Vista - problem uninstalling / deleting files/folders
Old 05-22-2009   #1 (permalink)
KRK
Some time ago I downloaded the 'partypoker' software. I soon uninstalled it.
I seem to have some bits remaining. There are some folders / files on my C:
drive, and the prog is still listed in the control panel /uninstall list. If
I try to run uninstall again I seem to get an install window which I cannot
close without using the taskbar / taskmanager /close application. If I try
to delete the folders directly I get a message 'folder not found - it may be
on an external hard drive or the internet'
Anybody suggest what's going on ?
Thanks
KK
Old 05-22-2009   #2 (permalink)
Vista Bussiness x64 PL
Re: problem uninstalling / deleting files/folders
Quote  Quote: Originally Posted by KRK View Post
Thanks
KK
You have to notice whats programs which you already tried uninstall still exist in Unistall list and visit websites for every problamatic programs how to remove them manually.Many programs are very difficult to remove.You can also try any commercial uninstaller program.
Uninstall list in these keys:
HKLM\Software\Microsoft\Windows\CurrentVerison\Uninstall
and for x64 systems only
HKLM\Software\WOW6432Node\Microsoft\Windows\CurrentVerison\Uninstall
Old 05-22-2009   #3 (permalink)
Ǝиçεl
RE: problem uninstalling / deleting files/folders
Hello KRK,
Tяy this program: <http://www.revouninstaller.com/>
Download and install CCleaner.
You can use it to take anything out of that list that you don't want.
Ǝиçεl
> Thanks
> KK
Old 05-22-2009   #4 (permalink)
silver hair
hi
I use > Revo Uninstaller < a lot, it has many options including search for
Junk files, before deleting look closely true the list
and its Free
lucky me I guess
> Thanks
> KK
Deleting Folders/Files in Temp File? Vista General
Problem Deleting Files Vista General
Another Deleting Files Problem... Vista account administration
Deleting uninstalled files and folders Vista General
Deleting folders and files Vista General
Designer Media Ltd
