| | FTP timestamp and offset Problem I'm trying to resolve an issue with FTP folders displaying the wrong timestamp on newly created folders/files on the FTP server. It displays an incorrect time which isn't even the GMT time. I'm in Hawaii and it shows up with -20 hours offset. Any ideas? When I look at the properties of the file its accurate. Thanks! |
| | Re: FTP timestamp and offset Problem Is there any time zone setting problems on the server? If you can reach the server, would you like to check the setting in the control panel and see whether it is the right local time in GMT format? "Jason" <Jason@xxxxxx> wrote in message news:F49BC257-1580-4F70-9976-463EB846F6D1@xxxxxx Quote: > I'm trying to resolve an issue with FTP folders displaying the wrong > timestamp on newly created folders/files on the FTP server. It displays > an > incorrect time which isn't even the GMT time. I'm in Hawaii and it shows > up > with -20 hours offset. Any ideas? When I look at the properties of the > file > its accurate. > > Thanks! |
| | Re: FTP timestamp and offset Problem On Tue, 26 May 2009 15:49:02 -0700, Jason <Jason@xxxxxx> wrote: Quote: >I'm trying to resolve an issue with FTP folders displaying the wrong >timestamp on newly created folders/files on the FTP server. It displays an >incorrect time which isn't even the GMT time. I'm in Hawaii and it shows up >with -20 hours offset. Any ideas? When I look at the properties of the file >its accurate. > >Thanks! where you are? |
Menus are offset in certain programs | General Discussion | |||
| Timestamp question | General Discussion | |||
| DNS timestamp conversion | VB Script | |||
| Accessing Multipage TIFF file via byte offset in .NET? | .NET General | |||
| Information from Exception Offset | Vista General | |||
