| | Running software as an Administrator I have a software program in which I want to save certain data files with a different name. When I use Save As, the software will not permit me to save the file, because it tells me that I need "administrator privileges." I am the sole user of my computer, running on a Vista 32-bit platform. When I right-click the desktop icon in question in order to use Run as Administrator, the option does not appear in the drop-down list, as it does for other software programs that I use. Is there a way for me to get around this (i.e., to run the software as an administrator)? I know how to do this in Windows 2000, but I am still on a learning curve in Vista. Gordon Biggar |
| | Re: Running software as an Administrator Gordon Biggar wrote: Quote: > I have a software program in which I want to save certain data files > with a different name. When I use Save As, the software will not permit > me to save the file, because it tells me that I need "administrator > privileges." > > I am the sole user of my computer, running on a Vista 32-bit platform. > When I right-click the desktop icon in question in order to use Run as > Administrator, the option does not appear in the drop-down list, as it > does for other software programs that I use. Is there a way for me to > get around this (i.e., to run the software as an administrator)? I know > how to do this in Windows 2000, but I am still on a learning curve in > Vista. > > Gordon Biggar which you should have the authority to save to Gordon. Vista is not going to let you save files to a directory it deems protected, like c:\program files. |
| | Re: Running software as an Administrator The software error message suggests this route, but as I noted in the reply to RalfG, I have had no problem in running this software (and saving files) on my Vista 64-bit platform. I also ran this program without incident on this laptop (Vista 32-bit) prior to a drive crash, which is why this error message has me confused. I may have to go the route of setting up another folder (not under Program Files), but it seems awkward. Thanks for your input! Gordon "Planters" <Dry@xxxxxx> wrote in message news:OalLka35JHA.1196@xxxxxx Quote: > Gordon Biggar wrote: Quote: >> I have a software program in which I want to save certain data files with >> a different name. When I use Save As, the software will not permit me to >> save the file, because it tells me that I need "administrator >> privileges." >> >> I am the sole user of my computer, running on a Vista 32-bit platform. >> When I right-click the desktop icon in question in order to use Run as >> Administrator, the option does not appear in the drop-down list, as it >> does for other software programs that I use. Is there a way for me to >> get around this (i.e., to run the software as an administrator)? I know >> how to do this in Windows 2000, but I am still on a learning curve in >> Vista. >> >> Gordon Biggar > You should create a folder on C: called Gordon and save the files there, > which you should have the authority to save to Gordon. Vista is not going > to let you save files to a directory it deems protected, like c:\program > files. > |
| Help with administrator program running thing? | Vista account administration | |||
| Cannot debug with running VS2005 as administrator | Vista security | |||
| Running as Administrator | Vista General | |||
| bluescreen crash while running my App with Run as Administrator | Vista General | |||
| Running an HTA or WSH script as administrator | Vista security | |||
