Vista - Vista home 32 bit recovery disks not labeled help?
Old 07-22-2009   #1 (permalink)
Vista Home Premium 32bit
My son sent me his Compaq laptop w/Vista installed and it wouldn't boot at all. Finally got it restored by using F11 and it is booting up again. They sent me 3 recovery disks, however none of them are labeled, so, I was hoping someone could help me get them labeled correctly because I am always the one in the family everyone calls when there are computer problems.
When I explore the disks there are folders as follows:
One disk has folder called: Preload
Next disk has folders called: Boot and preload
Third disk has folders called: Preload and tools.
Anyone know how these would be labeled correctly??
Thanks in advance!
Old 07-22-2009   #2 (permalink)
David B.
Re: Vista home 32 bit recovery disks not labeled help?
This would be a question for Compaq support, how are we supposed to know
which Compaq restore CD is what?
"trulyblest" <guest@xxxxxx-email.com> wrote in message
news:f5b519a776059d475a98219e8ed3cd31@xxxxxx-gateway.com...
Quote:
> Hi,
> problems.
> *When I explore the disks there are folders as follows:*
> Thanks in advance!
> trulyblest
Old 07-22-2009   #3 (permalink)
DaveD
On my HP, when I load the recovery disks, Explorer shows their labels as
Recovery13, Recovery23, and Recovery33.
I hope that helps.
Quote:
> Hi,
> problems.
> Thanks in advance!
> trulyblest
Old 07-22-2009   #4 (permalink)
Gene E. Bloch
On Wed, 22 Jul 2009 15:12:19 -0500, trulyblest wrote:
Quote:
> Hi,
> problems.
> Thanks in advance!
1. I would start with Boot and preload. Its name has that magic ring to it:
Boot.
2. There are three disks, hence six possible sequences. You could just try
all six.
3. Compaq might know.
4. If only one of the disks boots, there are only two sequences left to
try: the second next, or the third next.
Gene E. Bloch letters0x40blochg0x2Ecom
Old 07-22-2009   #5 (permalink)
Bill Daggett
trulyblest <guest@xxxxxx-email.com> wrote:
Quote:
>Hi,
>problems.
Since F11 worked, the recovery partition is intact and you should
still be able to make your own discs.
Contact HP/Compaq support and find out how to make your own discs...
and label them when you're done.
Old 07-22-2009   #6 (permalink)
LVTravel
Quote:
> Hi,
> problems.
> Thanks in advance!
> trulyblest
From my new Compaq Vista Laptop the recovery disks are
Disk 1 has the following folders: Boot, HP, preload, Sources and is labeled
Recovery 13
Disk 2 is: preload and is labeled Recovery 23
Disk 3 is: preload and tools and is labeled Recovery 33
Old 07-22-2009   #7 (permalink)
webster72n
Quote:
> Hi,
> problems.
#2, 1 and 3 seems to be the way to go.
On the other hand they'll only work in the proper sequence.
Therefore you are the master.
Good luck,
Harry.
Quote:
> Thanks in advance!
> trulyblest
Old 07-22-2009   #8 (permalink)
Bill Daggett
>Recovery 13
That'll work.
Old 07-22-2009   #9 (permalink)
Thank you LVTravel, that's exactly what I was looking for. I appreciate it very, very much!!
Thanks to the others for trying!
Quote  Quote: Originally Posted by LVTravel View Post
Quote:
> Hi,
> problems.
> Thanks in advance!
> trulyblest
Recovery 13
Old 07-23-2009   #10 (permalink)
LVTravel
news:0403f185c83678d9d3f2bac2bfd8f3d3@xxxxxx-gateway.com...
> LVTravel;1096373 Wrote:
>> news:f5b519a776059d475a98219e8ed3cd31@xxxxxx-gateway.com...> > >
Quote:
>> > > Hi,
>> > boot
>> > again.
>> > I
>> > am
>> > > problems.
>> > > Thanks in advance!
>> > > trulyblest > >
>> labeled
>> Recovery 13
> trulyblest
Thanks for posting back.
Vista Backup Recovery Disks Tutorials
Recovering PC factory condition with recovery disks w/ 64 bit vista premium (problem) Vista General
Using recovery disks to install Vista to new non-factory HD General Discussion
Recovery Disks with Vista Vista General
Vista Complete PC Recovery - Different Disks? Vista performance & maintenance
