Vista Forums Home Join Vista Forums Tech Publications Windows 7 Forum Vista Tutorials Webcasts Tags
Welcome to Vista Forums we are your forum for Windows Vista help and discussion. Whether you need help or just want to post an idea you have on Vista, this is the forum for you.
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
home network and printer connection problems with XP and Vista
Update your Vista Drivers
Thread Tools Display Modes
Old 10-29-2006   #1 (permalink)
MarkC
Guest
Hopefully someone else is running into the same issue and has a sugestion. I
am testing RC-1 and running RC-1 on my laptop while the home network and
printer run off of XP Home on a desktop. I can connect to the desktop and
see the shared folders but when I open them on the laptop, nothing shows up.
It is a similiar problem with the home network printer. It shows up under
the shared folders, but when I try to connect I get the message: Access
Denied.
Any solutions?
Old 10-29-2006   #2 (permalink)
Jan Il
Guest
Re: home network and printer connection problems with XP and Vista
Hi Mark :-)
There have been a number of problems with the home network. It sounds like
perhaps a permissions problem. Here are a few things that you might check
out:
1. Have you ensured that the permissions have all been set properly in the
Share folder?
2. Try setting the permissions for Everyone for that folder and the printer
and see if that will allow access. It Everyone is not in the list of
permissions, add it, then set the permissions for full as a test. If that is
not the problem then you can disable or delete it.
3. Make sure that you are a logged on as a user of that machine, not a
guest.
4. Double check the passwords if any are required.
5. Make sure the machines are on the same Workgroup
6. Make sure you have "Turn on printer sharing" in the network setup
checked.
7. Be sure you have the printer Share properly set up in the Control Panel
Hope this helps.
Jan
MS MVP - Windows IE/OE [DTS/AumHa]
Data/Comp Technology
www.datacomptech.com
Smiles are meant to be shared,
that's why they're so contagious.
Replies are posted only to the newsgroup for the benefit or other readers.
How to make a good newsgroup post:
http://www.dts-l.org/goodpost.htm
"MarkC" <MarkC@discussions.microsoft.com> wrote in message
news:3DE5B689-9900-4EE5-80E5-E1F72479C257@microsoft.com...
> I
> up.
> Denied.
> Any solutions?
Old 10-29-2006   #3 (permalink)
MarkC
Guest
Thanks for the advice. I followed your instructions and partial success. I
can view folders and content on the desktop, which runs XP Home on my Laptop
which is running RC-1. I could not find the permissions box. However, the
network printer is still the problem. I am still denied access. I had the
same problem when running One Care on XP but it vanished when I put McAfee
in. I have not tried this yet since I like the features with One Care, but I
do want to have access to wireless printing.
Mark
"Jan Il" wrote:
> Hi Mark :-)
> out:
> Share folder?
> guest.
> checked.
> Hope this helps.
> Jan
> > I
> > up.
> > Denied.
> > Any solutions?
Old 10-29-2006   #4 (permalink)
Jan Il
Guest
news:9A0D4E3C-8A74-4507-89D3-0BE3C404BD3A@microsoft.com...
> I
> Laptop
> the
> the
> but I
I have a laptop that is wireless, and I use the network printer on one of my
desktops. It works fine. Try this as a test; open Windiows Explorer on the
PC that has the printer that you want to use for your laptop. Locate the
folder that you have set up on the machine to share that displays the
printer. Right click on the folder itself, not the printer (if you have
already set it up to share), Mine is called Jan's Network Share, then select
Sharing and Security. Click on the Sharing tab>Check the box for Share this
folder, then click on the Permissions tab. You should see a window with the
word Everyone in it. Tick it and then check all of the permissions, then
OK/Apply.
Then click on the Security tab>In the Group of users list if you don't see
the word Everyone, click the Add tab and add the word Everyone, then set
full control for Everyone. Click OK and close out of that all the way. Log
on to the laptop and see if you can get access. It might take several
minutes for the list to fully populate. If this will allow you to use the
printer, then you can go back and reset the permissions as you like as long
as you can still get access.
I had the same problems and this is what has worked for me, and about the
only thing that does.
Let us know how this works.
Hope this helps.
Jan
> Mark
> "Jan Il" wrote:
>> Hi Mark :-)
>> like
>> check
>> out:
>> the
>> Share folder?
>> printer
>> is
>> guest.
>> checked.
>> Panel
>> Hope this helps.
>> Jan
>> readers.
>> > sugestion.
>> > I
>> > and
>> > and
>> > shows
>> > up.
>> > under
>> > Access
>> > Denied.
>> > Any solutions?
Display Modes
Vista Network printer connection rlevitz Vista networking & sharing 4 06-26-2008 09:01 AM
Home Network Connection from XP (ICS) to Vista BobM Vista networking & sharing 2 12-29-2007 07:50 PM
Home Network Windows Vista laptop + XP Desktop connection problems LindaAnn Vista networking & sharing 5 06-05-2007 02:14 AM
Vista peer group network printer connection Capt Bob Vista networking & sharing 5 04-19-2007 09:19 AM
vista/ xp pc's on home network- internet connection problems bullpig Vista networking & sharing 5 02-25-2007 11:04 PM
Complimentary Industry Resources
Vista Forums has joined forces with TradePub.com to offer you a new, exciting, and entirely free professional resource. Visit http://vistax64.tradepub.com today to browse our selection of complimentary Industry magazines, white papers, webinars, podcasts, and more across 34 industry sectors. No credit cards, coupons, or promo codes required. Try it today!
© Designer Media 2005-2008
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51
