Vista - sound scheme problems please help me ??
Old 07-05-2009   #1 (permalink)
Tony
I keep getting a yellow exclamation point on windows start navigation sound
I can go in and select it and it works for the time it is selected. but as
soon as I reboot the yellow exclamation point comes back how do I fix this
can someone help me please it annoying and aggravating to have to turn that
on all the time. I even did a system restore back to yesterday thinking I
did something to it no go still dose it. nothing else broken all works good
sound everything just not this one. thanks if you can help.
Old 07-05-2009   #2 (permalink)
The C. [MCSE] Privacy & Disclosure
RE: sound scheme problems please help me ??
This tutorial may help you
:System Files - SFC Command with a
windows file checker scan. Good Luck.
Computer/Software Tech.
Make it a great day!
Charles Richmond
Old 07-05-2009   #3 (permalink)
Jon
Re: sound scheme problems please help me ??
"Tony" <spock0@xxxxxx> wrote in message
news:9B9C32A1-7416-486C-A580-8C97EA5EFE20@xxxxxx
After changing your sound scheme, try saving it ['Save as ..' button above
sound selection area].
Otherwise what does the 'yellow exclamation point' say (exact message)?
Jon
It is better to light a candle than to curse the darkness (Chinese proverb)
Old 07-05-2009   #4 (permalink)
Tony
it doesn't say anything just there is strange I will try the scan thing.
"Jon" <Email_Address@xxxxxx> wrote in message
news:#Z9eAjW$JHA.3732@xxxxxx
>>sound I can go in and select it and it works for the time it is selected.
>>but as soon as I reboot the yellow exclamation point comes back how do I
>>fix this can someone help me please it annoying and aggravating to have to
>>turn that on all the time. I even did a system restore back to yesterday
>>thinking I did something to it no go still dose it. nothing else broken
>>all works good sound everything just not this one. thanks if you can help.
> Jon
> proverb)
Old 07-06-2009   #5 (permalink)
RalfG
If the sound file is corrupt no amount scans are going to report
anything. If you can open the file in an audio editor you can try
re-saving it. If you are trying to use a sound file that you added
yourself it might be simpler to just acquire/try a different copy of the
file.
>>> selected. but as soon as I reboot the yellow exclamation point comes
>>> back how do I fix this can someone help me please it annoying and
>>> aggravating to have to turn that on all the time. I even did a system
>>> restore back to yesterday thinking I did something to it no go still
>>> dose it. nothing else broken all works good sound everything just not
>> above sound selection area].
>> Jon
>> proverb)
Old 07-06-2009   #6 (permalink)
Tony
how would I obtain a audio editor I have real player and windows media
player do they do any sort of editing?. also is there a place to d-load the
windows default sound files?. thanks.
"RalfG" <itsnotme@xxxxxx> wrote in message
news:O0sgX5j$JHA.2120@xxxxxx
Quote:
> If the sound file is corrupt no amount scans are going to report anything.
> If you can open the file in an audio editor you can try re-saving it. If
> you are trying to use a sound file that you added yourself it might be
> simpler to just acquire/try a different copy of the file.
> Tony wrote:
>> thing.
>>> Jon
>>> proverb)
Old 07-06-2009   #7 (permalink)
Jon
news:A4B9E70A-1D2B-4476-B394-E99906633F0D@xxxxxx
> the windows default sound files?. thanks.
I'd first have a look in
C:\Windows\winsxs\x86_microsoft-windows-shell-sounds_........
for .wav files, specifically 'Windows Exclamation.wav'
If you spot it then you could try copying it to the folder
'C:\Windows\Media\'
Jon
Old 07-06-2009   #8 (permalink)
Jon
news:%23TMd5el$JHA.1488@xxxxxx
> 'C:\Windows\Media\'
Sorry it was 'Start navigation' wasn't it...
Try looking for 'Windows Navigation Start.wav' in subfolders of
C:\Windows\winsxs\x86_microsoft-windows-ie-internetexplorer_...........
Jon
Old 07-06-2009   #9 (permalink)
Tony
did not work could it be that maybe my real player took over those file
extensions and this causing the problem? if so would a simple re associate
that file to windows media work?
news:OuxWahl$JHA.1336@xxxxxx
>> 'C:\Windows\Media\'
> Jon
Old 07-06-2009   #10 (permalink)
Jon
news:1427C460-43D3-40D8-ADC2-DD3498695C2E@xxxxxx
Quite possibly. If not then these are my registry setting for .wav files,
which I think are default, and which you could compare with your own, or
paste into a .reg file .....
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\.wav]
"PerceivedType"="audio"
@="WMP11.AssocFile.WAV"
"Content Type"="audio/wav"
[HKEY_CLASSES_ROOT\.wav\OpenWithProgIds]
"soundrec"=hex(0):
"WMP11.AssocFile.WAV"=hex(0):
[HKEY_CLASSES_ROOT\.wav\PersistentHandler]
@="{098f2470-bae0-11cd-b579-08002b30bfeb}"
Jon
Sound scheme problem Vista General
Windows Vista Sound Scheme Vista performance & maintenance
Sound Scheme Tutorials
New Sound scheme? Vista General
Sound scheme for Vista Vista General
