Annoying startup error: delete WPDNSE folder help! RC1
  1. #1
    pwrwin Guest
    Hi. For the past two days whenever I start up my computer I receive a popup
    window:
    This folder is shared with other people. If you delete this folder, it will
    no longer be shared.
    Folder: C:\Users\****\AppData\Local\Temp\WPDNSE
    Share Name: C:\Users\****\AppData\Local\Temp\WPDNSE
    Then it tells me to continue or to cancel. Nothing seems to happen if I
    choose either one, only that WPDNSE gets deleted - just to return again when
    I reboot (or log off - log in). For some reason, this only seems to happen on
    my administrator account - my regular user account does not receive this
    message. I had no installed any new hardware or software, so I'm really
    confused here. I installed CCleaner to try and see if cleaning out my
    system/registry could get rid of the message, but it didn't.
    Any help?
    Windows Vista RC1 Build 5600
  2. #2
    M. Murcek Guest
    Re: Annoying startup error: delete WPDNSE folder help! RC1
    A quick Google shows nobody is quite sure what it is, but it is being
    discussed in English, French, Russian and Japanese. Anytime a folder gets
    erased, but returns on reboot, it means that somwhere a hidden copy probably
    exists and it's being restored on a directive from a registry entry or other
    spyware like entry point. Apparently none of the major spyware sites have
    anything on it yet, so it could be something else. It could be someone's
    content protection scheme (remember the Sony debacle last fall?) Sorry all
    I can offer is maybe...could be...etc. but that's all there is out there
    right now. If you want to know how the pros find this stuff, go look up
    Mark Russinovich's blog entries on the Sony Rootkit -
    http://www.sysinternals.com/blog/200...al-rights.html
    "pwrwin" <pwrwin@discussions.microsoft.com> wrote in message
    news:ECCA422C-3FF9-484F-93D5-845C9570A66F@microsoft.com...
    > popup
    > window:
    > will
    > when
    > on
    > Any help?
  3. #3
    Jane C Guest
    It only seemed to happen in RC1 x86, not in RC1 x64. It doesn't happen in
    later builds.
    > popup
    > window:
    > will
    > when
    > on
    > Any help?
Annoying startup error: delete WPDNSE folder help! RC1 problems?
Annoying startup error BT14 General Discussion 8 12 Mar 2009
Still Annoying- Delete/Rename Ricks Desktop General Discussion 2 10 Mar 2009
I can't delete a message, so annoying! asad_raza5367 Vista mail 2 05 Nov 2008
Desktop Blink at Startup - ANNOYING frustratedguy Vista performance & maintenance 5 25 May 2007
Error when trying to delete "Deleted Folder fedup2here Vista mail 1 27 Feb 2007
