| | Audio Devices I have a USB headset that I leave plugged in 24x7. I use it for a VoIP application that I run pretty frequently. I also have a standard pair of speakers/subwoofer. Both devices have the appropriate drivers installed and are functional. My question is this. Aside from application settings, is there any way to control which audio device a program will use? Say I'm running some third party software for playing MP3s. I have my headset on and decide that I want to take it off and shift my audio output for *one* particular application to my speakers instead. Assuming this application doesn't have an internal setting for device output, is there a way to quickly shift the audio to my speakers? Thanks! |
| | Re: Audio Devices That's a great question that isn't answered in XP or in Vista. Your drivers should include some sort of utility for controlling/re-directing output on the fly, but I think it's over their heads. Of course, in the Windows sound control panel, you can change preferred devices, but it's sure a pain in the neck to go do that just because you have a Skype call coming in . . . One of these days, PCs will be user-friendly. And we'll all look back at 2007, and we'll laugh. -- Dave "James" <minorkeys@gmail.com> wrote in message news:elf%236ZR%23GHA.4472@TK2MSFTNGP05.phx.gbl... >I have a USB headset that I leave plugged in 24x7. I use it for a VoIP >application that I run pretty frequently. I also have a standard pair of >speakers/subwoofer. Both devices have the appropriate drivers installed >and are functional. > > My question is this. Aside from application settings, is there any way to > control which audio device a program will use? Say I'm running some third > party software for playing MP3s. I have my headset on and decide that I > want to take it off and shift my audio output for *one* particular > application to my speakers instead. Assuming this application doesn't > have an internal setting for device output, is there a way to quickly > shift the audio to my speakers? > > Thanks! > |
| no audio output devices installed | Vista General | |||
| Devices>Recording: "No Audio Devices Found" | Sound & Audio | |||
| No audio devices are installed in recording | Sound & Audio | |||
| Multiple Audio Devices | Sound & Audio | |||
| Problems using multiple audio devices | Vista music pictures video | |||
