Vista - unable to create system restore point
Old 05-30-2009   #1 (permalink)
vista ultimate x64
when i tried to create a restore point an error message is being displayed. it says
" could not create the scheduled task for the following reason task image is corrupt or has been tampered with (0x80041321)"
what does it mean and pls help me with this
i am running on vista ultimate x64
pc config
dual core 2.8(intel)
intel 965board
80gb hdd
what i did was under system properties page, i clicked system protection tab on the left side checked the boxes( all system drives ie hard disk drives) and clicked apply then the message i described was popping out and when clicked create also the same message is being displayed
am also using registry mechanic
Old 05-30-2009   #2 (permalink)
Tony UK
RE: unable to create system restore point
Although I don't have an answer that refers to the specific error message, I
have found that in Vista and in XP, System restore is often blocked by an
installed antivirus application, such as Norton. If you disable the a/v
application and run S/R again, it will then work. This may not be what is
affecting you but on the other hand, perhaps it is.
"playboycensored" wrote:
> displayed. it says
> pc config
> intel 965board
> 80gb hdd
> displayed
> playboycensored
Old 05-30-2009   #3 (permalink)
VISTA HOME PREMIUM X64/ 7 x64 / 7x86
Re: unable to create system restore point
You might see if the solution posted here is of use:
Task image corrupt?? System restore
Hope it helps
SIW2
Quote:
playboycensored
pc config
intel 965board
80gb hdd
Old 05-31-2009   #4 (permalink)
Bob
Try System restore in Safe Mode.
>> displayed. it says
>> pc config
>> intel 965board
>> 80gb hdd
>> displayed
>> playboycensored
Old 05-31-2009   #5 (permalink)
Vista Home Premium 32bit
Vista Backup error puzzle
Check if task is corrupted
At a command prompt type : schtasks/query | findstr/i "replace with name of task example above would be Reminders"
(Mind the spaces)
Look for
ERROR: The task image is corrupt or has been tampered with.
ERROR: Task cannot be loaded: Reminders (task name)
If the above is true delete the task at the following location and recreate: (you should notice a file with the affected schedule task at this location) c:\Windows\System32\Tasks
If that does not help you have to delete in the registry the "Task Name"
Open regedit
- find it in the path:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tasks\
-and in
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Schedule\TaskCache\Tree\
- delete them
Not neccesary to say that you should have a valid sytem restore point or backup the registry before altering the registry.
(see the ref forum for details)
Quote  Quote: Originally Posted by Bob View Post
>> displayed. it says
>> pc config
>> intel 965board
>> 80gb hdd
>> displayed
>> playboycensored
Unable to Create Restore Point General Discussion
System Restore error (create restore point), event ID: 8193 Vista General
System Restore Point - create Tutorials
Couldn't create a system restore point in Vista General Discussion
Unable to create Restore Point-different error message Vista performance & maintenance
