Vista - Windowsize-problem
Old 07-09-2009   #1 (permalink)
Filips Benoit
Windowsize-problem
Dear all,
Since we moved from Windows XP to vista ( windowserver2008) we have this
resting problem:
Officeversion 2003 unchanged.
Remote desktop brings the user to a access-program to make excel-documents
for the clients.
( The access-program is necessary for serveral reasons)
Opening a excel-file from access with VBA should open excel-files with a
maximezed window.
( .Application.WindowState = xlMaximized)
This worked fine with previous OS (Windows XP).
Now it opens minimezed.
But the not-admin-user does not have a start-menu on his desktop in remote
desktop on the server.
So he only can show the open file using ALT-TAB, but we prefer to open it
directly in maximized window.
WHAT SHOULD I DO ???
Filip
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
fixed unable to delete email problem, now I have new problem Vista mail
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
