Vista - System Mechanic!!!!!!!! Works!!!!!
Old 10-18-2006   #1 (permalink)
Altimax98
Hey guys a new discovery, System mechanic WILL work on Vista 64. You have to
beat around the bush tho. If you want it do this: DONT use the normal
install, aka. Autorun.. It wont work instead go to the CD right click go to
explore. Once inside click the SystemMechanicPro (if you have pro most likely
works on standard too) Not the Install icon. Then make sure your connected to
the internet, and let it work. Any windows about "(Whatever the name was for
the company) Has known compatibility issues", click Run Program anyway, then
complete the install. It works fine for me, the only problem so far is the
System Customizer tab, it can use all of its features cause of differance
from XP. Anyway Let me know if you do this and what the result was. Thanks:
ALTI
Im pretty Smart with computers but I even need help sometimes. Thats why im
here.
Old 11-16-2008   #2 (permalink)
Vista x64
Re: System Mechanic!!!!!!!! Works!!!!!
I tried this. I cannot get past the Error window that reads, "System Mechanic Pro is not compatible with 64-bit operating systems at this time." It only has an "OK" button to click. There is no "Install anyway" button. Any ideas?
Old 12-08-2008   #3 (permalink)
Vista Home Premium 64bit
Iolo have just launched System Mechanic 8.5 which is 64 bit compatible. I've just downloaded it and can confirm that it works.
software program like System Mechanic 7 Software
System Mechanic 6 Vista General
System Mechanic Software
System Mechanic Vista General
System Mechanic 7.0 Pro incompatible Vista General
