| | Re: Studying abroad, devastating weird laptop problem Hmm... http://treehouse.ofb.net/go/en/voltage/China if it gets hot maybe there's a voltage problem, I dunno about sizes but this plug design looks like US 115V. I don;t necessarily agree 100% with the text on this site BTW. Rick Rogers wrote: Quote: > Hi, > > Sounds more like you were hacked as soon as you went online. The > easiest/shortest resolution is to format and reinstall. Alternately, you > can spend time, hours or days, poking through the startup axis with > tools like malwarebytes and autoruns to detect and remove malevolent > entries. > |
| | Re: Studying abroad, devastating weird laptop problem Hi, I think both Rick Rogers and Charlie Tame could be right. However, I would suggest you to stop the troubleshooting process at this point, and I found the following address from Gateway, USA by clicking "China" on their main page: http://cn.gateway.com/ You may want to have a local friend translate the page for you, and all you want is a local support phone number. PS: As pointed out by Charlie Tame, you may also want to ask your local friends about voltage converter (which may not be required by newer models) and plug adapters (as far as I can remember - very confusing). Hope this helps and good luck. "popular" <brenden.cline@xxxxxx> wrote in message news:38e0d86fd227861645d313c0351a4495@xxxxxx-gateway.com... Quote: > > I'm studying abroad in China and my laptop has a really weird problem, > so I apologize in advance but this is a bit long. > > I moved in with a host family last week, and 5 minutes after getting > the internet to work and beginning to Skype chat people (without video) > my computer (Gateway laptop model MT3423 I think, Vista Premium, Dual > Core AMD Turion, ~2 years old in good condition) froze and hasn't been > the same since. Now, booting brings me to the recovery screen (of course > - Normal Mode, Safe Mode with Networking, etc.), but no Safe Mode works > - I can get to the login screen but after signing in the Welcome screen > with the loading circle stays up indefinitely. Normal Mode works though, > but it has major issues. After successfully signing in programs begin to > load but it quickly slows down to a crawl, and takes about a minute to > close the two program warning boxes that pop up (just the usual 'this > program is unregistered' sort of thing). After this, Windows Calendar > inexplicably loads, again painfully slow, and if the computer hasn't > crashed by this point then it does shortly thereafter. And the crash > varies - a few times it started with a "Server Busy - this action cannot > be completed" error message but it usually says euphemistically > "Microsoft Windows - this application is not responding." > > I've tried several things but I haven't had any success. During this > loading window, I've tried running msconfig and unchecking nonessential > programs, but even after clicking Save Changes and Restart the changes > are not saved, and it'll still proceed to crash and load the programs > again next boot. I've tried loading the control panel, but it becomes > unresponsive after I try to click anything in it. I tried opening > accessories under the Start Menu and it bugged out, and instead of > showing the folder icon it showed a searching icon and wouldn't open. > The Command Prompt loaded but was too slow to execute anything. I also > tried opening Task Manager, even through Ctrl+Alt+Delete, and after a > few minutes it successfully loaded once but didn't show anything unusual > and then crashed. > > I'm not sure what the problem is - the only things I can think of are > that I had just setup 3 identical automatic broadband internet > connections as I was troubleshooting the connection, the room was really > hot (about 90 degrees F), and I had an SD memory stick in when I booted > up the last few times before this. Also, I installed a Logitech Quickcam > a few weeks before (whose software loads in the tray automatically) and > one of the 2 popups that load is new, bugging me about registering > EarthDesk. It seem to me like any of this should cause my problem, but > it seems to me that it's a software problem, in part because I don't > have any real evidence of hardware failure (although it does get really > hot, but the fan is still working) and because while Windows will be > crashing and I can't use the Start Menu, I can still hover over programs > in the tray and have their name popup (but the battery status and volume > control won't). > > Anyone have any advice/input? I'm going to try to get a copy of the > recovery CD, but that'll take at least a week and there are no > authorized Gateway repair centers in China, not to mention the language > barrier and risk involved, especially if I don't know what's wrong... > Thanks a lot everyone! > > > -- > popular |
| | Re: Studying abroad, devastating weird laptop problem Definitely looks like you've been got at. I am assuming you are okay with voltage as this would cause different problems. (All this applies when on battery too, yes)? A clean install seems your only option. Get it right first time and it should only take a couple of hours. Hunting for malware etc could take days. Two things... 1: I suggest disabling Autorun. Any viruses etc are often self loading and Autorun does the job for them. 2: So you don't have to go hunting on your slow machine, I have copied the instructions here. Good luck Ed Perform a clean installation There are two ways to perform a clean installation of Windows Vista. The first method is to install Windows Vista by running the Setup program from the current version of Windows on your computer. The second method is to start the computer from the Windows Vista DVD. First, try method 1. If it does not work, try method 2. Warning In a clean installation, existing data on your computer is deleted. This data includes personal data, settings, hardware driver information, and software programs. After you install the operating system, you must also reinstall all programs. Make sure that you back up personal data to disks or other external storage devices before you perform a clean installation. Method 1: Perform a clean installation of Windows Vista by running Setup from the current version of Windows To perform a clean installation of Windows Vista from the current version of Windows on the computer, follow these steps: 1.. Start the computer and make sure that the current version of Windows has started. 2.. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. Wait a moment for the Setup program to start automatically. 3.. If the Setup program does not start automatically, follow these steps: 1.. Click Start and then click Run. 2.. Type Drive:\setup.exe and then click OK. Note Drive is the drive letter of the computer's DVD drive. 4.. When the Setup program starts and the Install now screen appears, click Install now. 5.. When the Which type of installation do you want? screen appears, click Custom (advanced). The follow the instructions to install Windows Vista. If Windows Vista is now running on your computer, you have completed the installation successfully. If the installation does not finish or you receive an error message, and you are comfortable trying to troubleshoot the problem, go to the "Troubleshooting" section for more information about common issues and their resolutions. If you are not comfortable trying to troubleshoot the issue, go to the "Next Steps" section. Method 2: Perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD Note The computer must be configured to start from the DVD drive. For information about how to configure the computer to start from the DVD drive, see the documentation that is included with the computer. Or, contact the computer manufacturer. To perform a clean installation of Windows Vista by starting the computer from the Windows Vista DVD, follow these steps: 1.. Start the computer. 2.. Insert the Windows Vista DVD into the DVD drive and then close the drive tray. 3.. Restart the computer. 4.. When you receive the "Press any key to boot from CD" message, press a key. 5.. Follow the instructions to install Windows Vista. If Windows Vista is now running on your computer, you have completed the installation successfully. "popular" <brenden.cline@xxxxxx> wrote in message news:38e0d86fd227861645d313c0351a4495@xxxxxx-gateway.com... Quote: > > I'm studying abroad in China and my laptop has a really weird problem, > so I apologize in advance but this is a bit long. > > I moved in with a host family last week, and 5 minutes after getting > the internet to work and beginning to Skype chat people (without video) > my computer (Gateway laptop model MT3423 I think, Vista Premium, Dual > Core AMD Turion, ~2 years old in good condition) froze and hasn't been > the same since. Now, booting brings me to the recovery screen (of course > - Normal Mode, Safe Mode with Networking, etc.), but no Safe Mode works > - I can get to the login screen but after signing in the Welcome screen > with the loading circle stays up indefinitely. Normal Mode works though, > but it has major issues. After successfully signing in programs begin to > load but it quickly slows down to a crawl, and takes about a minute to > close the two program warning boxes that pop up (just the usual 'this > program is unregistered' sort of thing). After this, Windows Calendar > inexplicably loads, again painfully slow, and if the computer hasn't > crashed by this point then it does shortly thereafter. And the crash > varies - a few times it started with a "Server Busy - this action cannot > be completed" error message but it usually says euphemistically > "Microsoft Windows - this application is not responding." > > I've tried several things but I haven't had any success. During this > loading window, I've tried running msconfig and unchecking nonessential > programs, but even after clicking Save Changes and Restart the changes > are not saved, and it'll still proceed to crash and load the programs > again next boot. I've tried loading the control panel, but it becomes > unresponsive after I try to click anything in it. I tried opening > accessories under the Start Menu and it bugged out, and instead of > showing the folder icon it showed a searching icon and wouldn't open. > The Command Prompt loaded but was too slow to execute anything. I also > tried opening Task Manager, even through Ctrl+Alt+Delete, and after a > few minutes it successfully loaded once but didn't show anything unusual > and then crashed. > > I'm not sure what the problem is - the only things I can think of are > that I had just setup 3 identical automatic broadband internet > connections as I was troubleshooting the connection, the room was really > hot (about 90 degrees F), and I had an SD memory stick in when I booted > up the last few times before this. Also, I installed a Logitech Quickcam > a few weeks before (whose software loads in the tray automatically) and > one of the 2 popups that load is new, bugging me about registering > EarthDesk. It seem to me like any of this should cause my problem, but > it seems to me that it's a software problem, in part because I don't > have any real evidence of hardware failure (although it does get really > hot, but the fan is still working) and because while Windows will be > crashing and I can't use the Start Menu, I can still hover over programs > in the tray and have their name popup (but the battery status and volume > control won't). > > Anyone have any advice/input? I'm going to try to get a copy of the > recovery CD, but that'll take at least a week and there are no > authorized Gateway repair centers in China, not to mention the language > barrier and risk involved, especially if I don't know what's wrong... > Thanks a lot everyone! > > > -- > popular |
| | Re: Studying abroad, devastating weird laptop problem Translate.google.com may help you with the translation. It is mostly word-for-word translation, which means that many words will be out of place. -Paul Randall "xfile" <coucou@xxxxxx> wrote in message news:%23chDhvY%23JHA.4376@xxxxxx Quote: > Hi, > > > I think both Rick Rogers and Charlie Tame could be right. > > However, I would suggest you to stop the troubleshooting process at this > point, and I found the following address from Gateway, USA by clicking > "China" on their main page: > > http://cn.gateway.com/ > > You may want to have a local friend translate the page for you, and all > you want is a local support phone number. > > PS: As pointed out by Charlie Tame, you may also want to ask your local > friends about voltage converter (which may not be required by newer > models) and plug adapters (as far as I can remember - very confusing). > > Hope this helps and good luck. > > > > > "popular" <brenden.cline@xxxxxx> wrote in message > news:38e0d86fd227861645d313c0351a4495@xxxxxx-gateway.com... Quote: >> >> I'm studying abroad in China and my laptop has a really weird problem, >> so I apologize in advance but this is a bit long. >> >> I moved in with a host family last week, and 5 minutes after getting >> the internet to work and beginning to Skype chat people (without video) >> my computer (Gateway laptop model MT3423 I think, Vista Premium, Dual >> Core AMD Turion, ~2 years old in good condition) froze and hasn't been >> the same since. Now, booting brings me to the recovery screen (of course >> - Normal Mode, Safe Mode with Networking, etc.), but no Safe Mode works >> - I can get to the login screen but after signing in the Welcome screen >> with the loading circle stays up indefinitely. Normal Mode works though, >> but it has major issues. After successfully signing in programs begin to >> load but it quickly slows down to a crawl, and takes about a minute to >> close the two program warning boxes that pop up (just the usual 'this >> program is unregistered' sort of thing). After this, Windows Calendar >> inexplicably loads, again painfully slow, and if the computer hasn't >> crashed by this point then it does shortly thereafter. And the crash >> varies - a few times it started with a "Server Busy - this action cannot >> be completed" error message but it usually says euphemistically >> "Microsoft Windows - this application is not responding." >> >> I've tried several things but I haven't had any success. During this >> loading window, I've tried running msconfig and unchecking nonessential >> programs, but even after clicking Save Changes and Restart the changes >> are not saved, and it'll still proceed to crash and load the programs >> again next boot. I've tried loading the control panel, but it becomes >> unresponsive after I try to click anything in it. I tried opening >> accessories under the Start Menu and it bugged out, and instead of >> showing the folder icon it showed a searching icon and wouldn't open. >> The Command Prompt loaded but was too slow to execute anything. I also >> tried opening Task Manager, even through Ctrl+Alt+Delete, and after a >> few minutes it successfully loaded once but didn't show anything unusual >> and then crashed. >> >> I'm not sure what the problem is - the only things I can think of are >> that I had just setup 3 identical automatic broadband internet >> connections as I was troubleshooting the connection, the room was really >> hot (about 90 degrees F), and I had an SD memory stick in when I booted >> up the last few times before this. Also, I installed a Logitech Quickcam >> a few weeks before (whose software loads in the tray automatically) and >> one of the 2 popups that load is new, bugging me about registering >> EarthDesk. It seem to me like any of this should cause my problem, but >> it seems to me that it's a software problem, in part because I don't >> have any real evidence of hardware failure (although it does get really >> hot, but the fan is still working) and because while Windows will be >> crashing and I can't use the Start Menu, I can still hover over programs >> in the tray and have their name popup (but the battery status and volume >> control won't). >> >> Anyone have any advice/input? I'm going to try to get a copy of the >> recovery CD, but that'll take at least a week and there are no >> authorized Gateway repair centers in China, not to mention the language >> barrier and risk involved, especially if I don't know what's wrong... >> Thanks a lot everyone! >> >> >> -- >> popular |
| | Re: Studying abroad, devastating weird laptop problem Thanks and I totally forgot about it ![]() "Paul Randall" <paulr901@xxxxxx> wrote in message news:#F2LXbc#JHA.2120@xxxxxx Quote: > Translate.google.com may help you with the translation. It is mostly > word-for-word translation, which means that many words will be out of > place. > > -Paul Randall > > "xfile" <coucou@xxxxxx> wrote in message > news:%23chDhvY%23JHA.4376@xxxxxx Quote: >> Hi, >> >> >> I think both Rick Rogers and Charlie Tame could be right. >> >> However, I would suggest you to stop the troubleshooting process at this >> point, and I found the following address from Gateway, USA by clicking >> "China" on their main page: >> >> http://cn.gateway.com/ >> >> You may want to have a local friend translate the page for you, and all >> you want is a local support phone number. >> >> PS: As pointed out by Charlie Tame, you may also want to ask your local >> friends about voltage converter (which may not be required by newer >> models) and plug adapters (as far as I can remember - very confusing). >> >> Hope this helps and good luck. >> >> >> >> >> "popular" <brenden.cline@xxxxxx> wrote in message >> news:38e0d86fd227861645d313c0351a4495@xxxxxx-gateway.com... Quote: >>> >>> I'm studying abroad in China and my laptop has a really weird problem, >>> so I apologize in advance but this is a bit long. >>> >>> I moved in with a host family last week, and 5 minutes after getting >>> the internet to work and beginning to Skype chat people (without video) >>> my computer (Gateway laptop model MT3423 I think, Vista Premium, Dual >>> Core AMD Turion, ~2 years old in good condition) froze and hasn't been >>> the same since. Now, booting brings me to the recovery screen (of course >>> - Normal Mode, Safe Mode with Networking, etc.), but no Safe Mode works >>> - I can get to the login screen but after signing in the Welcome screen >>> with the loading circle stays up indefinitely. Normal Mode works though, >>> but it has major issues. After successfully signing in programs begin to >>> load but it quickly slows down to a crawl, and takes about a minute to >>> close the two program warning boxes that pop up (just the usual 'this >>> program is unregistered' sort of thing). After this, Windows Calendar >>> inexplicably loads, again painfully slow, and if the computer hasn't >>> crashed by this point then it does shortly thereafter. And the crash >>> varies - a few times it started with a "Server Busy - this action cannot >>> be completed" error message but it usually says euphemistically >>> "Microsoft Windows - this application is not responding." >>> >>> I've tried several things but I haven't had any success. During this >>> loading window, I've tried running msconfig and unchecking nonessential >>> programs, but even after clicking Save Changes and Restart the changes >>> are not saved, and it'll still proceed to crash and load the programs >>> again next boot. I've tried loading the control panel, but it becomes >>> unresponsive after I try to click anything in it. I tried opening >>> accessories under the Start Menu and it bugged out, and instead of >>> showing the folder icon it showed a searching icon and wouldn't open. >>> The Command Prompt loaded but was too slow to execute anything. I also >>> tried opening Task Manager, even through Ctrl+Alt+Delete, and after a >>> few minutes it successfully loaded once but didn't show anything unusual >>> and then crashed. >>> >>> I'm not sure what the problem is - the only things I can think of are >>> that I had just setup 3 identical automatic broadband internet >>> connections as I was troubleshooting the connection, the room was really >>> hot (about 90 degrees F), and I had an SD memory stick in when I booted >>> up the last few times before this. Also, I installed a Logitech Quickcam >>> a few weeks before (whose software loads in the tray automatically) and >>> one of the 2 popups that load is new, bugging me about registering >>> EarthDesk. It seem to me like any of this should cause my problem, but >>> it seems to me that it's a software problem, in part because I don't >>> have any real evidence of hardware failure (although it does get really >>> hot, but the fan is still working) and because while Windows will be >>> crashing and I can't use the Start Menu, I can still hover over programs >>> in the tray and have their name popup (but the battery status and volume >>> control won't). >>> >>> Anyone have any advice/input? I'm going to try to get a copy of the >>> recovery CD, but that'll take at least a week and there are no >>> authorized Gateway repair centers in China, not to mention the language >>> barrier and risk involved, especially if I don't know what's wrong... >>> Thanks a lot everyone! >>> >>> >>> -- >>> popular > |
| | #6 (permalink) |
| | Re: Studying abroad, devastating weird laptop problem Well I've seen some odd things happen with spurious things coming down power supply lines, in fact a few weeks back I had a good quality APC UPS hosed by something and it took out the computer PSU as well, but the same setup in the next room was fine, which is weird in itself as the outage was the same for both - oh well. We have bad power to our facility and I've seen machines get corrupted for no reason at all, usually installing a UPS fixes that. We don't know how the quality of the supply is around here half the time, never mind what it is like in China ![]() One thing I have seen a lot is "Freezing", although power off and on mostly gets them going again provided that not system files got hosed, and the other good one is start screen/reboot/start screen ad infinitum. xfile wrote: Quote: > Hi, > > > I think both Rick Rogers and Charlie Tame could be right. > > However, I would suggest you to stop the troubleshooting process at this > point, and I found the following address from Gateway, USA by clicking > "China" on their main page: > > http://cn.gateway.com/ > > You may want to have a local friend translate the page for you, and all > you want is a local support phone number. > > PS: As pointed out by Charlie Tame, you may also want to ask your local > friends about voltage converter (which may not be required by newer > models) and plug adapters (as far as I can remember - very confusing). > > Hope this helps and good luck. > > > > > "popular" <brenden.cline@xxxxxx> wrote in message > news:38e0d86fd227861645d313c0351a4495@xxxxxx-gateway.com... Quote: >> >> I'm studying abroad in China and my laptop has a really weird problem, >> so I apologize in advance but this is a bit long. >> >> I moved in with a host family last week, and 5 minutes after getting >> the internet to work and beginning to Skype chat people (without video) >> my computer (Gateway laptop model MT3423 I think, Vista Premium, Dual >> Core AMD Turion, ~2 years old in good condition) froze and hasn't been >> the same since. Now, booting brings me to the recovery screen (of course >> - Normal Mode, Safe Mode with Networking, etc.), but no Safe Mode works >> - I can get to the login screen but after signing in the Welcome screen >> with the loading circle stays up indefinitely. Normal Mode works though, >> but it has major issues. After successfully signing in programs begin to >> load but it quickly slows down to a crawl, and takes about a minute to >> close the two program warning boxes that pop up (just the usual 'this >> program is unregistered' sort of thing). After this, Windows Calendar >> inexplicably loads, again painfully slow, and if the computer hasn't >> crashed by this point then it does shortly thereafter. And the crash >> varies - a few times it started with a "Server Busy - this action cannot >> be completed" error message but it usually says euphemistically >> "Microsoft Windows - this application is not responding." >> >> I've tried several things but I haven't had any success. During this >> loading window, I've tried running msconfig and unchecking nonessential >> programs, but even after clicking Save Changes and Restart the changes >> are not saved, and it'll still proceed to crash and load the programs >> again next boot. I've tried loading the control panel, but it becomes >> unresponsive after I try to click anything in it. I tried opening >> accessories under the Start Menu and it bugged out, and instead of >> showing the folder icon it showed a searching icon and wouldn't open. >> The Command Prompt loaded but was too slow to execute anything. I also >> tried opening Task Manager, even through Ctrl+Alt+Delete, and after a >> few minutes it successfully loaded once but didn't show anything unusual >> and then crashed. >> >> I'm not sure what the problem is - the only things I can think of are >> that I had just setup 3 identical automatic broadband internet >> connections as I was troubleshooting the connection, the room was really >> hot (about 90 degrees F), and I had an SD memory stick in when I booted >> up the last few times before this. Also, I installed a Logitech Quickcam >> a few weeks before (whose software loads in the tray automatically) and >> one of the 2 popups that load is new, bugging me about registering >> EarthDesk. It seem to me like any of this should cause my problem, but >> it seems to me that it's a software problem, in part because I don't >> have any real evidence of hardware failure (although it does get really >> hot, but the fan is still working) and because while Windows will be >> crashing and I can't use the Start Menu, I can still hover over programs >> in the tray and have their name popup (but the battery status and volume >> control won't). >> >> Anyone have any advice/input? I'm going to try to get a copy of the >> recovery CD, but that'll take at least a week and there are no >> authorized Gateway repair centers in China, not to mention the language >> barrier and risk involved, especially if I don't know what's wrong... >> Thanks a lot everyone! >> >> >> -- >> popular |
| | #7 (permalink) |
| | Re: Studying abroad, devastating weird laptop problem As has been said in another branch to this thread, trying to fix a problem like this can be very frustrating and time consuming and it is often doomed to failure. If you have the money resources, I would suggest that you buy a replacement hard drive and clean install your system on it. It is seldom necessary to get the same brand as the original drive; just make sure it has the same interface (Sata vs IDE), and equal or more storage space than the original. In recent years, some computer manufacturers have designed their notebooks to allow very simple and easy access to replacing hard drives and memory sticks, and have a downloadable manual with illustrations to do the replacement, as well as specifications for replacement drives/memory. On this clean install, make sure your AV/malware suite is up to date, and install the minimum set of software to get your necessary work done. Work the system a while to veryify that it is stable. Purchase a USB case to hold the original hard drive; this will give you access to all your data on this old drive. Scan it with your AV/malware software. Over time, install the rest of the things you want on the new drive. The nice thing about this plan is that if you find that you have forgotten to get some key piece of information that can only be obtained while running from the original drive, you can switch back to get that info, saving it to a thumbdrive, then switch back to the new drive and use the info on the thumbdrive. If you are uncomfortable with doing this yourself, your computer repair place should be able to do it for you. Just make sure they know to keep the old hard drive and not attempt to 'clean it up' or format it, and to install it in a USB case and verify that its data is accessible. -Paul Randall "popular" <brenden.cline@xxxxxx> wrote in message news:042dcd15fd9fe8756a02a8d72172bc82@xxxxxx-gateway.com... Quote: > > Thanks for the input everyone, one thing I didn't mention is that before > I moved into my homestay, I was quarantined (swine flu and all) at a > hotel for a week. I used my laptop with no problem there with a voltage > converter (so that's no issue) and wireless internet, which makes me > skeptical of if it could be really be a virus/hacker. Three questions > (basically): > > 1) Is there a way to stop or disable the startup programs from loading, > besides msconfig? I can't really run an antivirus scan or anything else > since it's so slow and becomes unresponsive before it can do much. > > 2) What makes it seem like a virus? I have Norton Endpoint (from my > school) and Windows Firewall turned on, for what it's worth :/ > > 3) And how can I salvage my computer without reinstalling > Windows/reformatting? I can get to a computer repair place here, but if > I go in without knowing what's wrong/what needs to be done I'm afraid > they'll just wipe the harddrive which wouldn't be good... |
| | #8 (permalink) |
| | Re: Studying abroad, devastating weird laptop problem I forgot to mention: Hard drives can be partitioned and set up with a multiboot configuration. If you get a large (300 or more GB), then you might partion it to have a total of three primary partitions and one extended partition. The multibooting software/mechanism controls which primary partition you boot from. I prefer to do this manually. I create and format the primary partitions and the extended partition, then hide all primary partitions except the one I want to use now. I install the OS on all the primary partitions one at a time, with the others hidden. I have a bootable thumbdrive that holds the software for hiding/unhiding, and making one partition the active (bootable) partition. I create little batch files with names like Act-P1.bat and Act-P2.bat which do the hiding/unhiding and making the right partition active, so I don't have to type in the arcane commands to switch partitions. Then a reboot without the thumbdrive boots you into that partition. This kind of setup makes it relatively easy to switch to a 'clean' partition when you get in a situation like you are now in, in order to verify that with a clean system your computer runs as it should. This gives you the flexibility of having more than one 'installed spare clean system'. Of course, you will have to install your necessary applications on each of these partitions, which can take a lot of space. You might have a different mix of applications on the various primary bootable partitions. I use the extended partition to create a drive that can be shared, no matter which primary partition is booted from. Note that your computer may already have a second primary partition that contains recovery info that can be used to wipe out your current system and recreate it like new -- all your data gone. This will limit you to having only one spare bootable partition. Some computers come with a set of CDs or a DVD that provides the same functionality of this recovery partition, in which case you may choose to do it your way and have two customizable spare bootable partitions. Other computers allow you to make your own set of recovery CD/DVDs, but only one set, and have instructions in 'help & support'. With your current system running so poorly, you probably can't do that. Your computer manufacturer may sell recovery CD/DVDs specific to your particular laptop model, but they typically require the laptop's serial number or other info on a label on the computer. I would also recommend getting a bootable BartPE or other windows Preinstall Environment CD set up to allow poking around in a screwed up system using the clean system on the CD. The CD should be non-rewritable which guarantees that it cannot be contaminated with a virus after the CD is created. -Paul Randall "Paul Randall" <paulr901@xxxxxx> wrote in message news:epkK$3k%23JHA.1380@xxxxxx Quote: > As has been said in another branch to this thread, trying to fix a problem > like this can be very frustrating and time consuming and it is often > doomed to failure. > > If you have the money resources, I would suggest that you buy a > replacement hard drive and clean install your system on it. It is seldom > necessary to get the same brand as the original drive; just make sure it > has the same interface (Sata vs IDE), and equal or more storage space than > the original. In recent years, some computer manufacturers have designed > their notebooks to allow very simple and easy access to replacing hard > drives and memory sticks, and have a downloadable manual with > illustrations to do the replacement, as well as specifications for > replacement drives/memory. On this clean install, make sure your > AV/malware suite is up to date, and install the minimum set of software > to get your necessary work done. Work the system a while to veryify that > it is stable. Purchase a USB case to hold the original hard drive; this > will give you access to all your data on this old drive. Scan it with > your AV/malware software. Over time, install the rest of the things you > want on the new drive. > > The nice thing about this plan is that if you find that you have forgotten > to get some key piece of information that can only be obtained while > running from the original drive, you can switch back to get that info, > saving it to a thumbdrive, then switch back to the new drive and use the > info on the thumbdrive. > > If you are uncomfortable with doing this yourself, your computer repair > place should be able to do it for you. Just make sure they know to keep > the old hard drive and not attempt to 'clean it up' or format it, and to > install it in a USB case and verify that its data is accessible. > > -Paul Randall > > "popular" <brenden.cline@xxxxxx> wrote in message > news:042dcd15fd9fe8756a02a8d72172bc82@xxxxxx-gateway.com... Quote: >> >> Thanks for the input everyone, one thing I didn't mention is that before >> I moved into my homestay, I was quarantined (swine flu and all) at a >> hotel for a week. I used my laptop with no problem there with a voltage >> converter (so that's no issue) and wireless internet, which makes me >> skeptical of if it could be really be a virus/hacker. Three questions >> (basically): >> >> 1) Is there a way to stop or disable the startup programs from loading, >> besides msconfig? I can't really run an antivirus scan or anything else >> since it's so slow and becomes unresponsive before it can do much. >> >> 2) What makes it seem like a virus? I have Norton Endpoint (from my >> school) and Windows Firewall turned on, for what it's worth :/ >> >> 3) And how can I salvage my computer without reinstalling >> Windows/reformatting? I can get to a computer repair place here, but if >> I go in without knowing what's wrong/what needs to be done I'm afraid >> they'll just wipe the harddrive which wouldn't be good... > > |
| Weird - Very weird annoying problem | General Discussion | |||
| Re: Studying abroad, devastating weird laptop problem | Vista General | |||
| Devastating "administrator account" problem | Vista account administration | |||
| Brand new laptop... weird problems | Vista performance & maintenance | |||
