Vista - System tray
Old 05-23-2009   #1 (permalink)
Ghost
System tray
I used to have the icon in system try which looked like a bunch of bars that
when right click on I could connect wireless to the internet which then
would change to 2 computer monitors. It's gone since upgrading something and
I want it back. I think it's still there when logged in as ADMIN but not
other account. How do I fix this/
Add to System Tray General Discussion
Solved system tray General Discussion
Minimise to system tray? Live Mail
Re: NIC icon is system tray Vista General
Minimise to system tray? Vista General
