Blue Screen (BSoD) Help/Advice
  1. #1
    _chris Guest
    Hi, I'm new to this forum and basically I joined because I'm at my wit's
    end with a Blue Screen (BSoD) problem.
    I'm using Windows Vista on a Fujitsu Siemens Esprimo Mobile laptop.
    I have not yet discovered what causes the Blue Screen to appear but I
    have to switch of the laptop everytime it happens.
    Error codes from BSoD message are displayed as:
    TECHNICAL INFORMATION:
    *** STOP: 0X0000008E (0XC0000005, 0XA525F2F8, 0XAAFC7895,
    0X00000000)
    Any help or advice on what is causing this and how to stop it will be
    greatly appreciated.
    Thanks, Chris
    _chris
    _chris's Profile: http://forums.techarena.in/members/106403.htm
    View this thread: http://forums.techarena.in/vista-help/1198697.htm
  2. #2
    R. C. White Guest
    Re: Blue Screen (BSoD) Help/Advice
    Hi, Chris.
    R. C. White, CPA
    San Marcos, TX
    rc@xxxxxx
    Microsoft Windows MVP
    Windows Live Mail 2009 (14.0.8064.0206) in Win7 Ultimate x64 RC 7100
    My favorite place to start researching Stop Code errors is AumHa:
    TROUBLESHOOTING WINDOWS STOP MESSAGES
    http://aumha.org/a/stop.htm
    Or paste the Stop Code into your favorite search engine. Microsoft's new
    Bing get 34,200 hits. Check out some of those and then post back with some
    more relevant details.
    That code, KERNEL_MODE_EXCEPTION_NOT_HANDLED, almost always points to
    hardware problems, not software, and the first parameter, 0XC0000005, points
    to memory, so you might start there.
    RC
    R. C. White, CPA
    San Marcos, TX
    rc@xxxxxx
    "_chris" <chris.3tw6za@xxxxxx> wrote in message
    news:chris.3tw6za@xxxxxx
    > 0X00000000)
    > Thanks, Chris
  3. #3
    Jon Guest
    > 0X00000000)
    The 0X0000008E corresponds to the following error
    Bug Check 0x8E: KERNEL_MODE_EXCEPTION_NOT_HANDLED
    http://msdn.microsoft.com/en-us/library/ms794023.aspx
    and the 0XC0000005 to a memory access violation (same article).
    Which roughly translated means you have a dodgy driver for some device or
    program. The particular driver may be indicated along with the error message
    (they usually end in .sys and often appear on the same blue screen). Once
    you know the guilty driver, the issue generally becomes easier to resolve.
    Jon
  4. #4
    DL Guest
    Generally means a hardware / driver error
    If you boot into Safe Mode do you still get the bsod?
    > 0X00000000)
    > Thanks, Chris
    > _chris
Blue Screen (BSoD) Help/Advice problems?
Vista 64 BSOD (Blue Screen Of Death). Do I need to re-install? Calamity Cruse Drivers 4 08 Oct 2010
Blue Screen (BSOD) after Windows Updates srhaskin9 Windows Updates 4 11 Oct 2009
Vista Blue Screen Of Death (BSOD) Gingbeard Crashes and Debugging 2 02 Sep 2009
blue screen of death -BSOD problem ssur Crashes and Debugging 17 23 May 2009
Vista keeps BSOD all the time - Blue screen - any ideas? BertieBigBollox Vista General 21 30 Apr 2009
