Vista - Error 0xC004D401 (Activation) Plase Help
Old 10-19-2006   #1 (permalink)
psassaki
Every time appears the mensage
"There is a problem with your license so notifications will no longer appear"
You will no longer recive notifications, including those about your license
or activation.
Try to fix this problem, click one of the links below.
Error: 0xC004D401
Description:
The security processor reported a system file mismatch error.
I tried to validate, but every time appear "Error on Windows validation"
Unricognized error.
I tried to change my key but when i do it, appear one new window caled
"Invalid product key"
Code: 0xC004F033
Description: The Software Licensing Service reported that the product key is
not allowed to be installed. Please see the eventlog for details.
I've the original key ...
I don't know what i have to do now to stop it, can you help me ?
Thank you.
Old 10-20-2006   #2 (permalink)
Nir MSFT
RE: Error 0xC004D401 (Activation) Plase Help
Hello
The Vista team will be happy to help you troubleshoot this issue
We have seen some related issues for Vista machines that have Spyware Doctor
4.0 installed - if you have this software installed, try uninstalling and see
if it helps
If not, you can either let me know your email address so that I can contact
you or file a service request (free of charge) on the WGA hotline
at: http://support.microsoft.com/oas/def...&gprid=9860&;; and
let me know what the service request number is
I hope that we can help resolve the issue
Regards
Nir
> or activation.
> Error: 0xC004D401
> Description:
> Unricognized error.
> Code: 0xC004F033
> Thank you.
Old 10-20-2006   #3 (permalink)
psassaki
Thank You
"Nir MSFT" wrote:
> Hello
> if it helps
> Regards
> Nir
Yeah !
Thanks, my problem was solved.
Thank you
Old 10-24-2006   #4 (permalink)
eeter
"Nir MSFT" wrote:
> Hello
> if it helps
> Regards
> Nir
> > or activation.
> > Error: 0xC004D401
> > Description:
> > Unricognized error.
> > Code: 0xC004F033
> > Thank you.
Old 10-27-2006   #5 (permalink)
G.J Smith
Put me on the list I have the same recurring problem
GJS
"eeter" wrote:
> "Nir MSFT" wrote:
> > Hello
> > if it helps
> > Regards
> > Nir
> > > or activation.
> > > Error: 0xC004D401
> > > Description:
> > > Unricognized error.
> > > Code: 0xC004F033
> > > Thank you.
Old 03-20-2007   #6 (permalink)
Gamato
Dear Nir,
I got the same problem here and I had followed your suggestion to uninstall
the software but nothing changed. So I followed your other suggestion to get
the support request number, which in my case it is SRZ070320000614.
Please get me out of this problem soon, would u?
Thanks.
Best regard,
Gamato
"Nir MSFT" wrote:
> Hello
> if it helps
> Regards
> Nir
> > or activation.
> > Error: 0xC004D401
> > Description:
> > Unricognized error.
> > Code: 0xC004F033
> > Thank you.
Old 04-02-2007   #7 (permalink)
Mr Fu
Im having the same problem with the: Error 0xC004D401 and i think the cause
of it is the installation of an uncompatible game. I want to uninstall that
game but it won't let me open the control panel or programs and features. I
don't know what to do! Can someone help me? Also can u make ur replies as
simple as possible? im not quite sure what you guys are talking about. Im
only 12
~Thanks
"Gamato" wrote:
> Dear Nir,
> Thanks.
> Best regard,
> Gamato
> "Nir MSFT" wrote:
> > Hello
> > if it helps
> > Regards
> > Nir
> > > or activation.
> > > Error: 0xC004D401
> > > Description:
> > > Unricognized error.
> > > Code: 0xC004F033
> > > Thank you.
Old 04-04-2007   #8 (permalink)
Gamato
Yeah, at that time I also could not access the control panel directly from
the start button. Why dont u go to my computer first, then from the left side
window at the bottom, u click on control panel. It worked for me back then...
And after u uninstall the program that u think has compatibility issues, u go
online and try to validate again. If it still does not work, go to this
website and follow the instructions until u get the transaction code. After a
few days (three at the most), someone from the microsoft side will assist u
to solve your problem. Hope this will work for u, cause it works for me...
GBU
> only 12
> ~Thanks
> "Gamato" wrote:
> > Dear Nir,
> > Thanks.
> > Best regard,
> > Gamato
> > "Nir MSFT" wrote:
> > > Hello
> > > if it helps
> > > Regards
> > > Nir
> > > > or activation.
> > > > Error: 0xC004D401
> > > > Description:
> > > > Unricognized error.
> > > > Code: 0xC004F033
> > > > Thank you.
Trying to install vista and getting blue error screen plase help! Vista installation & setup
Error 0xC004D401 (Activation) Vista General
Error 0xC004D401 Vista installation & setup
Error 0xC004D401 (Windows Vista Activation) Vista General
Error code 0xC004D401 License Activation Vista General
