| | #11 (permalink) |
| | Re: Problems using Nero 6 and 7 Well I've watched the start of a film in.mpg format and its fine. Brian Wescombe wrote: > > "Mike" <me@mine.com> wrote in message > news:eRk9yy69GHA.4356@TK2MSFTNGP05.phx.gbl... >> I'm using RC1, (downloaded RC2 but could not burn it correctly) >> >> Nero 7.5.7.0 installed OK and I've used it to re-format DVD-RW's >> without problems. >> Only query I had was it wants to update Direct X but I just said "go >> ahead" and it works OK. Nero video/sound player works OK > > Try browsing to a folder containing MPEG files and see if you get an > error (or ten) > >> >> Mike >> >> Brian Wescombe wrote: >>> >>> "Clark" <who@whoknows.com> wrote in message >>> news:OotYxsu9GHA.4552@TK2MSFTNGP05.phx.gbl... >>>> Another thing I was thinking about was that I did not install the >>>> Nero Home utility. I figured it was too much like WMC that a >>>> conflict might occur. >>> >>> I didn't install Nero Home either, still had the problem >>> >>>> >>>> Clark >>>> >>>> "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in >>>> message news:aX9%g.8496$76.912@newsfe5-win.ntli.net... >>>>> That's the version I'm using, and getting the error shown below. >>>>> The so-called Vista ready version is unusable on my system while >>>>> this problem is occuring >>>>> >>>>> "Rob" <Rob@discussions.microsoft.com> wrote in message >>>>> news:9A053C1F-A010-41DC-8AFF-0D5136EE5286@microsoft.com... >>>>>> Good news. The wait is over. Nero 7 Ultra Enhanced release Oct 16 >>>>>> seems to >>>>>> now support Vista, well at least in the release notes it says it's >>>>>> Vista >>>>>> Ready now as a new feature so I take it everyone should upgrade to >>>>>> this new >>>>>> version (released last week) and test it on Vista. >>>>>> >>>>>> "Brian Wescombe" wrote: >>>>>> >>>>>>> Just done a clean install of 5744 RC2. Everything's working fine, >>>>>>> but when I >>>>>>> install either Nero 6.6.1.4 or 7.5.7.0, I get an error 'Windows >>>>>>> host process >>>>>>> (rundll32) has stopped working' and 'COM Surrogate has stopped >>>>>>> working' >>>>>>> whenever I browse to a folder containing MPEG files. Removing Nero >>>>>>> completely fixes the problem. >>>>>>> >>>>>>> I seem to recall a similar issue being posted here last week >>>>>>> >>>>>>> >>>>> >>>> >>> > |
| | #12 (permalink) |
| | Re: Problems using Nero 6 and 7 >> "Mike" <me@mine.com> wrote in message >> news:eRk9yy69GHA.4356@TK2MSFTNGP05.phx.gbl... >>> I'm using RC1, (downloaded RC2 but could not burn it correctly) >>> >>> Nero 7.5.7.0 installed OK and I've used it to re-format DVD-RW's >>> without problems. >>> Only query I had was it wants to update Direct X but I just said >>> "go ahead" and it works OK. Nero video/sound player works OK >> >> Try browsing to a folder containing MPEG files and see if you get >> an error (or ten) > > Well I've watched the start of a film in.mpg format and its fine. That's not the problem...movies play just fine. The issue is a driver conflict when you browse a folder with icons that show preview images of the mpeg file within the icons. If you change the display to list, detail, or small icons where there is no preview image of the movie, then there is no conflict and the service continues to run properly. Switch to large or medium icons, or tiles, and the service will immediately crash with an error when trying to render the preview image in the icons. This is a problem with the drivers provided from Nero. If you do a custom install of Nero and do not install the video and extra plugins, just the basic burning software, then Vista seems to work fine. It's obviously a driver conflict that Ahead overlooked - which is odd, because the default view is tiled icons which most people would have set in explorer. This happens with RC2 as well. |
| | #13 (permalink) |
| | Re: Problems using Nero 6 and 7 Bill, I've installed Nero 7 with just the burning ROM program and Recode enabled during Setup, but I still get the error with MPEG files. Any ideas? Hopefully they'll issue a fix before long "Bill" <bill@c.a> wrote in message news:b6Odnf6V37L4ktzYnZ2dnUVZ_oOdnZ2d@golden.net... > > That's not the problem...movies play just fine. > > The issue is a driver conflict when you browse a folder with icons that > show preview images of the mpeg file within the icons. If you change the > display to list, detail, or small icons where there is no preview image of > the movie, then there is no conflict and the service continues to run > properly. > > Switch to large or medium icons, or tiles, and the service will > immediately crash with an error when trying to render the preview image in > the icons. > > This is a problem with the drivers provided from Nero. If you do a custom > install of Nero and do not install the video and extra plugins, just the > basic burning software, then Vista seems to work fine. It's obviously a > driver conflict that Ahead overlooked - which is odd, because the default > view is tiled icons which most people would have set in explorer. > > This happens with RC2 as well. > |
| | #14 (permalink) |
| | Re: Problems using Nero 6 and 7 Could you give an example of the type of file to which you refer and possibly a place to download one, or how you got it? Are these videos you made, or something else. There are many different types of mpegs. Perhaps, even the one you have is corrupted. Clark "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in message news:dm11h.21780$gO3.5040@newsfe7-win.ntli.net... > Bill, I've installed Nero 7 with just the burning ROM program and Recode > enabled during Setup, but I still get the error with MPEG files. > Any ideas? Hopefully they'll issue a fix before long > > > "Bill" <bill@c.a> wrote in message > news:b6Odnf6V37L4ktzYnZ2dnUVZ_oOdnZ2d@golden.net... >> >> That's not the problem...movies play just fine. >> >> The issue is a driver conflict when you browse a folder with icons that >> show preview images of the mpeg file within the icons. If you change the >> display to list, detail, or small icons where there is no preview image >> of the movie, then there is no conflict and the service continues to run >> properly. >> >> Switch to large or medium icons, or tiles, and the service will >> immediately crash with an error when trying to render the preview image >> in the icons. >> >> This is a problem with the drivers provided from Nero. If you do a custom >> install of Nero and do not install the video and extra plugins, just the >> basic burning software, then Vista seems to work fine. It's obviously a >> driver conflict that Ahead overlooked - which is odd, because the default >> view is tiled icons which most people would have set in explorer. >> >> This happens with RC2 as well. >> > |
| | #15 (permalink) |
| | Re: Problems using Nero 6 and 7 "Clark" <who@whoknows.com> wrote in message news:%23Atqtp1%23GHA.1752@TK2MSFTNGP02.phx.gbl... > Could you give an example of the type of file to which you refer and > possibly a place to download one, or how you got it? Are these videos you > made, or something else. There are many different types of mpegs. > Perhaps, even the one you have is corrupted. Any type of MPEG will cause the problem - I've got some from Enchanced CDs (music video clips), some from DVDs and some were created when importing DVD recorder discs into Ulead Movie Factory. It doesn't matter which folder the files are in, or how many there are. As soon as I browse to a folder containing MPEGs the error appears immediately > > Clark > > "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in > message news:dm11h.21780$gO3.5040@newsfe7-win.ntli.net... >> Bill, I've installed Nero 7 with just the burning ROM program and Recode >> enabled during Setup, but I still get the error with MPEG files. >> Any ideas? Hopefully they'll issue a fix before long >> >> >> "Bill" <bill@c.a> wrote in message >> news:b6Odnf6V37L4ktzYnZ2dnUVZ_oOdnZ2d@golden.net... >>> >>> That's not the problem...movies play just fine. >>> >>> The issue is a driver conflict when you browse a folder with icons that >>> show preview images of the mpeg file within the icons. If you change the >>> display to list, detail, or small icons where there is no preview image >>> of the movie, then there is no conflict and the service continues to run >>> properly. >>> >>> Switch to large or medium icons, or tiles, and the service will >>> immediately crash with an error when trying to render the preview image >>> in the icons. >>> >>> This is a problem with the drivers provided from Nero. If you do a >>> custom install of Nero and do not install the video and extra plugins, >>> just the basic burning software, then Vista seems to work fine. It's >>> obviously a driver conflict that Ahead overlooked - which is odd, >>> because the default view is tiled icons which most people would have set >>> in explorer. >>> >>> This happens with RC2 as well. >>> >> > |
| | #16 (permalink) |
| | Re: Problems using Nero 6 and 7 "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in message news:dm11h.21780$gO3.5040@newsfe7-win.ntli.net... > Bill, I've installed Nero 7 with just the burning ROM program and > Recode enabled during Setup, but I still get the error with MPEG > files. > Any ideas? Hopefully they'll issue a fix before long Whoa...I thought I had it working ok but you're right, the problem exists even when I disable installing everything except Burning Rom. No ideas...we'll have to wait for Ahead to produce a fix. I'm surprised they missed this one...it's very obvious. |
| | #17 (permalink) |
| | Re: Problems using Nero 6 and 7 Thanks for letting me know Bill. At least I'm not the only one with this problem (that would be even more frustrating!) "Bill" <bill@c.a> wrote in message news:AZydnYgTD4lfXNnYnZ2dnUVZ_vudnZ2d@golden.net... > "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in > message news:dm11h.21780$gO3.5040@newsfe7-win.ntli.net... >> Bill, I've installed Nero 7 with just the burning ROM program and Recode >> enabled during Setup, but I still get the error with MPEG files. >> Any ideas? Hopefully they'll issue a fix before long > > Whoa...I thought I had it working ok but you're right, the problem exists > even when I disable installing everything except Burning Rom. > > No ideas...we'll have to wait for Ahead to produce a fix. I'm surprised > they missed this one...it's very obvious. > |
| | #18 (permalink) |
| | Re: Problems using Nero 6 and 7 Well, I will try to reproduce your problem, but for now, you might take a particular mpeg and put it in a separate folder and then try to browse to it. If it locks up, try checking the files associations for that extension to see what is opening it. Since you say all mpeg, I am going to download an MP4 from the Nero site which is a movie trailer. I will see if it locks up. Clark "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in message news 841h.6380$RR2.2329@newsfe2-win.ntli.net...> Thanks for letting me know Bill. At least I'm not the only one with this > problem (that would be even more frustrating!) > > "Bill" <bill@c.a> wrote in message > news:AZydnYgTD4lfXNnYnZ2dnUVZ_vudnZ2d@golden.net... >> "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in >> message news:dm11h.21780$gO3.5040@newsfe7-win.ntli.net... >>> Bill, I've installed Nero 7 with just the burning ROM program and Recode >>> enabled during Setup, but I still get the error with MPEG files. >>> Any ideas? Hopefully they'll issue a fix before long >> >> Whoa...I thought I had it working ok but you're right, the problem exists >> even when I disable installing everything except Burning Rom. >> >> No ideas...we'll have to wait for Ahead to produce a fix. I'm surprised >> they missed this one...it's very obvious. >> > |
| | #19 (permalink) |
| | Re: Problems using Nero 6 and 7 Well, the mp4 file worked fine. Any other suggestions to track this down? Did you have any other versions of Nero Installed first and did you try to use the Clean Tool prior to installing the latest version? Clark "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in message news 841h.6380$RR2.2329@newsfe2-win.ntli.net...> Thanks for letting me know Bill. At least I'm not the only one with this > problem (that would be even more frustrating!) > > "Bill" <bill@c.a> wrote in message > news:AZydnYgTD4lfXNnYnZ2dnUVZ_vudnZ2d@golden.net... >> "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in >> message news:dm11h.21780$gO3.5040@newsfe7-win.ntli.net... >>> Bill, I've installed Nero 7 with just the burning ROM program and Recode >>> enabled during Setup, but I still get the error with MPEG files. >>> Any ideas? Hopefully they'll issue a fix before long >> >> Whoa...I thought I had it working ok but you're right, the problem exists >> even when I disable installing everything except Burning Rom. >> >> No ideas...we'll have to wait for Ahead to produce a fix. I'm surprised >> they missed this one...it's very obvious. >> > |
| | #20 (permalink) |
| | Re: Problems using Nero 6 and 7 "Clark" <who@whoknows.com> wrote in message news:eduZLN5%23GHA.896@TK2MSFTNGP03.phx.gbl... > Well, the mp4 file worked fine. Any other suggestions to track this down? > > Did you have any other versions of Nero Installed first and did you try to > use the Clean Tool prior to installing the latest version? No, clean install of 7.5.7.0 and a clean install of Vista. The files will all play fine, it's when you browse to the folder containing them that's the problem. The problem only started when I installed Nero, after removing it everything was ok again. > > Clark > > "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in > message news 841h.6380$RR2.2329@newsfe2-win.ntli.net...>> Thanks for letting me know Bill. At least I'm not the only one with this >> problem (that would be even more frustrating!) >> >> "Bill" <bill@c.a> wrote in message >> news:AZydnYgTD4lfXNnYnZ2dnUVZ_vudnZ2d@golden.net... >>> "Brian Wescombe" <brian.NOSPAMwescombe@PLEASEntlworld.com> wrote in >>> message news:dm11h.21780$gO3.5040@newsfe7-win.ntli.net... >>>> Bill, I've installed Nero 7 with just the burning ROM program and >>>> Recode enabled during Setup, but I still get the error with MPEG files. >>>> Any ideas? Hopefully they'll issue a fix before long >>> >>> Whoa...I thought I had it working ok but you're right, the problem >>> exists even when I disable installing everything except Burning Rom. >>> >>> No ideas...we'll have to wait for Ahead to produce a fix. I'm surprised >>> they missed this one...it's very obvious. >>> >> > |
| Nero problems in Event Viewer | Software | |||
| Nero problems? | Vista General | |||
| Nero Installations Problems | Vista General | |||
| Problems watching DVD with Nero | Vista music pictures video | |||
| RE: Problems watching DVD with Nero | Vista music pictures video | |||
