Vista Tutorial - DEP problem! help me!!!
Old 07-02-2009   #1 (permalink)
vista home premium
Hello
I turned DEP off by reading the vistax64 forum.
when i rebooted, a big problem raised.
windows vista ( home premium ) crashed to continue.
i selected safe mode and other F8 choices...but still problem is there.
then I used Vista DVD to repair startup...problem not solved.
I used system restore...but not worked.
DELL company gived a choice to me...it sets all required windows vista files and folders on my another drive...how can i boot it ?
if i do it, so i can keep avoid my files and downloaded programs ( .exe ) from failed windows ( c:\ ) .
your forum website is best
thank you
Arsham Farahani
Old 07-03-2009   #2 (permalink)
vista home premium
Re: DEP problem! help me!!!
please dont forget my issue!!!
Old 07-03-2009   #3 (permalink)
Administrator
Hello Arsham,
You might see if booting to the command prompt from your Vista installation DVD, then enabling DEP again may help. OPTION TWO in the link below will help show you how to boot into the command prompt if needed.
Command Prompt at Startup
If you do the "Restore the computer's software to the original condition" option from Dell, then it will format your hard drive and restore Vista back to factory default like the day you first got it. It should fix your porblem, but it will wipe out all of your files though.
Quote  Quote: Originally Posted by persiagulf4ever View Post
Hello
thank you
Arsham Farahani
Old 07-03-2009   #4 (permalink)
vista home premium
thanks,i know how to open cmd from Vista DVD.
I need a command to enabling my inactive windows...i remember that we should use bootcfg /rebuild in XP ( i read in XP 70-270 testking...but in vista i know it does not work ).
i think i should active boot files from drive D:\ ?
Quote  Quote: Originally Posted by Brink View Post
Hello Arsham,
Hello
thank you
Arsham Farahani
Old 07-03-2009   #5 (permalink)
Administrator
You can try these commands to repair the Vista boot files.
Bootmgr is missing
Hello Arsham,
Hello
thank you
Arsham Farahani
Old 07-03-2009   #6 (permalink)
vista home premium
which command is useful for activing boot files of drive d:\ ?
Quote:
Boot the computer from Vista OS DVD.
  • Click on Repair Your Computer.
  • Click on Command prompt.
  • At the X:\Sources prompt, type bcdedit /export C:\BCD_Backup and press <Enter>
  • Type c: and press <Enter>.
  • At the C:\ prompt, type cd boot and press <Enter>.
  • At the C:\Boot prompt, type attrib bcd -s -h -r and press <Enter>.
  • At the C:\Boot prompt, type ren c:\boot\bcd bcd.old and press <Enter>.
  • At the C:\Boot prompt, type bootrec /rebuildbcd and press <Enter>.
  • The Boot Configuration File will be rebuilt at this point. Once it finishes, type exit and press <Enter>. Click the Restart button .
Old 07-03-2009   #7 (permalink)
Administrator
I would do the ones in the link that I posted above.
Bootmgr is missing
bootrec /fixmbr
(your dvdrom drive letter):\boot\bootsect.exe /nt60 all /force
del C:\boot\bcd
bootrec /rebuildbcd
Close cmd prompt, remove dvd, Reboot.
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
