| | Better way to remove shortcut arrow Hi all, Check out this site. This guy has a really good patch that removes the shortcut arrow without the side effects of deleting the IsShortcut key. It works really well. I'm using RC2. http://www.neowin.net/forum/index.ph...owtopic=499870 -- Paul |
| | Re: Better way to remove shortcut arrow Thanks for your posting. I checked this patch is also good for both x86 and x64 Japanese version. "PaulB" <PaulB@discussions.microsoft.com> wrote in message news:E82E12A3-C4F0-4422-B754-3836390FFEE4@microsoft.com... > Hi all, > Check out this site. This guy has a really good patch that removes the > shortcut arrow without the side effects of deleting the IsShortcut key. It > works really well. > I'm using RC2. > > http://www.neowin.net/forum/index.ph...owtopic=499870 > -- > Paul |
| How do I remove "shortcut" from shortcuts and only have an arrow? | Vista performance & maintenance | |||
| How can I remove shortcut icon arrow overley in vista | Vista file management | |||
| How to remove arrow sign from Shortcut Icons | Vista General | |||
| Remove Shortcut Arrow - Vista | Vista file management | |||
| Shortcut Arrow | Vista General | |||
