1.    16 Jun 2009 #1
    Jimmy Hsu Guest
    No sound from my PC
    My Desktop PC was working fine yesterday, but today there is no sound at all
    from the speakers. I opened Device Manager and found everything normal:
    there was no yellow questions marks beside the Sound item. The speaker
    cables are also firmly connected to the PC.
    I've ran AVG, SpyBot & Malwarebyte's Anti-Malware to scan for virus, etc,
    but found none.
    Please help. I have a HP-Pavilion KT393AA desktop, with 2.5 g
    Intel Core2 Quad Q9300 , 3.3 g RAM, Realtek HIgh Defintion Audio, running
    Vista Home Premium SP 1
  2.    16 Jun 2009 #2
    Richard in AZ Guest
    Re: No sound from my PC
    "Jimmy Hsu" <jimmyhsu@xxxxxx> wrote in message news:OwsBffv7JHA.356@xxxxxx
    > but found none.
    What are your speaker volume settings?
  3.    17 Jun 2009 #3
    Ken Blake, MVP Guest
    On Wed, 17 Jun 2009 11:00:32 +0800, "Jimmy Hsu"
    Check the following:
    1. The speakers are plugged in and the outlet they are plugged into is
    live.
    2. The physical speaker volume control is not turned down.
    3. The Windows speaker volume control is not turned down, nor is it
    muted.
    If all the above are OK, the speakers may have physically died. Try
    them on another computer to be sure.
    Ken Blake, Microsoft MVP - Windows Desktop Experience
    Please Reply to the Newsgroup
  4.    17 Jun 2009 #4
    Jimmy Hsu Guest
    Speaker volumes, physical and Windows Vol. Ctrl are all set at mid way, not
    muted.
    "Ken Blake, MVP" <kblake@xxxxxx> wrote in message
    news:u41i35t28ji6b2hg48l6vj8akfuqo1vrc2@xxxxxx
    >> all
    > live.
    > muted.
  5.    17 Jun 2009 #5
    Manny Weisbord Guest
    >muted.
    Plug a set of earphones into the speaker jack... do you hear sound?
    >>> all
    >> live.
    >> muted.
  6.    17 Jun 2009 #6
    Peter Foldes Guest
    Jimmy
    Many posts lately about this same issue. You are infected with malware. Suggest
    running Malwarebytes and SuperAntiSpyware along with your resident AV.
    Post back and let us know
    Peter
    Please Reply to Newsgroup for the benefit of others
    Requests for assistance by email can not and will not be acknowledged.
    > My Desktop PC was working fine yesterday, but today there is no sound at all from
    > the speakers. I opened Device Manager and found everything normal: there was no
    > yellow questions marks beside the Sound item. The speaker cables are also firmly
    > I've ran AVG, SpyBot & Malwarebyte's Anti-Malware to scan for virus, etc, but
    > found none.
    > Please help. I have a HP-Pavilion KT393AA desktop, with 2.5 g Intel
    > Core2 Quad Q9300 , 3.3 g RAM, Realtek HIgh Defintion Audio, running Vista Home
    > Premium SP 1
  7.    17 Jun 2009 #7
    Tae Song Guest
    > all from the speakers. I opened Device Manager and found everything
    > normal: there was no yellow questions marks beside the Sound item. The
    > speaker cables are also firmly connected to the PC.
    > but found none.
    You could try reinstalling or updating the audio driver. Some Windows
    Update is causing audio to stop for some reason for some people.
  8.    17 Jun 2009 #8
    Jimmy Hsu Guest
    As you suggested, I plugged a set of earphones into speaker jack, and yes,
    I do hear sound BUT it is very soft. It is still very soft after I turn
    up all the volume settings to Max.
    I have reinstalled the Realtek Audio drivers, but the problem remains.
    Thks
    "Manny Weisbord" <mannyweisbord@xxxxxx> wrote in message
    news:m59i35pterlhiro4sjs8mnvo56a10vseal@xxxxxx
    >>not
    >>muted.
    >>>> at
    >>>> all
    >>>> normal:
    >>> live.
    >>> muted.
  9.    17 Jun 2009 #9
    >Thks
    Obviously your system is producing SOME level of sound. I believe you
    stated that your speakers are powered. It's conceivable that they've
    failed.
    Where are you getting those Realtek drivers from? Do you have
    automatic update enabled so that it installs items when they're found?
    If you're not getting the sound drivers from the computer
    manufacturer's site, you should go there and get them. If you have
    the correct drivers, then the speakers are suspect.
    >>>not
    >>>muted.
  10.    18 Jun 2009 #10
    Tae Song Guest
    news:E15D97B3-0C2A-4672-AE51-0D69653655BC@xxxxxx
    > yes, I do hear sound BUT it is very soft. It is still very soft after
    > I turn up all the volume settings to Max.
    > Thks
    >>>not
    >>>muted.
    >>>>> at
    >>>>> all
    >>>>> normal:
    >>>>> speaker
    >>>> live.
    >>>> muted.
    Did you perhaps set the default playback device to Realtek Digital Output?
    Check to see if the default playback device is set to Speakers.
Page 1 of 2 12 LastLast
distorted sound in vista/createiv x-fi titanium sound card
It isn't always there...it comes and goes, but it's pretty ugly. I thought it might be a sample rate thing, but I changed those settings in control...
Sound & Audio
No sound when playing music or video, but internet sound works fine
Each time I try to play a song or video in wmp, itunes, VLC media player, InterVideo, etc. I get absolutely no sound. Videos play, I can see the...
Sound & Audio
Sound Problems - Vent, Xfire, Steam voice - no sound
I can hear sound in almost every program perfectly, exept for ventrilo, xfire speak, and steam voice. these ones i can talk but i cant hear...
Vista hardware & devices
Setting per Application Sound Output, or Per Sound Type Outputs...
OK folks. Fresh to the meat grinder, I installed Vista. Little did I know the torment that would ensue. I thought people were exaggerating when they...
Vista General
How to record sound clips or music using the sound recorder?
In XP i use to record sound clip using the sound recorder by modifying the sound control setting in XP. I forgot to do this in XP and now trying to...
Vista music pictures video
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound!
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Kevin John Panzke P.S. I am Running...
Vista General
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF)
Hi, What is required for the DTS Test sound you can send through the SPDIF Settings to be decoded my my Surround Receiver/Amplifier? It...
Vista General
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
