Vista - System restore
Old 10-25-2006   #1 (permalink)
Jerry P
System restore
I like to backup a certain restore date to a DVD disk or to another drive.
Can this be done, if so where is the file with the restore name I gave it
located?
Old 10-25-2006   #2 (permalink)
peter
Re: System restore
First of all "Restore" is that part of Vista that "saves" settings at a
preset point in time
Restore is also a function under the "backup" program.
Restore points created by "Restore" cannot be copied
Backup can create a backup of your HD/programs/files and these can be saved
toa CD/DVD and then restored when needed.
peter
"Jerry P" <alpha7878@comcast.net> wrote in message
news:9D4EDA3B-EC50-4342-B0C3-F812AFB3CB01@microsoft.com...
>located?
Old 10-25-2006   #3 (permalink)
Rick Rogers
Re: System restore
You can't, and even if you could you wouldn't be able to restore that date.
If you want to preserve the system "as is" for a specific time, you should
look into imaging software.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
>located?
Old 10-25-2006   #4 (permalink)
Jerry P
Re: System restore
Peter, I been playing with PC's since the mid 70's. When you had to write
your programs in DOS. I completely understand how the backup works. I been
doing it for yrs & yrs, for work/home. I was just curious how it saved it to
disk. I have more backups of my system, just in case.
"peter" <peter@nowhere.net> wrote in message
news:Oevy92J%23GHA.3392@TK2MSFTNGP05.phx.gbl...
> saved toa CD/DVD and then restored when needed.
> peter
>>located?
Old 10-25-2006   #5 (permalink)
Jerry P
Re: System restore
Thanks Rick, just curious.
Jerry
"Rick Rogers" <rick@mvps.org> wrote in message
news:uH9mx$J%23GHA.1128@TK2MSFTNGP05.phx.gbl...
> Hi,
> date. If you want to preserve the system "as is" for a specific time, you
> should look into imaging software.
> Best of Luck,
>>located?
Old 10-25-2006   #6 (permalink)
Chad Harris
Re: System restore
Jerry--
I don't think you can. System restore points are volume shadow copy backup
in Vista. You can get familiar with how it works in Vista (different from
the XP registry snapshots) here. If Jill Zoeller [MSFT] or someone else
knows a way to "backup" a particular restore point, then I'd welcome seeing
it. Why not just make timely backups using backup in Vista (Charley Russell
is doing a web cast on it tomorrow and the webcast will be archived):
The link is here at from Jill Zoeller's blog "The Filing Cabinet":
We just received a link from one of our MVPs to a webcast he's hosting on
October 26 at 10:00 AM Pacific Time. Below is a bio and overview of the
webcast."
Webcast on Backup in Vista
http://blogs.technet.com/filecab/arc...vista-rc1.aspx
System Restore
http://www.microsoft.com/technet/win...77cd8104d.mspx
System Restore
http://blogs.technet.com/filecab/arc...ble-files.aspx
http://blogs.technet.com/filecab/pages/447166.aspx
CH
>located?
Old 10-26-2006   #7 (permalink)
Jill Zoeller [MSFT]
Re: System restore
You can use Complete PC Backup to make an image of your system at the
date/time you want. You are given the choice to save the backup to another
partition or DVD when you create it.
Want to learn more about Windows Server file and storage technologies? Visit
our team blog at http://blogs.technet.com/filecab/default.aspx.
>located?
Old 10-26-2006   #8 (permalink)
Jerry P
Re: System restore
Thanks Chad. I was just looking to see how the file system worked using
backup. This blog told me what I wanted to know.
Jerry
"Chad Harris" <Vista RTM is really Beta 1.net> wrote in message
news:%2373ewYK%23GHA.4428@TK2MSFTNGP04.phx.gbl...
> Jerry--
> backup in Vista. You can get familiar with how it works in Vista
> (different from the XP registry snapshots) here. If Jill Zoeller [MSFT]
> or someone else knows a way to "backup" a particular restore point, then
> I'd welcome seeing it. Why not just make timely backups using backup in
> Vista (Charley Russell is doing a web cast on it tomorrow and the webcast
> will be archived):
> webcast."
> System Restore
> System Restore
> CH
>>located?
Old 10-26-2006   #9 (permalink)
peter
Re: System restore
good to know......
and now you know that "restore points" cant be saved to CD/DVD
peter
news:3DE71917-753C-451F-BA06-BBF4FEFDC309@microsoft.com...
> to disk. I have more backups of my system, just in case.
>> peter
>>>drive. Can this be done, if so where is the file with the restore name I
>>>gave it located?
System Restore Task - Change Automatic Restore Point Schedule Tutorials
System Restore error (create restore point), event ID: 8193 Vista General
System Restore: do restore points persist after a restore? Vista General
System restore hasn't held a restore point since I installed Vista Vista General
system restore not creating system restore everyday Vista General
