| | Different System Restore Dialog Box For some odd reason, when I open System Restore, I'm presented with a different dialog screen than I was before. Before, I was presented with a screen that had already select the most recent restore point allowing me to select, I Believe, 'Choose another restore point'. Now I'm not presented with these choices. I only see a Next and a Cancel button and a space where the choices were. When I click Next I see a list of restore points, just like before. But, that first screen is definitely different than what I used to see. Has anyone any idea how I can get the old screen back?? Any help will be appreciated. James |
| | Re: Different System Restore Dialog Box A Vista update seemed to have fixed the problem. I believe it was an activex update that fixed it. I installed a 'Visual Styles' software and it seemed to have occurred after that. I noticed it when I went toSystem Restore after deciding I don't want this software. Although I'm not sure how long the dialog was like that 'cause I haven't done a restore in a while. But it seems to be ok now. If anyone has had this experience, please let me know. James "JamesJ" <jjy@xxxxxx_roadrunner.com> wrote in message news:uh4T6ENBKHA.4984@xxxxxx Quote: > For some odd reason, when I open System Restore, I'm presented with a > different dialog screen than I was before. Before, I was presented with > a screen that had already select the most recent restore point allowing me > to select, I Believe, 'Choose another restore point'. Now I'm not > presented > with these choices. I only see a Next and a Cancel button and a space > where > the choices were. When I click Next I see a list of restore points, just > like before. > But, that first screen is definitely different than what I used to see. > Has anyone any idea how I can get the old screen back?? > > Any help will be appreciated. > James > > |
| System Restore Task - Change Automatic Restore Point Schedule | Tutorials | |||
| System Restore error (create restore point), event ID: 8193 | Vista General | |||
| System Restore: do restore points persist after a restore? | Vista General | |||
| System Restore dialog slows to open with Vista? | Vista General | |||
| system restore not creating system restore everyday | Vista General | |||
