Vista - System Restore won't work (again)
Old 08-10-2009   #1 (permalink)
rmo555
I had this problem once before where none of my Restore Points worked.
I shut off System Restore, then turned it back on again - then it
worked. That was 1-2 months ago. I just needed it and it exhibited
the same problem. Both times, it worked in Safe Mode only. But then,
I lost all my other Restore Points. Any suggestions?
System Restore doesn't work Vista General
System restore and other system apps do not work Vista General
Does system restore really work? Vista General
System Restore does not work Vista General
System Restore Just Doesn't work Vista performance & maintenance
