| Vista Ultimate 32 bit | Help with Windows Firewall and Base Filtering Engine Hoping one of you geniuses can help me out. I'm running 32 bit Vista Ultimate with Service Pack One. I have a problem that is driving me batty. When I open Windows security center and try to turn on Windows Firewall I get a message stating: "Windows Security Center can't turn on Windows Firewall." I attempt to turn on Windows Firewall manually but get the message: "Windows cannot start the Windows Firewall service." As per advice I saw on another thread on this forum (i believe) I opened a command prompt as an administrator and ran "SFC /scannow" several times. Each time I get the message: "Windows Resource Protection found corrupt files but was unable to fix some of them." In the log it looks like two files are corrupted (I have attached the entire log). They appear to me to be: 2009-06-30 15:55:09, Info CSI 000000ff [SR] Could not reproject corrupted file [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:18{9}]"mscms.dll"; source file in store is also corrupted 2009-06-30 15:55:10, Info CSI 00000100 Repair results created: and 2009-06-30 15:56:42, Info CSI 00000153 [SR] Could not reproject corrupted file [ml:520{260},l:58{29}]"\??\C:\Windows\System32\en-US"\[l:28{14}]"ikeext.dll.mui"; source file in store is also corrupted 2009-06-30 15:56:44, Info CSI 00000154 Repair results created: Finally this may be related. When I run services.msc as an administrator and attempt to start the base filtering engine service i get the following error: Windows could not start the Base Filtering Engine service on Local Computer. Error 15100: The resource loader failed to find MUI file. I hope I provided enough info. Just ask for more. Thanks so much!! Cant wait to get this fixed. |
| | Re: Help with Windows Firewall and Base Filtering Engine gordievsky wrote: Quote: > Hoping one of you geniuses can help me out. > > I'm running 32 bit Vista Ultimate with Service Pack One. > <http://vistasupport.mvps.org/repair_a_vista_installation_using_the_upgrade_option_of_the_vista_dvd.htm> |
| | Re: Help with Windows Firewall and Base Filtering Engine BFE Service is required for the Firewall to start. Start - All Programs - Accessories - Right Click Command Prompt - run as Admin sfc /scannow "gordievsky" <guest@xxxxxx-email.com> wrote in message news:aad4f91cd0ac937fa2cd15fc444dae66@xxxxxx-gateway.com... Quote: > > Hoping one of you geniuses can help me out. > > I'm running 32 bit Vista Ultimate with Service Pack One. > > I have a problem that is driving me batty. When I open Windows > security center and try to turn on Windows Firewall I get a message > stating: > > "Windows Security Center can't turn on Windows Firewall." > > I attempt to turn on Windows Firewall manually but get the message: > > "Windows cannot start the Windows Firewall service." > > As per advice I saw on another thread on this forum (i believe) I > opened a command prompt as an administrator and ran "SFC /scannow" > several times. Each time I get the message: > > "Windows Resource Protection found corrupt files but was unable to fix > some of them." > > In the log it looks like two files are corrupted (I have attached the > entire log). > > They appear to me to be: > > 2009-06-30 15:55:09, Info CSI 000000ff [SR] Could > not reproject corrupted file > [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:18{9}]"mscms.dll"; > source file in store is also corrupted > 2009-06-30 15:55:10, Info CSI 00000100 Repair > results created: > > > and > > 2009-06-30 15:56:42, Info CSI 00000153 [SR] Could > not reproject corrupted file > [ml:520{260},l:58{29}]"\??\C:\Windows\System32\en-US"\[l:28{14}]"ikeext.dll.mui"; > source file in store is also corrupted > 2009-06-30 15:56:44, Info CSI 00000154 Repair > results created: > > Finally this may be related. When I run services.msc as an > administrator and attempt to start the base filtering engine service i > get the following error: > > Windows could not start the Base Filtering Engine service on Local > Computer. > > Error 15100: The resource loader failed to find MUI file. > > I hope I provided enough info. Just ask for more. > > Thanks so much!! Cant wait to get this fixed. > > > +-------------------------------------------------------------------+ > |Filename: CBS.log | > |Download: http://www.vistax64.com/attachment.p...hmentid=13876| > +-------------------------------------------------------------------+ > > -- > gordievsky |
| Vista Ultimate 32 bit | Re: Help with Windows Firewall and Base Filtering Engine gordievsky wrote: Quote: > Hoping one of you geniuses can help me out. > > I'm running 32 bit Vista Ultimate with Service Pack One. > <http://vistasupport.mvps.org/repair_a_vista_installation_using_the_upgrade_option_of_the_vista_dvd.htm> |
| Vista Ultimate 32 bit | Re: Help with Windows Firewall and Base Filtering Engine BFE Service is required for the Firewall to start. Start - All Programs - Accessories - Right Click Command Prompt - run as Admin sfc /scannow "gordievsky" <guest@xxxxxx-email.com> wrote in message news:aad4f91cd0ac937fa2cd15fc444dae66@xxxxxx-gateway.com... Quote: > > Hoping one of you geniuses can help me out. > > I'm running 32 bit Vista Ultimate with Service Pack One. > > I have a problem that is driving me batty. When I open Windows > security center and try to turn on Windows Firewall I get a message > stating: > > "Windows Security Center can't turn on Windows Firewall." > > I attempt to turn on Windows Firewall manually but get the message: > > "Windows cannot start the Windows Firewall service." > > As per advice I saw on another thread on this forum (i believe) I > opened a command prompt as an administrator and ran "SFC /scannow" > several times. Each time I get the message: > > "Windows Resource Protection found corrupt files but was unable to fix > some of them." > > In the log it looks like two files are corrupted (I have attached the > entire log). > > They appear to me to be: > > 2009-06-30 15:55:09, Info CSI 000000ff [SR] Could > not reproject corrupted file > [ml:520{260},l:46{23}]"\??\C:\Windows\System32"\[l:18{9}]"mscms.dll"; > source file in store is also corrupted > 2009-06-30 15:55:10, Info CSI 00000100 Repair > results created: > > > and > > 2009-06-30 15:56:42, Info CSI 00000153 [SR] Could > not reproject corrupted file > [ml:520{260},l:58{29}]"\??\C:\Windows\System32\en-US"\[l:28{14}]"ikeext.dll.mui"; > source file in store is also corrupted > 2009-06-30 15:56:44, Info CSI 00000154 Repair > results created: > > Finally this may be related. When I run services.msc as an > administrator and attempt to start the base filtering engine service i > get the following error: > > Windows could not start the Base Filtering Engine service on Local > Computer. > > Error 15100: The resource loader failed to find MUI file. > > I hope I provided enough info. Just ask for more. > > Thanks so much!! Cant wait to get this fixed. > > > +-------------------------------------------------------------------+ > |Filename: CBS.log | > |Download: http://www.vistax64.com/attachment.php?attachmentid=13876| > +-------------------------------------------------------------------+ > > -- > gordievsky That's what I suspected. When I run "sfc /scannow" as an admin I get the message: "Windows Resource Protection found currupt files but was unable to fix some of them." I attached the CBS.log |
| | #6 (permalink) |
| Vista Ultimate 32 bit | Re: Help with Windows Firewall and Base Filtering Engine Any other ideas? |
| | #7 (permalink) |
| | Re: Help with Windows Firewall and Base Filtering Engine http://www.blackviper.com/WinVista/S...s_Firewall.htm Make sure all your services are set properly. They have interdependency. http://www.blackviper.com/WinVista/servicecfg.htm Start - Admin Tools - Services Or Start - type administrative - Administrative Tools folder - Services Google your error messages for more. "gordievsky" <guest@xxxxxx-email.com> wrote in message news:f91ec836793c8ed545e1bd30775bd802@xxxxxx-gateway.com... Quote: > > Any other ideas? > > > -- > gordievsky |
| | #8 (permalink) |
| Vista Ultimate 32 bit | Re: Help with Windows Firewall and Base Filtering Engine Windows Vista Service Pack 2 Services Information - Windows Firewall Make sure all your services are set properly. They have interdependency. Windows Vista Service Pack 2 Service Configurations by Black Viper Start - Admin Tools - Services Or Start - type administrative - Administrative Tools folder - Services Google your error messages for more. "gordievsky" <guest@xxxxxx-email.com> wrote in message news:f91ec836793c8ed545e1bd30775bd802@xxxxxx-gateway.com... Quote: > > Any other ideas? > > > -- > gordievsky Thanks, I did this. When I attempted to start both IKEEXT and Base Filtering Engine services, they gave me two different errors: Base Filtering Engine gives: "Error 15100: The resource loader failed to find MUI file." IKEEXT gives: "Error 1068: The dependency service or group failed to start." IKEEXT also says "Failed to Read Description. Error Code: 15100" "Error 1086: The dependency service or group failed to start." I googled both the errors but could not find a solution. I'm hoping some experts here can help. Thanks!! |
| | #9 (permalink) |
| | Re: Help with Windows Firewall and Base Filtering Engine Have a Vista disc? looks like Startup Repair is needed. -- Rob Supporting Member, Cascade Bicycle Club P.O. Box 15165 Seattle, WA. 98115-0165 206-522-3222 and 24 hr hotline 206-522-BIKE http://www.cascade.org "gordievsky" <guest@xxxxxx-email.com> wrote in message news:1a24eeb82a124b2ae0232a62913f484a@xxxxxx-gateway.com... Quote: > > Spirit;1080321 Wrote: Quote: >> 'Windows Vista Service Pack 2 Services Information - Windows Firewall' >> (http://www.blackviper.com/WinVista/S...s_Firewall.htm) >> >> Make sure all your services are set properly. They have >> interdependency. >> >> 'Windows Vista Service Pack 2 Service Configurations by Black Viper' >> (http://www.blackviper.com/WinVista/servicecfg.htm) >> >> Start - Admin Tools - Services >> >> Or Start - type administrative - Administrative Tools folder - Services >> >> Google your error messages for more. >> >> "gordievsky" <guest@xxxxxx-email.com> wrote in message >> news:f91ec836793c8ed545e1bd30775bd802@xxxxxx-gateway.com...> > > Quote: >> > > >> > > Any other ideas? >> > > >> > > >> > > -- >> > > gordievsky > > > > Thanks, I did this. > > When I attempted to start both IKEEXT and Base Filtering Engine > services, they gave me two different errors: > > Base Filtering Engine gives: > > "Error 15100: The resource loader failed to find MUI file." > > IKEEXT gives: > > "Error 1068: The dependency service or group failed to start." > > IKEEXT also says "Failed to Read Description. Error Code: 15100" > > "Error 1086: The dependency service or group failed to start." > > I googled both the errors but could not find a solution. I'm hoping > some experts here can help. > > Thanks!! > > > -- > gordievsky |
| | #10 (permalink) |
| Vista Ultimate 32 bit | Re: Help with Windows Firewall and Base Filtering Engine I do have a Vista disc. Does Startup repair delete all my programs/files? Have a Vista disc? looks like Startup Repair is needed. -- Rob Supporting Member, Cascade Bicycle Club P.O. Box 15165 Seattle, WA. 98115-0165 206-522-3222 and 24 hr hotline 206-522-BIKE http://www.cascade.org "gordievsky" <guest@xxxxxx-email.com> wrote in message news:1a24eeb82a124b2ae0232a62913f484a@xxxxxx-gateway.com... Quote: > > Spirit;1080321 Wrote: Quote: >> 'Windows Vista Service Pack 2 Services Information - Windows Firewall' >> (Windows Vista Service Pack 2 Services Information - Windows Firewall) >> >> Make sure all your services are set properly. They have >> interdependency. >> >> 'Windows Vista Service Pack 2 Service Configurations by Black Viper' >> (Windows Vista Service Pack 2 Service Configurations by Black Viper) >> >> Start - Admin Tools - Services >> >> Or Start - type administrative - Administrative Tools folder - Services >> >> Google your error messages for more. >> >> "gordievsky" <guest@xxxxxx-email.com> wrote in message >> news:f91ec836793c8ed545e1bd30775bd802@xxxxxx-gateway.com...> > > > > Thanks, I did this. > > When I attempted to start both IKEEXT and Base Filtering Engine > services, they gave me two different errors: > > Base Filtering Engine gives: > > "Error 15100: The resource loader failed to find MUI file." > > IKEEXT gives: > > "Error 1068: The dependency service or group failed to start." > > IKEEXT also says "Failed to Read Description. Error Code: 15100" > > "Error 1086: The dependency service or group failed to start." > > I googled both the errors but could not find a solution. I'm hoping > some experts here can help. > > Thanks!! > > > -- > gordievsky |
| Base Filtering Engine Prevents Ethernet Connectivity | Vista networking & sharing | |||
| Base Filtering Engine wont start | Vista General | |||
| Dropped Internet Connnection related to Base Filtering Engine | Vista networking & sharing | |||
| The Base Filtering Engine service terminated | Vista security | |||
| Base Filtering Engine in Vista causing very slow DNS lookups and slow internet performance | Vista security | |||
