| | Startup problem with Vista Whenever I start my laptop, I receiev the follewing message: GrooveMonitor.exe not working error code0xc0150004 and BTTray.exe not working error code 0xc0150004 The problem signature i Problem signature: Problem Event Name: APPCRASH Application Name: btsendto_explorer.exe Application Version: 6.2.0.6600 Application Timestamp: 49222aa5 Fault Module Name: ntdll.dll Fault Module Version: 6.0.6001.18000 Fault Module Timestamp: 4791a7a6 Exception Code: c0150004 Exception Offset: 00009cac OS Version: 6.0.6001.2.1.0.768.3 Locale ID: 16393 Additional Information 1: 9d13 Additional Information 2: 1abee00edb3fc1158f9ad6f44f0f6be8 Additional Information 3: 9d13 Additional Information 4: 1abee00edb3fc1158f9ad6f44f0f6be8 What should I do? -- vivekalka ------------------------------------------------------------------------ vivekalka's Profile: http://forums.techarena.in/members/112029.htm View this thread: http://forums.techarena.in/vista-help/1209013.htm http://forums.techarena.in |
| | Re: Startup problem with Vista vivekalka wrote: Quote: > > Whenever I start my laptop, I receiev the follewing message: > GrooveMonitor.exe not working error code0xc0150004 and BTTray.exe not > working error code 0xc0150004 > The problem signature i > Problem signature: > Problem Event Name: APPCRASH > Application Name: btsendto_explorer.exe you use Bluetooth devices, update your drivers. If you don't use Bluetooth devices, you can stop those processes from running at Startup (see below). GrooveMonitor.exe belongs to the Groove add-in of Microsoft Office. Office Groove is a collaboration program. http://office.microsoft.com/en-us/gr...656331033.aspx If you don't use Groove, you can just disable it from running at Startup. Manage your Startup: Start Orb>Search box>type: msconfig and when it appears in the Results box above, right-click and choose "Run as Administrator". If you are prompted for an administrator password or for a confirmation, type the password, or click Continue. Then see what is on the Startup tab. You don't need to restart immediately, but the next time you do you'll get a dialog saying you've used the Utility. Usually in Vista this will be blocked by Windows Defender and you'll need to allow it so you can then tick the box that says in effect, "don't bother me about this again". Important - Do not use the System Configuration Utility to stop processes. Instead, use Services. Start Orb>Search box>type: services and when it appears in the Results box above, right-click and choose "Run As Administrator". Confirm elevation as needed. The free Autoruns program is very useful for managing your Startup - http://www.microsoft.com/technet/sys...s/default.mspx Malke -- MS-MVP Elephant Boy Computers - Don't Panic! http://www.elephantboycomputers.com/#FAQ |
| Vista Startup Problem | General Discussion | |||
| Vista Startup Problem | Vista General | |||
| Vista startup problem | Vista installation & setup | |||
| Vista startup problem | General Discussion | |||
| Windows Vista problem at startup | Vista performance & maintenance | |||
