| | How to remove Invalid entry from Programs and Features...? Hi, How can we remove invalid or incorrect entries from Programs and Features manually...? Oc9ine. |
| Vista x64 Ultimate SP2, Windows 7 Ultimate x64 | Re: How to remove Invalid entry from Programs and Features...? Hello Oc9ine, This tutorial can help show how to remove a entry manually. Programs and Features - Remove Uninstall Entry Hope this helps, Shawn |
| | Re: How to remove Invalid entry from Programs and Features...? oc9ine <oc9ine@xxxxxx> wrote: Quote: >Hi, > >How can we remove invalid or incorrect entries from Programs and >Features manually...? > >Oc9ine. out CCleaner: http://www.ccleaner.com/ You can either uninstall, rename or REMOVE an entry using that program and the Tools/Uninstall function. |
| Programs and Features - Remove Uninstall Entry | Tutorials | |||
| Unable To Remove Uninstalled Programs From "Programs And Features". | Software | |||
| Programs and Features - Invalid entries | Vista General | |||
| No Uninstall entry in "Add/Remove programs" | Vista installation & setup | |||
| Invalid boot entry | Vista General | |||
