Vista - Start-Up Repair will NOT work. Will not boot Vista.
Old 07-23-2009   #1 (permalink)
PleaseHelpASAP
I have an Acer Extensa laptop with Windows Vista Home Premium installed.
Its been working great for over a year now untill yesterday when all of
a sudden it wouldn't boot up properly. It continued to go to start-up
repair, but that kept on failing. After trying all other tools, (system
restore had no restore points for some odd reason)... I tried safe mode.
That did not work. It instead went back to the start-up repair screen.
The same warning message popped up everytime it failed "Cannot repair
automatically, click finish blah blah blah". When I bought this laptop
from Best Buy, I did not recieve any type of Disk for Vista, it was
already loaded on there... I would rather not do a clean install and
hope there is another way to fix this. Thank you.
PleaseHelpASAP
PleaseHelpASAP's Profile: http://forums.techarena.in/members/117626.htm
View this thread: http://forums.techarena.in/vista-help/1219332.htm
Old 07-23-2009   #2 (permalink)
PleaseHelpASAP
Re: Start-Up Repair will NOT work. Will not boot Vista.
Just checked and the "chkdsk/f" will not work on command prompt, says
drive is in use and instead of booting up at start up repair continues
to come up.
PleaseHelpASAP
Old 07-23-2009   #3 (permalink)
Bill Daggett
"Randem" <newsgroups@xxxxxx> wrote:
Quote:
>That is a common problem with Vista.
No it's not.
Old 08-19-2009   #4 (permalink)
Unknowning
I have the same problem and I did everything specified above, I ran
chkdsk/f from vista's recovery cd that I downloaded and it changed
nothing. I'm at a dead end here I don't want to have to reinstall vista
and my drivers.
Unknowning
Unknowning's Profile: http://forums.techarena.in/members/126416.htm
Solved Vista won't start - Startup Repair can't.. what next General Discussion
Solved Vista repair does not work General Discussion
Vista Boot Repair Vista General
Vista won't boot or repair Vista General
Windows will not start, repair fails, restore won't work. Vista hardware & devices
