How Do I Remove System Sounds?
  1. #1
    Shane Guest
    I just removed Ipswitch's WS_FTP 2007, but the system sounds associated with
    the program did not uninstall with it. How do I manually remove the system
    sounds in Control Panel?
    Thanks,
    Shane.
    Windows Vista Home Premium SP2
  2. #2
    Alan Edwards Guest
    Re: How Do I Remove System Sounds?
    Try removing the Registry keys with Regedit.
    I don't have WS_FTP but it is probably under a key like:
    HKEY_USERS\.DEFAULT\AppEvents\Schemes\Apps\WS_FTP
    You should see the names of the sounds in the subkeys.
    If the .wav files are also still there, then take a note of them and
    remove them.
    ....Alan
    Alan Edwards, MS MVP Windows - Internet Explorer
    http://dts-l.com/index.htm
    On Wed, 8 Jul 2009 23:04:39 -0600, in
    microsoft.public.windows.vista.general, "Shane"
    >Thanks,
    >Shane.
  3. #3
    Jon Guest
    "Alan Edwards" <edwards@xxxxxx> wrote in message
    news:lt0b55dph69crsc32ssinigp52vu3r90lg@xxxxxx
    > remove them.
    Also remove relevant keys / values under
    HKEY_CURRENT_USER\AppEvents
    Jon
  4. #4
    Alan Edwards Guest
    On Thu, 9 Jul 2009 07:23:49 +0100, in
    microsoft.public.windows.vista.general, "Jon"
    >> remove them.
    Not necessary.
    They are the same keys.
    ....Alan
    R
  5. #5
    Jon Guest
    news:d9cb55psaat2821km1f7684noia7hjmvlf@xxxxxx
    > Not necessary.
    No, they differ.
    HKEY_USERS\.DEFAULT contains default settings for newly created users ie
    *future* user accounts
    HKEY_CURRENT_USER designates the current user
    So if you change only under 'HKEY_USERS\.DEFAULT', it will have no effect on
    the current user.
    Jon
  6. #6
    Shane Guest
    Thanks for your answers.
    There are fourteen system sounds left over from WS_FTP, and it seems that
    each system sound has four entries in the registry. For example, this change
    event appears in the following four locations:
    HKEY_CURRENT_USER\AppEvents\EventLabels\WSFTP_ChgUp
    HKEY_CURRENT_USER\AppEvents\Schemes\Apps\.Default\WSFTP_ChgUp
    HKEY_USERS\S-1-5-21-3132765019-448504513-1931188874-1000\AppEvents\EventLabels\WSFTP_ChgUp
    HKEY_USERS\S-1-5-21-3132765019-448504513-1931188874-1000\AppEvents\Schemes\Apps\.Default\WSFTP_ChgUp
    I have no idea who the "S-1-5-21-3132765019-448504513-1931188874-1000" user
    is.
    So, for each of the fourteen system sounds, do I delete the four registry
    keys? Do I have to reboot my computer for the changes to take effect?
    Thanks,
    Shane
How Do I Remove System Sounds? problems?
System and app sounds don't always play rmo555 Vista performance & maintenance 0 20 Oct 2009
How Do I Remove System Sounds? Shanester Sound & Audio 0 15 Jul 2009
System sounds and notification sounds have stopped working in wind Ant Vista General 0 30 Jan 2008
No system sounds or internet sounds. but media still works hayatosan Vista General 0 09 Sep 2007
System Alert Sounds =?Utf-8?B?Qm9i?= Vista General 2 18 Sep 2006
