Vista - Switch to Home Basic from Home Premium?
Old 08-09-2009   #1 (permalink)
Paul
Hi everyone,
I recently upgraded a 4 year old laptop with 2GB of RAM from XP to Vista
Home Premium. The upgrade went well and everything works fine, except that
I can't use Windows Media Center to it's full potential or edit movies due
to the limitations of my graphics card. I can live without this full
functionality, however a TON of my hard drive space is taken up my WMC when
I can barely use it anyway.
Long story short, I should have upgraded to Windows Home Basic. I think I
heard that all upgrade DVDs contain all versions of the OS and was wondering
if there's a way to "downgrade" to Home Basic from the Premium DVD. (Or
maybe unintall WMC, but I can't find that option anywhere).
Thanks in advance for any answers.
Paul
Cleveland, Ohio
Old 08-09-2009   #2 (permalink)
Richard G. Harper
Re: Switch to Home Basic from Home Premium?
Neither of these options will work for you. There is no way to uninstall
MCE features and since the product key you have is for Home Premium it won't
install Home Basic. You would be best advised to leave things as they are.
"Paul" <veck712@xxxxxx> wrote in message
news:OU08CXMGKHA.2516@xxxxxx
Quote:
> Hi everyone,
> that
> when
> wondering
> Paul
> Cleveland, Ohio
Old 08-09-2009   #3 (permalink)
ray
On Sun, 09 Aug 2009 05:27:00 -0400, Richard G. Harper wrote:
> uninstall MCE features and since the product key you have is for Home
> Premium it won't install Home Basic. You would be best advised to leave
> things as they are.
Damn - what a way to run a business!
Quote:
>> Hi everyone,
>> Vista Home Premium. The upgrade went well and everything works fine,
>> except that
>> due to the limitations of my graphics card. I can live without this
>> full functionality, however a TON of my hard drive space is taken up my
>> WMC when
>> think I heard that all upgrade DVDs contain all versions of the OS and
>> was wondering
>> (Or maybe unintall WMC, but I can't find that option anywhere).
>> Paul
>> Cleveland, Ohio
Old 08-09-2009   #4 (permalink)
Colin Barnhorst
Quote:
> Hi everyone,
> that
> when
> wondering
> Paul
> Cleveland, Ohio
You need a Home Basic product key and you would have to reinstall from
scratch. If your Home Premium came preinstalled on the machine then you
might also need a Vista dvd as well.
Windows Vista Home Premium Key Home Basic Discs General Discussion
ip4200: Vista Home Basic Fails, but Home premium works Vista print fax & scan
Re: Anytime Upgrade from Vista Home Basic to Home Premium Vista installation & setup
Re: Upgrading from Home basic to Home premium-all things not installed Vista General
Re: Upgrading from Home basic to Home premium-all things not installed Vista installation & setup
