Vista - Audio breakup
Old 08-01-2009   #1 (permalink)
carl43m
Audio breakup
I have vista home premium with a 256MB Radeon 2600 XT video card. I am
continually having problems with streaming audio breaking up. Sometimes
there are no issues and other times once it starts I have to reboot the pc in
order for the audio to work correctly again. This happens with streaming
video from you tube, Rhapsody or any number of news web sites where I am
watching a video. My pc has 4GB of Ram and 260 GB of hard drive memory. I
never have an audio issue if I am playing something that resides on my pc,
ie. a game or musicon hard drive.
I have 10 Mbps of internet connect speed so that shouldn't be the issue.
And as I pointed out--if I do a reboot everything works fone for another day
or so. Does anyone have any idea as to what might be the issue and how to
fix it? Thanks.
Old 08-01-2009   #2 (permalink)
Vista Buisness X32
Re: Audio breakup
It sounds like a bandwidth Issue. I know you have a 10MB Connection but maybe the place you are streaming from is being heavily consumed by other users. Also 10MB connection is most likely cable. How cable internet works is if a lot of users in your area are using a lot of bandwidth at the same time, then your speeds go down. Check your bandwidth by typing into good bandwidth speed test.
SuperXero
Systems Admin - CCNA, MCSE, A+
Old 08-04-2009   #3 (permalink)
Chuck
Re: Audio breakup
IP bandwidth is one factor. Uneven data streaming speed is another. To much
running in background on your P/C is another.
Finally, out of order packets can also be a source of the problem.
http://miranda.ctd.anl.gov Can be a good detailed test for speed and
quality.
"SuperXero" <guest@xxxxxx-email.com> wrote in message
news:b99c6dcd693669f4df022051b5cb3809@xxxxxx-gateway.com...
> SuperXero
> *'HackingManual.Net ' (http://HackingManual.Net)-Because Knowledge Is
> Power*
> SuperXero
How do I get audio file format in audio filter driver? Vista music pictures video
Media Player audio breakup at end of song Vista music pictures video
Audio drivers for Intel Sigmatel onboard audio Vista hardware & devices
Realtek AC'97 audio driver provided by Microsoft. Audio error MCE Vista hardware & devices
Vista Beta 2 - Audio / Sound Drivers - Universal Audio Architectur Vista hardware & devices
