| | Problems with HP Solution Center on HP Pavillion running VISTA Home Permium I had HP Solution Center for an HP Scanjet 4850 installed on a PC running WINDOWS XP. I ported Solution Center over to a PC running Windows Vista using Microsoft's Windows Easy Transfer Companion. When I start HP Solution Center I get a message (every time) "Please wait while Windows configures HP Solution Center". If I cancel or not I get an error message saying that a network resource is unavailable. When I click OK Solution Center starts, gives me the same error message. When I clear all error Messages I am able to scan photos, documents etc.I tried reinstalling the software but then I try I get an error stating that the installer cannot access the HKEY\Local_Machine\System\ENUM registry key. I have tried changing the permissions on that key but Vista will not let me save changes even though I am logged in to an administrator account.Where do I go from here. Post Originated from http://www.VistaForums.com Vista Support Forums |
| | Re: Problems with HP Solution Center on HP Pavillion running VISTA Home Permium "johns" schreef in bericht news:udznQpvFKHA.4280@xxxxxx Quote: > I had HP Solution Center for an HP Scanjet 4850 installed on a PC running > WINDOWS XP. I ported Solution Center over to a PC running Windows Vista > using Microsoft's Windows Easy Transfer Companion. When I start HP > Solution Center I get a message (every time) "Please wait while Windows > configures HP Solution Center". If I cancel or not I get an error message > saying that a network resource is unavailable. When I click OK Solution > Center starts, gives me the same error message. When I clear all error > Messages I am able to scan photos, documents etc.I tried reinstalling the > software but then I try I get an error stating that the installer cannot > access the HKEY\Local_Machine\System\ENUM registry key. I have tried > changing the permissions on that key but Vista will not let me save > changes even though I am logged in to an administrator account.Where do I > go from here. > > > Post Originated from http://www.VistaForums.com Vista Support Forums Maybe not a direct answer but just for information. I was running scanner HP4570 on my ME. I installed the CD-SW on my Vista but he refused to work and after several contacts with the help center the only solution was to perform a clean install on Vista. Afterwards not at all instaaling the CD-SW but directly connecting the scanner to an USB-bus and everthing was working fine. A technical clarification i didn't receive but the scannner is now working fine. regards Huib |
| HP Pavillion Elite m9660f with Vista Home Premium 64 SP1. | Vista installation & setup | |||
| Big Problems running Sims 2 on Vista Home Premium | Vista Games | |||
| Windows Vista Problems and Solution center | Vista General | |||
| Running Vista Home Premium but no Media Center | Vista networking & sharing | |||
| problems with windows vista solution center in control panel | Vista General | |||
