| Vista Home Premium 32bit | Rename folders in left pane using double click? I cannot rename folders in the left pane using a slow double click ... My double click speed works fine in the right pane and I have no problem renaming there. I can't get this to work in Vista. Can anyone help please? |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: Rename folders in left pane using double click? Hello Sjmnbritz, You could right click on the folder and click on "Rename" instead. Hope this helps, Shawn |
| | Re: Rename folders in left pane using double click? You may need to change the double-click speed threshold for your mouse. Control Panel\Hardware and Sound Mouse Icon Buttons tab *** "sjmnbritz" <guest@xxxxxx-email.com> wrote in message news:616866960235d5de796115bd6dc914bb@xxxxxx-gateway.com... Quote: > > I cannot rename folders in the left pane using a slow double click ... > My double click speed works fine in the right pane and I have no > problem renaming there. > I can't get this to work in Vista. Can anyone help please? > > > -- > sjmnbritz |
| Contacts in left pane under local folders | Vista mail | |||
| Single click to expand folder tree in left pane Vista | General Discussion | |||
| Only "Inbox" appears under local folders on left hand side pane | Vista mail | |||
| windows explorer - How to stop folders pane shifting to the left? | Vista General | |||
| hot to change mouse to single click instead of double click to ope | Vista hardware & devices | |||
