia networking controller with Microsoft drivers (6.2.0.121)
> not Nvidia. Maybe I haven't had a problem since I didn't install the
> Nvidia drivers.
>> them
>>>the X64 site.
>>>> John:
>>>>>>> Hi Matt,
>>>>>>> builds.
>>>>>>> Best of Luck,
>>>>>>>>seems to
>>>>>>>> web, and AIM.
>>>>>>>> "World Wide
Display Modes
Connection and DNS problems Clare Network & Internet 3 05-21-2008 12:22 AM
Connection Problems Sargeant Rutter Vista networking & sharing 1 04-26-2008 01:26 AM
Connection problems...PLEASE HELP!!! hfbs1234 Network & Internet 3 12-11-2007 11:39 AM
VPN Connection Problems Tim S. Raisbeck Vista General 0 04-11-2007 09:39 PM
IE 7 Connection problems & Windows Mail Connection PB90 Vista General 1 03-09-2007 11:19 AM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
