Vista - Problems using Nero 6 and 7
Old 10-30-2006   #21 (permalink)
Bill
Re: Problems using Nero 6 and 7
"Clark" <who@whoknows.com> wrote in message
news:eduZLN5%23GHA.896@TK2MSFTNGP03.phx.gbl...
> Well, the mp4 file worked fine. Any other suggestions to track this
> down?
The problem is NOT related to playing a movie, only to viewing the
prevew image in the icons. This was mentioned in my other post and has
been stripped out of this one. I'll add it back in so you can
understand the problem more clearly:
The issue is a driver conflict when you browse a folder with icons
that show preview images of the mpeg file within the icons. If you
change the display to list, detail, or small icons where there is no
preview image of the movie, then there is no conflict and the service
continues to run properly.
Switch to large or medium icons, or tiles, and the service will
immediately crash with an error when trying to render the preview
image in the icons.
This is a problem with the drivers provided from Nero. It's
obviously a driver conflict that Ahead overlooked - which is odd,
because the default view is tiled icons which most people would have
set in explorer.
Old 10-30-2006   #22 (permalink)
Clark
I understand the problem. As I said, the mp4 file works fine when I browse.
Since you have been unwilling to give specifics about the file types you are
actually using, I can check nothing else. All types of Icons/thumbnails
work fine with ALL of Nero installed.
As I suggested, check which program controls them. Do they show with an
Nero Icon or something else. When you installed Nero, did you allow it to
associate all the file types with itself?
Maybe there is an Icon Cache that needs to be rebuilt. Maybe a setting in
Folder options, like "always show Icons-never thumbnails"- might help.
Anyway, Nero works on my system, so there must be something on yours causing
the problem. You need to start somewhere. Download one of the mp4 movie
trailers and put it in it's own folder and see if it crashes. My thumbnail
for the mp4 file is a green film strip with a small Nero logo on the lower
right.
Clark
"Bill" <bill@c.a> wrote in message
news:wuKdnd1tpK2MfNjYnZ2dnUVZ_t6dnZ2d@golden.net...
>> down?
> The problem is NOT related to playing a movie, only to viewing the prevew
> image in the icons. This was mentioned in my other post and has been
> stripped out of this one. I'll add it back in so you can understand the
> image in the icons.
> set in explorer.
Old 10-30-2006   #23 (permalink)
Bill
news:%23jCKkTC$GHA.4196@TK2MSFTNGP03.phx.gbl...
>browse. Since you have been unwilling to give specifics about the
>file types you are actually using, I can check nothing else. All
>types of Icons/thumbnails work fine with ALL of Nero installed.
I haven't tried MP4 yet, but the other movie formats cause the Dllhost
COM Surrogate service to crash when displaying previews of MPG2, WMV,
and I think AVI files.
Windows Media Player.
> Do they show with an Nero Icon or something else. When you
> installed Nero, did you allow it to associate all the file types
> with itself?
No association changes because I didn't install all of Nero this last
time.
> setting in Folder options, like "always show Icons-never
While changing the display type prevents the host service from
crashing, that is not a fix to the problem. There should not be an
error of any kind.
> causing the problem. You need to start somewhere.
Vista and Nero were the only two programs on the computer. I did a
clean install of Vista when this happened and put Nero back in, and it
crashes the service. I read one report of the service crashing without
Nero installed, but it was probably related to another program and its
driver.
Google for vista and com surrogate:
http://www.iexbeta.com/wiki/index.ph...atibility_List
http://windowsvistablog.com/blogs/wi...ers_2100_.aspx
http://shellrevealed.com/forums/thread/4476.aspx
Old 10-30-2006   #24 (permalink)
Clark
OK, so if you go to the C:\Users\Public\Videos\Sample Videos folder and
open it, you get this crash? The large thumbnails show pictures of a bear,
etc. If I double click one of them, Nero Showtime starts and plays the
video. I can of course change that if I right click and change the program
set to handle file. If you just have problems with .avi files, I can
certainly understand that since Nero has been having that problem for quite
a while.
Other than the fact is seems OK on my system, the only references I can find
refer to Php or IIS. If you run either of those, it might be related.
Otherwise, I wonder if the video driver might be involved, or perhaps
something else you are running. If you both have the same problem, you
might try to compare what software and devices you might have in common.
If I find anything, I will post back.
Clark
news:cdedncC2bZ0jkNvYnZ2dnUVZ_oednZ2d@golden.net...
>>browse. Since you have been unwilling to give specifics about the file
>>types you are actually using, I can check nothing else. All types of
> I haven't tried MP4 yet, but the other movie formats cause the Dllhost COM
> Surrogate service to crash when displaying previews of MPG2, WMV, and I
> think AVI files.
>> Do they show with an Nero Icon or something else. When you installed
>> Nero, did you allow it to associate all the file types with itself?
> time.
>> in Folder options, like "always show Icons-never thumbnails"- might help.
> While changing the display type prevents the host service from crashing,
> that is not a fix to the problem. There should not be an error of any
> kind.
> Vista and Nero were the only two programs on the computer. I did a clean
> install of Vista when this happened and put Nero back in, and it crashes
> the service. I read one report of the service crashing without Nero
> installed, but it was probably related to another program and its driver.
Nero problems in Event Viewer Software
Nero problems? Vista General
Nero Installations Problems Vista General
Problems watching DVD with Nero Vista music pictures video
RE: Problems watching DVD with Nero Vista music pictures video
