| | Setting 'System managed' page file for d: drive causes high CPU us Hello! Setting 'System managed' page file for my d: drive (EIDE Samsung SP2514N on JMicron JMB363 PATA and SATA controller on my Asus P5K motherboard) causes explorer.exe to use about 90% of CPU after a restart for several minutes and in about 10 minutes intervals during 720p video playback in VLC Player for several minutes. RAM 6GB, CPU Intel E6750. Vista Ultimate x64. I have set 'no page file' for my d: drive (EIDE Samsung SP2514N on my Asus P5K motherboard) and the problem disappeared. Why does setting page file for my d: drive cause the high CPU usage? My d: drive is least frequently used. I have not changed 'System managed' for my G: drive. I have set 'System managed' for my c: drive (WD5005000AACS ATA) too, and the problem have not reappeared. Regards, Dima |
| | Re: Setting 'System managed' page file for d: drive causes high CPU us "Dima" <Dima@xxxxxx> wrote in message news:8F6E54C6-6A17-49CA-8A25-1E2545698950@xxxxxx Quote: > Hello! > Setting 'System managed' page file for my d: drive (EIDE Samsung SP2514N > on > JMicron JMB363 PATA and SATA controller on my Asus P5K motherboard) > causes > explorer.exe to use about 90% of CPU after a restart for several minutes > and > in about 10 minutes intervals during 720p video playback in VLC Player for > several minutes. > RAM 6GB, CPU Intel E6750. Vista Ultimate x64. > I have set 'no page file' for my d: drive (EIDE Samsung SP2514N on my Asus > P5K motherboard) and the problem disappeared. Why does setting page file > for > my d: drive cause the high CPU usage? My d: drive is least frequently > used. > I have not changed 'System managed' for my G: drive. > I have set 'System managed' for my c: drive (WD5005000AACS ATA) too, and > the > problem have not reappeared. > Regards, > Dima each drive......and if these drives are partitions and not physically-separate hard disks then there's no advantage in moving the page file from C drive either.... |
| | Re: Setting 'System managed' page file for d: drive causes high CP Thanks Gordon for your reply! I have 3 HDDs: 2 SATA: C: and G: and one EIDE d:. I do not have logical partitions. MS writes that Windows uses a page file on a less busy HDD at a time. The busyness changes over time, therefore MS recomends to spread a page file over all phisical HDDs. What program can assess performance with different locations of a page file? I want to compare different locations of a page file. Regards, Dima "Gordon" wrote: Quote: > > "Dima" <Dima@xxxxxx> wrote in message > news:8F6E54C6-6A17-49CA-8A25-1E2545698950@xxxxxx Quote: > > Hello! > > Setting 'System managed' page file for my d: drive (EIDE Samsung SP2514N > > on > > JMicron JMB363 PATA and SATA controller on my Asus P5K motherboard) > > causes > > explorer.exe to use about 90% of CPU after a restart for several minutes > > and > > in about 10 minutes intervals during 720p video playback in VLC Player for > > several minutes. > > RAM 6GB, CPU Intel E6750. Vista Ultimate x64. > > I have set 'no page file' for my d: drive (EIDE Samsung SP2514N on my Asus > > P5K motherboard) and the problem disappeared. Why does setting page file > > for > > my d: drive cause the high CPU usage? My d: drive is least frequently > > used. > > I have not changed 'System managed' for my G: drive. > > I have set 'System managed' for my c: drive (WD5005000AACS ATA) too, and > > the > > problem have not reappeared. > > Regards, > > Dima > You only need ONE page file for your entire system - you do NOT need one for > each drive......and if these drives are partitions and not > physically-separate hard disks then there's no advantage in moving the page > file from C drive either.... > |
| | Re: Setting 'System managed' page file for d: drive causes high CP "Dima" <Dima@xxxxxx> wrote in message news:C2058F5C-34DB-40D1-9C5C-09CF8EE332B2@xxxxxx Quote: > Thanks Gordon for your reply! > I have 3 HDDs: 2 SATA: C: and G: and one EIDE d:. I do not have logical > partitions. MS writes that Windows uses a page file on a less busy HDD at > a > time. The busyness changes over time, therefore MS recomends to spread a > page > file over all phisical HDDs. |
| | Re: Setting 'System managed' page file for d: drive causes high CP http://support.microsoft.com/kb/314482 "Gordon" wrote: Quote: > > "Dima" <Dima@xxxxxx> wrote in message > news:C2058F5C-34DB-40D1-9C5C-09CF8EE332B2@xxxxxx Quote: > > Thanks Gordon for your reply! > > I have 3 HDDs: 2 SATA: C: and G: and one EIDE d:. I do not have logical > > partitions. MS writes that Windows uses a page file on a less busy HDD at > > a > > time. The busyness changes over time, therefore MS recomends to spread a > > page > > file over all phisical HDDs. > Never heard that one before - can you post a link to that? > > > > |
| | #6 (permalink) |
| | Re: Setting 'System managed' page file for d: drive causes high CP "Dima" <Dima@xxxxxx> wrote in message news:5DD3A546-2DEC-4FF8-BFE8-B1595131C29D@xxxxxx Quote: i suggest then that you create a very small page file on C for the memory dumps and create a partition on your least-utilised HDD purely dedicated to the second, windows-managed pagefile. (The article only mentioned TWO page files as above, not one on each drive....) |
| Setting 'System managed' page file for d: drive causes high CPU us | Vista hardware & devices | |||
| Setting 'System managed' page file for d: drive causes high CPU us | Vista performance & maintenance | |||
| Getting and setting page file size | PowerShell | |||
| How to move the page file from drive c to other drive? | Vista General | |||
| Managed page file less than recommended | Vista performance & maintenance | |||
