Vista - 64-bit versus 32-bit Vista
Old 08-01-2009   #1 (permalink)
MAT
On Windows Vista Compatibility Center
http://www.microsoft.com/windows/compatibility/ is a list of
32-bit/64-drivers and compatibility.
Non-compatible drivers to Vista 64-bit is apparently still a problem no
matter what is listed on the Windows Vista compatibility page.
I've just bough a PC with the i7 Intel processor, 6 GB RAM including the
64-bit Vista version.
According to my net-bank using Java from Sun Microsystem I have to use the
32-bit version of Internet Explorer if I wanna use the net-bank since the
drivers are not compatible to the 64-bit version.
3 questions:
How do I force the installation of Internet Explorer to be 32-bit and not
64-bit version?
Is there a trick to have both Internet Explorer 32- bit and 64-bit on the
same PC?
Do I have to have another PC with 32-bit Vista if I wanna use programs with
32-bit drivers not compatible to Vista 64-bit,
or is it possible to configure the PC to have both 32-bit Vista and 64-bit
Vista?
Old 08-01-2009   #2 (permalink)
Richard Urban
Re: 64-bit versus 32-bit Vista
The standard browser in 64 bit Vista IS a 32 bit program. You have to
purposefully start the 64 bit version of Internet Explorer, which does not
allow flash player to operate. It will say Internet Explorer (64 bit).
So, if you can not access your banking site with the 32 bit version of I.E.
you do not have Adobe Flash Player installed or the install is corrupted
somehow.
Richard Urban
Microsoft MVP
Windows Desktop Experience
"MAT" <non-exit@xxxxxx-exit.com> wrote in message
news:%23cMlyVqEKHA.4316@xxxxxx
> 3 questions:
> 64-bit version?
> same PC?
> with 32-bit drivers not compatible to Vista 64-bit,
> Vista?
Old 08-01-2009   #3 (permalink)
MAT
Thanks for prompt answer:
I'll continue using the 32-bit version of IE8 using the 64-bit Vista and see
if I have access to my bank account when I receive my new security code (to
the new PC).
I didn't know that IE as standard was 32 bit and that the flash player was
the issue.
Concerning the flash player according to the Windows Vista compatibility
page Adobe Flash Player 9 and 10 are 64-bit compatible
http://www.microsoft.com/windows/com...ayer&os=64-bit
"Richard Urban" <richardurbanREMOVETHIS@xxxxxx> skrev i meddelelsen
news:%23EiNgcqEKHA.4316@xxxxxx
> I.E. you do not have Adobe Flash Player installed or the install is
> corrupted somehow.
> Richard Urban
> Microsoft MVP
>> the 32-bit version of Internet Explorer if I wanna use the net-bank since
>> the drivers are not compatible to the 64-bit version.
>> 3 questions:
>> 64-bit version?
>> same PC?
>> 64-bit Vista?
Old 08-01-2009   #4 (permalink)
Mike Hall - MVP
news:ez$XvdrEKHA.4376@xxxxxx
> see if I have access to my bank account when I receive my new security
> code (to the new PC).
> the issue.
>> not allow flash player to operate. It will say Internet Explorer (64
>> bit).
>> corrupted somehow.
>> Richard Urban
>> Microsoft MVP
>>> since the drivers are not compatible to the 64-bit version.
>>> 3 questions:
>>> not 64-bit version?
>>> the same PC?
>>> 64-bit Vista?
Not according to Adobe.. just tried it here..
Mike Hall - MVP Windows Experience
http://msmvps.com/blogs/mikehall/
Old 08-01-2009   #5 (permalink)
Dominic Payer
32-bit Flash Player 10 is compatible with 64-bit Windows - it needs no
64-bit components.
Sometime - unspecified - in the future there will be a 64-bit Flash
Player. See http://kb2.adobe.com/cps/000/6b3af6c9.html
>> and see if I have access to my bank account when I receive my new
>> security code (to the new PC).
>> was the issue.
>> compatibility page Adobe Flash Player 9 and 10 are 64-bit compatible
>> meddelelsen news:%23EiNgcqEKHA.4316@xxxxxx
>>> does not allow flash player to operate. It will say Internet Explorer
>>> (64 bit).
>>> of I.E. you do not have Adobe Flash Player installed or the install
>>> is corrupted somehow.
>>> Richard Urban
>>> Microsoft MVP
>>>> no matter what is listed on the Windows Vista compatibility page.
>>>> the 64-bit Vista version.
>>>> use the 32-bit version of Internet Explorer if I wanna use the
>>>> net-bank since the drivers are not compatible to the 64-bit version.
>>>> 3 questions:
>>>> and not 64-bit version?
>>>> on the same PC?
>>>> programs with 32-bit drivers not compatible to Vista 64-bit,
>>>> 64-bit Vista?
Old 08-01-2009   #6 (permalink)
Vista home premium 32bit
Quote  Quote: Originally Posted by Dominic Payer View Post
64-bit components.
Player. See Flash Player support on 64-bit operating systems
>> was the issue.
Would it not be the easiest to use another browser - Chrome, Opera, Safari or FF.
Old 08-01-2009   #7 (permalink)
Keith H
You can install both 32-bit and 64-bit Java, this way javascript should work
regardless of the bit-ness of the browser..
Update Release Notes: http://java.sun.com/javase/6/webnotes/ReleaseNotes.html
Download @ http://www.java.com/en/download/manual.jsp
This will take you to where you can select Java SE Runtime Environment 6u14 (it
seems 6u15 has been pulled).. Select and download 'Windows' and 'Windowsx64'
~k
Old 08-02-2009   #8 (permalink)
Poutnik
In article <l4CdnXtqarjCY-nXnZ2dnUVZ_hOdnZ2d@xxxxxx>, keherma.
@.epix.net says...
It looks like common confusion.
Javascript as interpreted script language,
hosted either by browsers, either by Windows scripting host,
has nothing in common but name with Java and Java applets.
Poutnik
The best depends on how the best is defined.
Old 08-02-2009   #9 (permalink)
Richard Urban
Yes it is. But read the following from the Adobe page you linked to:
Adobe Flash Player is not supported for playback in a 64-bit browser.
Richard Urban
Microsoft MVP
"Dominic Payer" <dcp@xxxxxx> wrote in message
news:%23YokHSsEKHA.4168@xxxxxx
> 64-bit components.
>>> was the issue.
>>>> (64 bit).
>>>> Richard Urban
>>>> Microsoft MVP
>>>>> 3 questions:
>>>>> on the same PC?
>>>>> 64-bit Vista?
Old 08-03-2009   #10 (permalink)
MAT
Hi again:
According to this link to Adobe
http://labs.adobe.com/technologies/flashplayer10/ Adobe Flash Player 10
released 7/30/09 is 64-bit compatible (4 days ago).
Version 10.0.32.18 is downloadable from http://get.adobe.com/flashplayer/
The other link (mentioned earlier in this thread)
http://kb2.adobe.com/cps/000/6b3af6c9.html indicating that Adobe Flash
Player 10 is not supported for playback in a 64-bit browser, was apparently
an old information last updated 2008-10-14.
news:%23X$zjC4EKHA.1340@xxxxxx
> Richard Urban
> Microsoft MVP
>> 64-bit components.
>>>> was the issue.
>>>>> (64 bit).
>>>>> Richard Urban
>>>>> Microsoft MVP
>>>>>> 3 questions:
>>>>>> on the same PC?
>>>>>> 64-bit Vista?
Vista Versus XP General Discussion
Vista versus XP Vista General
8.5 versus 2008 versus 9 Live Messenger
Vista versus Leopard Vista General
Vista versus XP Backup Vista General
