| | shortcut does not work on desktop Windows Vista Home Premium SP 1 32 bit operating system I right click on the desktop, open the menu and pick new then folder and it works fine. I right click on the desktop, open the menu and pick new then shortcut and nothing happens. I restarted the computer but it is still the same. Help. Please. John |
| | Re: shortcut does not work on desktop I also did a restore to earlier but still the same problem. |
| | Re: shortcut does not work on desktop As a workaround, right click on whatever you are trying to create a shortcut to and select Send To>>Desktop. "thewiz" <jwelles339@xxxxxx> wrote in message news:vofQl.93776$ew.54493@xxxxxx Quote: >I also did a restore to earlier but still the same problem. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: shortcut does not work on desktop Hello theWiz, This may be able to fix the New Shortcut option for you. New Shortcut Fix Hope this helps, Shawn Windows Vista Home Premium SP 1 32 bit operating system I right click on the desktop, open the menu and pick new then folder and it works fine. I right click on the desktop, open the menu and pick new then shortcut and nothing happens. I restarted the computer but it is still the same. Help. Please. John |
| | Re: shortcut does not work on desktop "Bob" <bob@xxxxxx> wrote in news:Oq1Xnl91JHA.1196@xxxxxx: Quote: > As a workaround, right click on whatever you are trying to create a > shortcut to and select Send To>>Desktop. > > "thewiz" <jwelles339@xxxxxx> wrote in message > news:vofQl.93776$ew.54493@xxxxxx Quote: >>I also did a restore to earlier but still the same problem. > > Sorta irritating but I will live. Again, thanks. |
| shortcut on desktop - deleting the word "shortcut" | Vista General | |||
| The shortcut run as administrator does not work? | Vista General | |||
| Shortcut on desktop for a network mapped drive doesnt work | Vista General | |||
| Desktop shortcut to my U: drive does not work | Vista General | |||
| Run as Administrator : via shortcut don't work | Vista account administration | |||
