Vista - Problems with upgrading
Old 07-27-2009   #1 (permalink)
inkedXgirl
A month ago I up grade my computer from windows viast to basic to vista
home premium only then realizing I only had a key for vista basic. I
tried to downgrade but my computer wont work. It just loads up blank
with out a screen. It will load normally then it will have me enter my
password but after that the screen is black and you can see my mouse. I
have no idea what to do please help me. I am tired of using a laptop it
doesn't have enough memory for my school work.
Thanks
inkedXgirl
inkedXgirl's Profile: http://forums.techarena.in/members/118854.htm
View this thread: http://forums.techarena.in/vista-help/1221445.htm
Old 07-28-2009   #2 (permalink)
Gordon
Re: Problems with upgrading
"inkedXgirl" <inkedXgirl.3w09vb@xxxxxx> wrote in message
news:inkedXgirl.3w09vb@xxxxxx
> Thanks
You will need to restore the machine to it's prior state by whatever method
your vendor gave you. If you have data that you need, then you must make a
copy of that data onto an external devoice (CD/DVD, thumbdrive, external HDD
etc) before you do so.
Old 07-28-2009   #3 (permalink)
Gordon's Psychiatrist
>> Thanks
> method your vendor gave you. If you have data that you need, then you
> must make a copy of that data onto an external devoice (CD/DVD,
> thumbdrive, external HDD etc) before you do so.
Err <sigh> he needs to back up his data Err. Then he needs to Err
restore his system. Err.
Problems upgrading Vista installation & setup
Problems upgrading from 32 bit to 64 bit! General Discussion
Need Help Please!! Problems with upgrading General Discussion
Upgrading hardware - will it cause problems? Vista General
