| | Shrink volume & create new partition using disk management console Vista Home Premium, x86, SP2, 160GB HDD, HP6375US laptop I downloaded Windows 7 RC1 with the intent of adding a partition to my HDD and dual booting. My understanding is that I would need a 16GB partition. My Disk Management Console tells me I have two existing primary partitions (expected). D (the recovery partition) is 6.62GB. The other (C) makes up the difference (~142GB) and has 47.1GB free space. When I begin the "shrink volume" process, it says that only 3MB is available to shrink C. I checked the page file and it has less than 3GB allocated to it. So, I have two questions. First, why isn't more shrinkage ;>) space available? Two, assuming that with your help I can find more space, if I try to create a 16GB partition from C will I significantly affect computer performance? |
| | Re: Shrink volume & create new partition using disk management console rak wrote: Quote: > Vista Home Premium, x86, SP2, 160GB HDD, HP6375US laptop > > I downloaded Windows 7 RC1 with the intent of adding a partition to my > HDD and dual booting. My understanding is that I would need a 16GB > partition. My Disk Management Console tells me I have two existing > primary partitions (expected). D (the recovery partition) is 6.62GB. > The other (C) makes up the difference (~142GB) and has 47.1GB free space. > > When I begin the "shrink volume" process, it says that only 3MB is > available to shrink C. I checked the page file and it has less than 3GB > allocated to it. So, I have two questions. First, why isn't more > shrinkage ;>) space available? Two, assuming that with your help I can > find more space, if I try to create a 16GB partition from C will I > significantly affect computer performance? the disk shrink of vista is so basic that its useless... First they make an OS that bloats the disk with crap, then they make a half baked shrinkage tool... what a disgrace vista is.... You need to either defragment your drive with a defragmenter that will move everything towards the beginning of your disk (the build in one of vista doesnt do sht) or you must use a real partitioning software like paragon partition manager |
| | Re: Shrink volume & create new partition using disk management console On Tue, 2 Jun 2009 14:12:17 -0400, "rak" <rakess@xxxxxx> wrote: Quote: >Vista Home Premium, x86, SP2, 160GB HDD, HP6375US laptop > >I downloaded Windows 7 RC1 with the intent of adding a partition to my HDD >and dual booting. My understanding is that I would need a 16GB partition. >My Disk Management Console tells me I have two existing primary partitions >(expected). D (the recovery partition) is 6.62GB. The other (C) makes up >the difference (~142GB) and has 47.1GB free space. > >When I begin the "shrink volume" process, it says that only 3MB is available >to shrink C. I checked the page file and it has less than 3GB allocated to >it. So, I have two questions. First, why isn't more shrinkage ;>) space >available? Two, assuming that with your help I can find more space, if I >try to create a 16GB partition from C will I significantly affect computer >performance? You will no doubt need a third-party partition manager. Vista's disk manager will only let you shrink until it runs into a file on your drive that it can't move. Try EASEUS partition manger. It's free. Google it. |
| | Re: Shrink volume & create new partition using disk management console "rak" <rakess@xxxxxx> wrote in message news:smeVl.109604$uD3.101396@xxxxxx Quote: > Vista Home Premium, x86, SP2, 160GB HDD, HP6375US laptop > > I downloaded Windows 7 RC1 with the intent of adding a partition to my HDD > and dual booting. My understanding is that I would need a 16GB partition. > My Disk Management Console tells me I have two existing primary partitions > (expected). D (the recovery partition) is 6.62GB. The other (C) makes up > the difference (~142GB) and has 47.1GB free space. > > When I begin the "shrink volume" process, it says that only 3MB is > available to shrink C. I checked the page file and it has less than 3GB > allocated to it. So, I have two questions. First, why isn't more > shrinkage ;>) space available? Two, assuming that with your help I can > find more space, if I try to create a 16GB partition from C will I > significantly affect computer performance? System recovery is where many brand name manufactures (including HP) store data to restore Windows Vista to factory condition. |
| Disk Management - Shrink Partition | Tutorials | |||
Disk Management - Shrink Partition in Vista | General Discussion | |||
| Disk Management - Shrink volume | Vista file management | |||
| Disk Management - Shrink volume | Vista General | |||
| Disk Management - Shrink volume | Vista performance & maintenance | |||
