Vista - X86 to 64 not using full potential
Old 08-02-2009   #1 (permalink)
kallides13
Ok so this is the deal I have an Acer laptop pretty new with windows 7
on it its a 32 bit version. When I go to look at my system it says to me
that I have 4 gig of ram but in brackets it is also saying that I am
able to use only 2.99 of it. I have done some research and apparently I
need a 64 bit version of windows which I downloaded but my computer is
X86 based so is there anyway round this? Aprogram that might change
something or am I stuck with 32bit windows then?
Please help
kallides13
kallides13's Profile: http://forums.techarena.in/members/120685.htm
View this thread: http://forums.techarena.in/vista-help/1225108.htm
Old 08-02-2009   #2 (permalink)
Mark Adams
RE: X86 to 64 not using full potential
> Please help
> kallides13
You didn't say what processor your laptop has, most modern processors are 64
bit capable. If the processor is 64 bit capable, drivers still need to be
provided by Acer. Go to the Acer website and locate 64 bit drivers for your
model. If none are available, you won't be able to use a 64 bit OS.
Old 08-02-2009   #3 (permalink)
DaveD
Re: X86 to 64 not using full potential
It's using all your memory. It's just that some of it is reserved for system
use.
It's working fine. Don't worry about it.
Don't get 64 bit Windows unless you have MORE than 4 GB of memory.
"kallides13" <kallides13.3warna@xxxxxx> wrote in message
news:kallides13.3warna@xxxxxx
> Please help
> kallides13
Old 08-02-2009   #4 (permalink)
Mike Hall - MVP
"DaveD" <dd@xxxxxx> wrote in message
news:%234Zk8D6EKHA.3556@xxxxxx
> system
Quote:
Not true.. It is using 3gb of the four available. The rest of the
addressable space up to the 4gb limit is being taken up by the motherboard
resources..
Mike Hall - MVP Windows Experience
http://msmvps.com/blogs/mikehall/
Old 08-02-2009   #5 (permalink)
Ken Blake, MVP
On Sun, 2 Aug 2009 13:42:27 -0500, "DaveD" <dd@xxxxxx> wrote:
> use.
Not correct. Here's the correct info:
All 32-bit client versions of Windows (not just Vista/XP) have a 4GB
address space (64-bit versions can use much more). That's the
theoretical upper limit beyond which you can not go.
But you can't use the entire 4GB of address space. Even though you
have a 4GB address space, you can only use *around* 3.1GB of RAM.
That's because some of that space is used by hardware and is not
available to the operating system and applications. The amount you can
use varies, depending on what hardware you have installed, but can
range from as little as 2GB to as much as 3.5GB. It's usually around
3.1GB.
Note that the hardware is using the address *space*, not the actual
RAM itself. If you have a greater amount of RAM, the rest of the RAM
goes unused because there is no address space to map it to.
> > Please help
> > kallides13
Ken Blake, Microsoft MVP - Windows Desktop Experience
Please Reply to the Newsgroup
Old 08-02-2009   #6 (permalink)
DaveD
A crucial difference! Thanks for the clear explanation.
Potential explorer.exe problems General Discussion
Just a thought or two on potential... Chillout Room
Potential Upgrade Problem Vista General
Potential fix for X-Fi / NForce 4 SCP issue Sound & Audio
