| | faulting module ntdll.dll Hello, I have problems like this iexplore.exe when calling some ActiveX Faulting application iexplore.exe, version 8.0.6001.18813, time stamp 0x4a6621ae, faulting module ntdll.dll, version 6.0.6001.18000, time stamp 0x4791a7a6, exception code 0xc0000374, fault offset 0x000b015d, process id 0x2890, application start time 0x01ca14ee0db44e69. or WScript.exe when calling some ActiveX Faulting application WScript.exe, version 5.7.0.18068, time stamp 0x48235878, faulting module ntdll.dll, version 6.0.6001.18000, time stamp 0x4791a7a6, exception code 0xc0000374, fault offset 0x000b015d, process id 0x19c0, application start time 0x01ca14edec259ba9. on WINXP the same ActiveX no problem, ntdll.dll version on WinXP 5.1.2600.5755. what can I do ? mike |
| | Re: faulting module ntdll.dll That information by itself isn't decipherable. Generally for any non-submitted data report the data you have will be missing a potentially useful data point. You could potentially use the Windows Debugging SDK to track this down further. =\ -- Speaking for myself only. See http://zachd.com/pss/pss.html for some helpful WMP info. This posting is provided "AS IS" with no warranties, and confers no rights. -- "Michal Valent" <valent@xxxxxx> wrote in message news:ewe6THPFKHA.4220@xxxxxx Quote: > Hello, > I have problems like this > > iexplore.exe when calling some ActiveX > > Faulting application iexplore.exe, version 8.0.6001.18813, time stamp > 0x4a6621ae, faulting module ntdll.dll, version 6.0.6001.18000, time stamp > 0x4791a7a6, exception code 0xc0000374, fault offset 0x000b015d, process id > 0x2890, application start time 0x01ca14ee0db44e69. > > or WScript.exe when calling some ActiveX > > Faulting application WScript.exe, version 5.7.0.18068, time stamp > 0x48235878, faulting module ntdll.dll, version 6.0.6001.18000, time stamp > 0x4791a7a6, exception code 0xc0000374, fault offset 0x000b015d, process id > 0x19c0, application start time 0x01ca14edec259ba9. > > on WINXP the same ActiveX no problem, > ntdll.dll version on WinXP 5.1.2600.5755. > > what can I do ? > > mike |
| | Re: faulting module ntdll.dll I have rebuilded affected ActiveX under Vista, and the problem is solved. It seems to be some incompatibility in ntdll.dll betveen XP and Vista versions. mike "zachd [MSFT]" <zachd@xxxxxx> wrote in message news:u9OyNlVFKHA.4316@xxxxxx Quote: > > That information by itself isn't decipherable. Generally for any > non-submitted data report the data you have will be missing a potentially > useful data point. > > You could potentially use the Windows Debugging SDK to track this down > further. =\ > > -- > Speaking for myself only. > See http://zachd.com/pss/pss.html for some helpful WMP info. > This posting is provided "AS IS" with no warranties, and confers no > rights. > -- > "Michal Valent" <valent@xxxxxx> wrote in message > news:ewe6THPFKHA.4220@xxxxxx Quote: >> Hello, >> I have problems like this >> >> iexplore.exe when calling some ActiveX >> >> Faulting application iexplore.exe, version 8.0.6001.18813, time stamp >> 0x4a6621ae, faulting module ntdll.dll, version 6.0.6001.18000, time stamp >> 0x4791a7a6, exception code 0xc0000374, fault offset 0x000b015d, process >> id 0x2890, application start time 0x01ca14ee0db44e69. >> >> or WScript.exe when calling some ActiveX >> >> Faulting application WScript.exe, version 5.7.0.18068, time stamp >> 0x48235878, faulting module ntdll.dll, version 6.0.6001.18000, time stamp >> 0x4791a7a6, exception code 0xc0000374, fault offset 0x000b015d, process >> id 0x19c0, application start time 0x01ca14edec259ba9. >> >> on WINXP the same ActiveX no problem, >> ntdll.dll version on WinXP 5.1.2600.5755. >> >> what can I do ? >> >> mike > |
| Access violation ... in module ntdll.dll | Vista General | |||
| APPCRASH - fault module NTDLL.DLL! | Vista General | |||
| Faulting Applications | Gaming | |||
| Live messenger crash faulting module msvcr80.dll | Vista General | |||
| Windows Media Players Has Stopped Responding, Faulting Module mswm | Vista General | |||
